12-14-2016, 20:45 | #151 (permalink) |
Junior Member Join Date: May 2002 Age: 51
Member: 11528 Status: Offline Thanks Meter: 2 | Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below:============================================ ==== Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : F741F157D09CA5D78276C899 Box Status : NOT ACTIVATED please help me to activate this box,thanhk in advance. |
The Following User Says Thank You to tibitech For This Useful Post: |
03-03-2017, 10:58 | #152 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2690775 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : CE0CBF99C84310428A3CF101 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Help me, please |
03-03-2017, 11:59 | #153 (permalink) |
Junior Member Join Date: May 2015
Member: 2399418 Status: Offline Thanks Meter: 2 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : F5ADF65B84A0C3D3D9384FFA ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Help me, please |
The Following User Says Thank You to ngocbao_mobi For This Useful Post: |
03-03-2017, 16:40 | #155 (permalink) | |
Major Poster Join Date: May 2011 Location: south africa
Member: 1585460 Status: Offline Sonork: 6678600 Thanks Meter: 3 | Quote:
Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : 9952FEC68FD6829EAF330674 plz help me for Acrivate thanks | |
The Following User Says Thank You to m.aqeel36 For This Useful Post: |
03-03-2017, 16:46 | #156 (permalink) |
Member: 1585460 Status: Offline Sonork: 6678600 Thanks Meter: 3 | Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : 9952FEC68FD6829EAF330674 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done plz help me for Activate thanks |
03-04-2017, 07:53 | #157 (permalink) |
Freak Poster Join Date: Feb 2010 Location: Philippines
Member: 1227219 Status: Offline Sonork: 100.1662069 Thanks Meter: 21 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : EA809909A7BA9C7CCC639A84 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ |
03-04-2017, 09:07 | #159 (permalink) |
Freak Poster Join Date: Aug 2014 Location: khulna bangladash
Member: 2243325 Status: Offline Sonork: 01715634715 Thanks Meter: 28 | my advancebox gold is the atf network login to your atf network account invalid responsc halp me advancebox tim my atf box full Activation gsmsumonshapla bangladash khulna halp me atf box ATF JTAG v1.0.15.8544 (6/17/2015) Default language ID 0x0409, LR 14 JTAG Interface Connected, S/N 0xCA60B9CA Resetting and Exploring JTAG Checking ATF JTAG Activation from Server...The operation timed out |
03-04-2017, 13:07 | #160 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2212568 Status: Offline Thanks Meter: 0 | sir what is the problem my atf box Driver Version : 00020828 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : FF6E76F8D68CE6D0B41887DF ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ PLZ HELP ME. |
03-04-2017, 13:49 | #161 (permalink) |
Freak Poster Join Date: Mar 2017 Location: Moskow
Member: 2691652 Status: Offline Thanks Meter: 60 | ============================================== Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : E56982019190839821389979 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software =============================================== Help me, please |
03-04-2017, 18:18 | #162 (permalink) |
Junior Member Join Date: Jan 2016
Member: 2522327 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : A0CC7AA0C43E0607FFB74A6F ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Help me, please |
03-04-2017, 20:10 | #163 (permalink) |
No Life Poster Join Date: May 2010 Location: EGYPT Age: 39
Member: 1298774 Status: Offline Sonork: 100.1584126 Thanks Meter: 94 | Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : B95613598E73D37CBA5D65F7 ========================================= Please Try Again Later (Server Busy) ========================================= |
03-05-2017, 03:08 | #164 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1985027 Status: Offline Thanks Meter: 2 | atf server connection error ..... cannot activate box... no feedback of product supporter if the server is totally dead.. many consumers are affected with this problem.. pls update thnx.. |
03-05-2017, 12:59 | #165 (permalink) |
Junior Member Join Date: Sep 2005 Location: ukraine Age: 40
Member: 184803 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : EFA087E1FAA978C7FD7BD1A0 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
