05-15-2014, 07:19 | #1 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2134218 Status: Offline Thanks Meter: 0 | BootFlashModeDCT5Ex Failed ERROR: FBUS Boot FAILED im new to ATF and im still searching/reading/learning, but i found no solution for this problem. I have a ATF Nitro and my goal is to read the full flash from a Nokia 6300 RM-217. Phone is connected with a GPG6300 Phone-Connector. Everytime i get: Booting Phone via FBUS...Some postings here say: Restore Eeprom, Restore Box .. All tested, Box is up-to-date, but nothing helps. Im using Version 11.30 and first output is: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : EE73DEA1FBAE8.... Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ Thanks. Denny |
05-15-2014, 13:03 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @DennyM Please check with other phone and see if booting/flashiing is okay? If so, then you can be certain that it is phone's hardware or your FBUS cable problem. BR |
