Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 12-07-2011, 15:29   #1 (permalink)
hacker1gsm's Avatar
Member: 5113
Broadcom Free Authorize NOT WORK WITH ME
CHK IT PLZ ATF TEAM
             USB Phone Authorization Boot
1. Turn OFF Phone and wait 10 Seconds...
2. Connect the USB Cable to the PHONE Micro USB Port
3. Connect the USB Cable to the PC USB Port
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
 BootRom Verified!
BootFlashModeDCT5Ex Succeded After 0 Tries
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 6 (0x06)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 17  (11)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000000
     ID DWORD    1 : 00000000
     ID DWORD    2 : 22000509
     ID DWORD    3 : 200C0000
  2  EM_ASIC_ID 02
     Block Length  : 5  (05)
     ID DWORD    0 : 00005361
  3  PUBLIC_ID 12
     Block Length  : 21  (15)
     ID DWORD    1 : 00C73590
     ID DWORD    2 : 68C2F732
     ID DWORD    3 : BCE74299
     ID DWORD    4 : 30E9082B
  4  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  5  ROOT_KEY_HASH 14
     Hash          :  1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
  6  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : DE56D582
     CRC         1 : BDDE7A3A
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_usb2nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0010 ->
   Device ID         : 0011 -> Type not in database
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0030 -> K5W1G13ACB
   Revision ID       : 0431
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              :
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   Size              : 08000000 (128 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_XSR16_usbalg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
 START READING RPL DATA
IMEI: 355933041904973
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
Reading : RSA... OK!
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355933041904973\355933041904973_51042.rpl
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
  PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index   : 00
CMT PAPUBKEYS HASH:
 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
FlashInfo.RestartMode : Normal Mode
ERROR: You need 5 ATF Network Credits to Authorize this Phone
Time Taken to Complete Tasks: 00:00:11
Old 12-07-2011, 17:46   #2 (permalink)
Member: 145731
I have the same problem with my ATF
Old 12-07-2011, 17:51   #3 (permalink)
Member: 1482280
Sonork: 100.1600954
no guys its Working
check again
Old 12-07-2011, 17:57   #4 (permalink)
hacker1gsm's Avatar
Member: 5113
same
hi
i just chk it now also same erorr
b/r
Old 12-07-2011, 17:58   #5 (permalink)
frozenice's Avatar
Member: 418852
Sonork: 100:1587670
@hacker1gsm
This is EXE side limitation... Because EXE will check that you have atleast 5 credits
before it will proceed.
We will update exe in a while via AUTO UPDATE, to remove this limitation...
But for other users who have atleast 5 credits inside,, it will not be consumed at all.
Can you post your ATF Serial NUmber?
We can give you temporary 5 credits just so you can authorize this phone now.
The Following User Says Thank You to frozenice For This Useful Post:
Old 12-07-2011, 18:27   #6 (permalink)
hacker1gsm's Avatar
Member: 5113
@frozenice thanx for fast support keep up
AdvanceBox SN : E4F9A10EF4AFF95F8AE3274B
b/r
Old 12-07-2011, 18:29   #7 (permalink)
Member: 145731
this is my ATF serial number, Thanks.
Advance Turbo Flasher Found
Driver Version : 00020814
Library Version : 00030206
Box Type : AdvanceBox Turbo
Box Firmware : LogiCore 9.02.10
Software Version : v8.00
AdvanceBox SN : 9085318FBC5ACCE29A6D0207
Box Status : ACTIVATED
Box Successfully Initialized
Old 12-07-2011, 19:46   #8 (permalink)
Advance-Box's Avatar
Member: 651945
@hacker1gsm
@cocoavg
Temporary Credits transferred.
B.R.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 12-07-2011, 20:46   #9 (permalink)
Member: 35883
Sonork: 100.1608568
Library Version : 00030204
Box Type : ATF Lightning
AdvanceBox SN : 831CC3BED59C2315833622AD
not working
Old 12-08-2011, 00:44   #10 (permalink)
SFR-_-MAN's Avatar
Member: 1633151
Sonork: SFR-_-MAN
00:40:06 : ERROR: You need 5 ATF Network Credits to Authorize this Phone
00:40:06 :
00:40:06 : Time Taken to Complete Tasks: 00:00:21
00:40:46 :
00:40:46 : ERROR: You need 5 ATF Network Credits to Authorize this Phone
00:40:46 :
00:40:46 : Time Taken to Complete Tasks: 00:00:18
Old 12-08-2011, 01:25   #11 (permalink)
mamo_mogon03's Avatar
Member: 235905
Sonork: 100.1580742:mamomogon03
Simple: you need at least 5 credits available, though it will not consume on authorization.
Old 12-08-2011, 02:06   #12 (permalink)
frozenice's Avatar
Member: 418852
Sonork: 100:1587670
the 5 credits issue is just temporary, because we will stil be updating the EXE
br
Old 12-08-2011, 04:30   #13 (permalink)
Member: 1582058
AdvanceBox SN : D06B2E51EC4B165FE1C41313
thanks
Old 12-08-2011, 05:25   #14 (permalink)
lovepreet's Avatar
Member: 667436
just update your exe by checking auto update in setting it will solve thats it
Old 12-08-2011, 08:32   #15 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
thanks
ATF MINOR UPDATE v8.10!! 8th December 2011!!
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
Page generated in 0.62063 seconds with 12 queries
