02-05-2014, 05:23 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Ganimedes
Member: 1067814 Status: Offline Sonork: 100.1618982 Thanks Meter: 82 | Box Type: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ---(SOLUTION INSIDE) Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Box Firmware : LogiCore 11.0.00 Software Version : v11.00 AdvanceBox SN : 978A4ED9C46E32ACE1F19DB3 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// |
02-05-2014, 05:29 | #2 (permalink) |
Member: 1067814 Status: Offline Sonork: 100.1618982 Thanks Meter: 82 | im doing all i find at forum, but my box still at Box Type : ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ. how i check if it modified pcb or normal? im restore on normal and modified......an said the same errors. i download all atf full install fixed......and nothing get right......i need help.....urgent. when i restore a normal pcb only green and blue litght.. when i restored to pcb modified only blue and orange.... in restore the EEPROM and nothing. please need help. |
02-08-2014, 07:56 | #6 (permalink) | |
Banned Join Date: Nov 2013 Location: CHINA , INDIA
Member: 2061073 Status: Offline Sonork: 100.1646455 Thanks Meter: 160 | Quote:
Best Regards Advanceunlock.com | |
02-08-2014, 12:56 | #7 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @braham12 1. Disconnect ATF Box from USB port (YES DO NOT CONNECT IT) 2. Run ATF Software AdvanceBox.exe (Box is still NOT CONNECTED) 3. Goto "Product Support" ---> "Box Tools" ---> Select Box Type (ATF Normal PCB) ---> Connect ATF BOX to USB port NOW! ---> Click "Restore Box" Wait until it Finishes... it will tell you to update firmware after... After Restore Box + Update Firmware, your problem will be fixed. B.R. |
02-08-2014, 15:04 | #8 (permalink) |
Member: 1067814 Status: Offline Sonork: 100.1618982 Thanks Meter: 82 | Thanks for the best team and the best support in the world!!! my bs is alive again!!!!!!! Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.01 AdvanceBox SN : 978A4ED9C46E32ACE1F19DB3 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 08.45 09-11-11 RM-725 (c) Nokia IMEI Plain : 012765005900620 IMEI Spare : A012765005900620 IMEI SV : 30127650059006205F Phone Model: K` C2-05 Category : Entry Phone Phone Type : RM-725 ================================================ Extended Phone Information ================================================ Product Serial Number: B098339AH Product Code : 059N6Z2 Module Code : 0204808 Basic Production Code: 059D2P2 Long Production SN : 0 PPM SW Version : V 08.45 09-11-11 RM-724 (c) Nokia L BT MCM Version : 19b5-22012 MCU SW Version : V 08.45 09-11-11 RM-725 (c) Nokia HW Version : 1001 RFIC Version : Dummy RFIC version LCD Version : TPO Content Pack Version : Content: ora DO SL V 08.45 09-11-11 RM-724 (c) Nokia Bluetooth ID : F8:5F:2A:14:E4:86 CS Type : GSM850, GSM1900 ********** SIMLOCK INFO ********** CONFIG_DATA : 3700100000000000 PROFILE_BITS : 800000000003000B ASIC : 11 PROVIDER : Orange Dominicana, S.A. ;Dominican Republic [GSM] LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Close SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : NORMAL ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01022C00 DCC Ver: 003005 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... |
