03-18-2015, 05:07 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Octoplus Team
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | Bad atf server daily busy why? I use everyday your software but a few days ago could not connect server so I cant use it now. How to connect atf server? please any solution my problem!!!!! |
03-18-2015, 11:10 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, your screen shot isn't visible. Please upload somewhere else or write here the problem clearly. BR |
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post: |
03-18-2015, 15:01 | #5 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @Islombek1991, What you problem?...i can see good that you have already Last Atf Version 12.06 and the same sw say you this...so where's you problem? |
The Following 2 Users Say Thank You to allumts For This Useful Post: |
03-22-2015, 09:15 | #6 (permalink) |
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | Hello Bro Thanks answer my question. ATF cant connect the internet. I cant use it. I upload img and logs here. Please be carefully look thanks. |
03-22-2015, 09:38 | #9 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Excuseme but you what want say with this: Quote:
Please post Clear Log and screenshoot of this you problem...from this photo is all ok, no issue, impossible help you if not explain clear What you problem. NOTE: Many Operaction you not have need any Internet becouse work in Standalone. Only thingh i can see from first Photo is the Box requiering for Activaction...have Activate this after the last fw? BR allumts | |
03-22-2015, 11:16 | #12 (permalink) |
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | Brother Allumts My problem Atf not activated on my pc here is logs ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.06 AdvanceBox SN : ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
03-22-2015, 11:17 | #13 (permalink) |
Member: 1922302 Status: Offline Sonork: 100.1638015 Thanks Meter: 23 | Here is logs brother my atf not activated on my pc ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.06 AdvanceBox SN : ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
