02-03-2015, 04:40 | #16 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Activate Box Now 2 Times. @vasya123451 Who is your Reseller and what Date did you buy this Box? @bladi2372 This is SX4 Problem? |
The Following User Says Thank You to Advance-Box For This Useful Post: |
02-04-2015, 21:29 | #18 (permalink) |
Junior Member Join Date: Aug 2014 Location: rio blanco , nicaragua
Member: 2240524 Status: Offline Thanks Meter: 1 | i bought on april 2014 in nicaragua, it was working perfect till last update always show me "sx4 Connecting to : 59.148.208.118 >> Connect timed out". when im trying to connect to server google show mw this page can not be loaded try again later or check internet connection even with v11.92 Advance Turbo Flasher Found ================================================ Driver Version : 00021200 Library Version : 00030209 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.92 AdvanceBox SN : A9E8C139F050D62093F59871 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
02-05-2015, 02:44 | #19 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
02-05-2015, 02:57 | #21 (permalink) |
No Life Poster Join Date: May 2010 Location: EGYPT Age: 39
Member: 1298774 Status: Offline Sonork: 100.1584126 Thanks Meter: 94 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : D849DA11CA8B0D72E3EF4C4A Box Status : NOT ACTIVATED ================================================ Please Activate your Box |
02-05-2015, 03:13 | #23 (permalink) | |
THIS Box is STILL Blocklisted. | |
02-05-2015, 11:09 | #24 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1163778 Status: Offline Sonork: 246 Thanks Meter: 1 | ATF box Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below: Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v11.92 AdvanceBox SN : 2C01949F688BDB1BEB95D3A7 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done date: 2015.01.15 reseller: hoangthong mobile box do not add active credit SL3, please help me.thanks |
02-05-2015, 14:26 | #25 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @laodai1983, Sticky thread there are for to be read not only for do number of post: sl3-brute-force-server-shutdown-notice BR |
02-08-2015, 15:49 | #28 (permalink) |
Junior Member Join Date: Jul 2010 Location: palembang
Member: 1342287 Status: Offline Thanks Meter: 1 | Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.92 AdvanceBox SN : 8A6464EC830A40C59762A66A Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-07-2015, 13:07 | #29 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2358472 Status: Offline Thanks Meter: 0 | Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below: Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.05 AdvanceBox SN : A027F251F0D28F67FD0BEDD9 Box Status : NOT ACTIVATED |
03-07-2015, 13:51 | #30 (permalink) |
No Life Poster Join Date: Jan 2012 Location: Satkhira khulna Bangladesh
Member: 1716947 Status: Offline Sonork: 100.1661965 Thanks Meter: 195 | Hello boss my box not get auto update please tell... when i click auto update software show new update is avilable and i click yes software show download done but not update software please solved my problem.... ================================================ Driver Version : 00020828 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v11.88 AdvanceBox SN : 835DCA51D7486812E596907E Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
The Following User Says Thank You to shanawas_1 For This Useful Post: |
