08-22-2014, 10:14 | #1 (permalink) |
Insane Poster Join Date: Feb 2005 Location: Poland ,Krakw Age: 46
Member: 117016 Status: Offline Thanks Meter: 2 | Box demaged after 11.60 Im just update my box to 11.60 now vid adn pid was change aplication tot recognize my box in xp sp3 it show as Usb serial conventer A and B this is my log 10:15:13 : ================================================ 10:15:13 : Advance Turbo Flasher Found 10:15:13 : ================================================ 10:15:13 : Driver Version : 00021000 10:15:13 : Library Version : 00030207 10:15:19 : Box Type : ?1o+aOu 7*BaO 10:15:19 : Box Firmware : mdp?,??71???a 10:15:19 : Software Version : v11.60 10:15:19 : AdvanceBox SN : F57AB21F22583842FEDC6411 10:15:19 : 10:15:19 : ============================================== 10:15:19 : ATF Box is not in USB 2.0 Mode 10:15:19 : ============================================== 10:15:19 : 10:15:19 : * Go to "Product Support" tab and click the 10:15:19 : * "Restore Box" Button to fix the Box Firmware 10:15:19 : 10:15:19 : ** If Problem is Not Solved... 10:15:19 : 1. Make Sure you are NOT using USB HUBS 10:15:19 : 2. Make Sure your USB port is USB 2.0 10:15:19 : 3. Make Sure you are using the latest Drivers 10:15:19 : 10:15:19 : *** If Problem is STILL Not Solved 10:15:19 : 1. Use a THICKER USB Cable 10:15:19 : 2. Connect ATF Directly to the Root USB Port 10:15:19 : 3. Uninstall Drivers, Reboot PC, Reinstall 10:15:19 : 10:15:19 : **** If you are still Stuck... 10:15:19 : 1. Search your entire PC for "ftdibus.sys 10:15:19 : 2. Delete all "ftdibus.sys" files you find 10:15:19 : 3. Reboot PC... 10:15:19 : 4. Disconnect ATF Box and all Boxes from PC 10:15:19 : 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 10:15:19 : 6. ReInstall ATF Software 10:15:19 : 7. Connect ATF Box Only to your USB Port 10:15:19 : 8. Install the Correct Drivers 10:15:19 : 10:15:21 : Box Type : $rO M6Oq?eTJ^ 10:15:21 : Box Firmware : !~j4?Polei 10:15:21 : Software Version : v11.60 10:15:21 : AdvanceBox SN : 62EDF5049233598C3AFF3A8F 10:15:21 : 10:15:21 : ============================================== 10:15:21 : ATF Box is not in USB 2.0 Mode 10:15:21 : ============================================== 10:15:21 : 10:15:21 : * Go to "Product Support" tab and click the 10:15:21 : * "Restore Box" Button to fix the Box Firmware 10:15:21 : 10:15:21 : ** If Problem is Not Solved... 10:15:21 : 1. Make Sure you are NOT using USB HUBS 10:15:21 : 2. Make Sure your USB port is USB 2.0 10:15:21 : 3. Make Sure you are using the latest Drivers 10:15:21 : 10:15:21 : *** If Problem is STILL Not Solved 10:15:21 : 1. Use a THICKER USB Cable 10:15:21 : 2. Connect ATF Directly to the Root USB Port 10:15:21 : 3. Uninstall Drivers, Reboot PC, Reinstall 10:15:21 : 10:15:21 : **** If you are still Stuck... 10:15:21 : 1. Search your entire PC for "ftdibus.sys 10:15:21 : 2. Delete all "ftdibus.sys" files you find 10:15:21 : 3. Reboot PC... 10:15:21 : 4. Disconnect ATF Box and all Boxes from PC 10:15:21 : 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 10:15:21 : 6. ReInstall ATF Software 10:15:21 : 7. Connect ATF Box Only to your USB Port 10:15:21 : 8. Install the Correct Drivers 10:15:21 : 10:15:23 : Box Type : AdvanceBox Turbo 10:15:23 : Box Firmware : LogiCore 11.0.00 10:15:23 : Software Version : v11.60 10:15:23 : AdvanceBox SN : A5D8C7C6DDDEE2CCAB5F7E7F 10:15:33 : ERROR: Invalid Reply Detected... 0xB003 10:15:33 : 10:15:33 : 10:15:33 : ================================================ 10:15:33 : ATF SOFTWARE IS NOT ACTIVATED ON THIS PC 10:15:33 : Please Activate your ATF Software 10:15:33 : ================================================ 10:15:33 : 10:15:33 : * Follow these Instructions 10:15:33 : 1. Connect this PC to the INTERNET 10:15:33 : 2. Restart ATF Software 10:15:33 : 10:15:33 : 10:15:33 : 10:15:39 : 10:15:39 : Mprog wont program box |
08-22-2014, 10:50 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Mprogram know how to use? read instruction and use file in "Template" folder .ept then reprogram you Box...... or first use these steps: 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers Br allumts |
