Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 01-20-2011, 14:17   #1 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
*** bugs and update recommendations ***
Hi,
Please, post here all bugs found with ATF software and post update recommendations. We will try to fix bugs as fast as its possible and work on update recommended by users.
When you post about bugs - please confirm first that is realy bug or problem from you side, like cable, sw version, firmware version etc...
Please search before post about bugs, maybe.. its already fixed! And always use the most recent version of Advance-box
PS: bugs report must be with operation logs or screen shot. Post without logs or screen shot will be deleted!
PS2: This thread is for bugs and update recommendations ONLY - please be without 'thnx post', 'good update' or without any kind of successfuly flashed logs.
All posts which is not releated to this topic, will be deleted!
Old 01-21-2011, 03:08   #2 (permalink)
ralel's Avatar
Member: 405730
recomendation:
flash chip size detection for dct4/+/++
The Following User Says Thank You to ralel For This Useful Post:
Old 01-21-2011, 11:18   #3 (permalink)
kalpeshoza's Avatar
Member: 462292
it possible in next update auto write rpl backup without selecting the rpl file if we have same rpl file like M* ....
The Following User Says Thank You to kalpeshoza For This Useful Post:
Old 02-23-2011, 12:24   #4 (permalink)
nunu.gabriel's Avatar
Member: 857353
languages from PPM
It would be nice to see what languages are inside PPM. Now I'm flashing a 2330c and I don't know in wich PPM I will find russian language.
Thanks!
Old 11-15-2011, 10:59   #5 (permalink)
Member: 857353
on some models it does not detect file system, on N8 you can't change product code...
Old 11-17-2011, 16:02   #6 (permalink)
BackSlash_cu's Avatar
Member: 1020744
* Multi ATF box doesn't work at all.
* Some info about Language
* if you start the software without box, and connect the box after that, the panels down doesn't work.
* The ability to read offline some Old-New hashes, like other tools, not talking about broadcom.
Old 12-11-2011, 18:38   #7 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
Neither is a bug, but would add that ..
1)Make a Popup for content about languaje into a ppm file
2) Resize to 1024*768 for old ppl like me( or full screnn mode)
3) been to lower flash version without having to delete.
ATF does not allow write smaller versions in the cellular sl3 ..
It tells you that (you will killed for different ppm version and does not allow you cel) .. (I already know I sleep the phone temporarily)
br.
The_polack
Old 04-02-2012, 09:26   #8 (permalink)
Member: 19271
1. Box not connected
2. Software opened- "No ATF Box found" info
3. Press "Set VBAT Off"
And.... Software frozen ;-)
Old 04-02-2012, 15:18   #9 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
It is ll driver issue , not bugs
Br - srinibas ( ATF Team )
Old 04-02-2012, 19:56   #10 (permalink)
mobilefactor's Avatar
Member: 1560569
BUG in 8.60
After update to 8.60 ver.
I can BUS CHECK but can not scan the Phone ( FBUS )
hang on reading MCU ..... !
did not try the usb
I could read the hash phone also pm120 SL3
but cant read phone from SCAN button.
Old 04-03-2012, 09:02   #11 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
did not try the usb
Either you have wrongly update your Box firmware or not update it yet
Post the screenshot
Br - srinibas (ATF Team )
Old 04-03-2012, 12:54   #12 (permalink)
Member: 1560569
I did update the BOX firmware ... Latest Firmware,
I test it via USB no problem.
Old 04-03-2012, 13:44   #13 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
what type of box you have ?
BIG Chrome or Nitro/Lighting ?
If Big then what PCB inside ? Normal or modified ?
It is important to know B4 update box firmware .......
Old 04-06-2012, 10:06   #14 (permalink)
Member: 1713933
bug or what...?!
Hello ATF team!
In ATF 8.60 I noticed you can't read/reset user code anymore after this method.
F.A.Q - Frequently Asked Questions !
Because it gives me this error.
ERROR: No Flash Files Loaded
Booting/Flashing Failed...
Please Try Again...
The Following 2 Users Say Thank You to unlockflash For This Useful Post:
Old 04-07-2012, 21:46   #15 (permalink)
Member: 407451
Please add usb 3.0 support.
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! FREECELLUK Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-26-1999 22:48
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.23789 seconds with 12 queries
