01-17-2013, 13:22 | #3 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Iraq Age: 37
Member: 1773166 Status: Offline Sonork: 100.1627804 Thanks Meter: 26 | . DO NOT USE THE PHONE"S BATTERY 14:05:37 : 2. Connect the Soldered TP Connections to ATF Box 14:05:37 : 3. Disconnect the USB Cable and Wait until the 14:05:37 : the ATF Software will tell you to Connect the USB. 14:05:37 : 14:05:39 : 14:05:39 : Interface Reset OK! 14:05:39 : Reading Platform Information... 14:05:39 : Selecting Active Handle... 14:05:39 : Select Handle OK! 14:05:39 : Sending Ping... 14:05:39 : Ping Reply OK! 14:05:39 : 14:05:39 : Lumia 800/800C Detected 14:05:39 : 14:05:39 : Storage Device Information 14:05:39 : Manufacturer ID: 90 14:05:39 : Application ID : 014A 14:05:39 : Product Name : HYNIX 14:05:39 : Product Rev : 5C 14:05:39 : Product SN : 0675A601 14:05:39 : 14:05:39 : Protection Information 14:05:39 : Write Protect A: OFF 14:05:39 : Write Protect B: OFF 14:05:39 : 14:05:39 : Writing MBR... 14:05:40 : Write Success! 14:05:40 : Writing SEC_BOOT... 14:06:10 : Write Success! 14:06:10 : Writing OSBL... 14:07:05 : ERROR: Block Write Failed at 0x00000B64 14:07:05 : Check your Test Point Soldering! 14:07:05 : ERROR: WRITE FAILED! |
01-17-2013, 14:55 | #6 (permalink) |
Member: 1773166 Status: Offline Sonork: 100.1627804 Thanks Meter: 26 | 14:05:25 : 1. DO NOT USE THE PHONE"S BATTERY 14:05:25 : 2. Connect the Soldered TP Connections to ATF Box 14:05:25 : 3. Disconnect the USB Cable and Wait until the 14:05:25 : the ATF Software will tell you to Connect the USB. 14:05:25 : 14:05:30 : 14:05:30 : Interface Reset OK! 14:05:30 : Reading Platform Information... 14:05:30 : Selecting Active Handle... 14:05:30 : Select Handle OK! 14:05:30 : Sending Ping... 14:05:30 : Ping Reply OK! 14:05:30 : 14:05:30 : Lumia 800/800C Detected 14:05:30 : 14:05:30 : Storage Device Information 14:05:30 : Manufacturer ID: 90 14:05:30 : Application ID : 014A 14:05:30 : Product Name : HYNIX 14:05:30 : Product Rev : 5C 14:05:30 : Product SN : 0675A601 14:05:30 : 14:05:30 : Protection Information 14:05:30 : Write Protect A: OFF 14:05:30 : Write Protect B: OFF and now : 1. DO NOT USE THE PHONE"S BATTERY 14:08:27 : 2. Connect the Soldered TP Connections to ATF Box 14:08:27 : 3. Disconnect the USB Cable and Wait until the 14:08:27 : the ATF Software will tell you to Connect the USB. 14:08:27 : 14:08:29 : 14:08:29 : Interface Reset OK! 14:08:29 : Reading Platform Information... 14:08:29 : Selecting Active Handle... 14:08:29 : Select Handle OK! 14:08:30 : Sending Ping... 14:08:30 : Ping Reply OK! 14:08:30 : 14:08:30 : Lumia 800/800C Detected 14:08:30 : 14:08:30 : Storage Device Information 14:08:30 : Manufacturer ID: 90 14:08:30 : Application ID : 014A 14:08:30 : Product Name : HYNIX 14:08:30 : Product Rev : 5C 14:08:30 : Product SN : 0675A601 14:08:30 : 14:08:30 : Protection Information 14:08:30 : Write Protect A: OFF 14:08:30 : Write Protect B: OFF 14:08:30 : 14:08:30 : Writing MBR... 14:08:30 : Write Success! 14:08:30 : Writing SEC_BOOT... 14:09:06 : Write Success! 14:09:06 : 14:09:06 : BOOT Images Written Successfully! 14:09:06 : 14:09:06 : Total Elapsed Time 00:00:38 same problem phone dead |
