08-16-2013, 05:09 | #1 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1120953 Status: Offline Thanks Meter: 3 | Bb5 f bus not detect.. Usb ok but f bus pblm ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 10.3.70 Software Version : v10.00 AdvanceBox SN : C285F9388342A1A1D270C58E Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ Forcing Test Mode via BUSCHECK... Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED |
08-16-2013, 06:01 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | What happening with all phone ? What type of box ? Have you restore box firmware ? Need these answer Br - srinibas |
08-16-2013, 08:24 | #4 (permalink) |
No Life Poster Join Date: Apr 2011
Member: 1560569 Status: Offline Thanks Meter: 100 | If u did all software methods and did nit help u have to do as I did if u have big box Hardware method to remove 2 Coils from the box ! Find the pdf instruction file in ATF section here |
08-17-2013, 11:08 | #5 (permalink) |
Freak Poster Join Date: Jun 2006 Location: pok wong malaysia
Member: 300886 Status: Offline Thanks Meter: 61 | if u problem from atf lightning, try this. it's working to me till now. http://forum.gsmhosting.com/vbb/f609...-fbus-1448881/ |
The Following User Says Thank You to kindo For This Useful Post: |
08-19-2013, 01:49 | #7 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | On 2nd post i was ask about box type , n you indirectly answer on 6th post . When any supporter asking you about anything , read carefully n reply . without proper answer , we cant help you . you have update your firmware with wrong PCB type , check it , all will OK Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
