Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 04-08-2012, 01:32   #16 (permalink)
Advance-Box's Avatar
Member: 651945
Originally Posted by dixx View Post
Please add usb 3.0 support.
ATF Boxes works 100% when connected to a real USB 3.0 Port. This is
because the USB 3.0 Specification requires it to be USB 2.0 backward
compatible.
Old 04-09-2012, 19:35   #17 (permalink)
Member: 407451
compatible.
Okay I know it but usb 3.0 speed?
Old 04-10-2012, 03:39   #18 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Speed of ATF at USB 2.0 is much more higher then other device at USB 3.0
Br - srinibas ( ATF Team )
Old 04-10-2012, 09:30   #19 (permalink)
amit_varietymob's Avatar
Member: 399228
I am happy customer of ATF BOX. FLASHING with ATF BOX is very good and fast.Please fix the bug in flashing , as after flashing in mobiles such as 7210c, 5220, 3110c no themes, containt etc. I use letest version flashfile and as per product code. My files are correct & not currupted. Flashed with both Fbus as well as Usb with ticking Force 64k CNT. Still same, no themes. If flashed with another tool i.e. U*S i will find themes etc. though it is little slow in flashing.
Old 04-11-2012, 14:10   #20 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
hello dear,
its not atf bug.. u need to change flash files. if u cant flash file with good CNT then ask me.
1000 of times i flashed nokia 3110c,6300,7210 etc. & never got a single problem regarding gallery empty or calculator mising...No any box except ATF can flash cnt correctly..I have cyclone,mxbox,JAF,ufs but everytime I use atf to flash these phones & I am very satisfied with it..
btw u dont need to tick "force 128K" to have gallery or calculator if u are flashing with ATF.
regards.
The Following User Says Thank You to rabirabi For This Useful Post:
Old 04-11-2012, 14:13   #21 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Hi,
Use v8.63, it has no problem at all.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 04-11-2012, 16:05   #22 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Dont tick on Force 64K CNT
All will OKAY
The Following User Says Thank You to srinibas For This Useful Post:
Old 04-15-2012, 08:10   #23 (permalink)
cabezaadrian10's Avatar
Member: 1239963
Sonork: 100.1622592
Originally Posted by ..::Angel::.. View Post
Hi,
These phone needs to be flashed UDA with factory set
in order to reset phone code to 12345. Or you can Full
Flash the phone via USB.
hi there,
please help me, i install 8.63 last update but when conect a fbus its scan phone bootflashmodedct5.exe failure
why?? whast a problem??
thx in advance..
Old 04-17-2012, 01:57   #24 (permalink)
farodriguez's Avatar
Member: 1165060
Sonork: 100.1615792
Recommendation
Originally Posted by gsm8775 View Post
pleas add email notification with unlock codes when sl3 job done .
br
Email notification when SL3 Job finish
Old 04-20-2012, 15:46   #25 (permalink)
sonicpromo's Avatar
Member: 1177924
I get out of system resources error when I try to decrupt PM120 hashes. Program locks up & has top be force closed. Had this error since upgrading to 8.63 can no longer usa ATF
Old 04-27-2012, 12:13   #26 (permalink)
faizafirdous's Avatar
Member: 1281866
My suggestion for next update is follwing
1.Add option for NPC reset in fbush & in usb mode
2.Add full back up rpl & simlock in dead condition using fbush & usb mode
i now you have added rpl back up with fbush cable add it with usb
Old 05-01-2012, 04:58   #27 (permalink)
Member: 1613772
Sonork: 005462
another one 6021 fail after flash phone is dead
ImageFile:C:\Program Files\Nokia\Phoenix\Products\RM-94\rm94__05.220
PhoneType : DCT4
Algorithm : DCT4 ALGORITHM
Supported Hardwares :
> 1131
> 1130
> 2140
> 2141
> 2142
> 2143
> 3161
> 3160
Secondary Sending Speed : 100000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 51000Hz
Number of Blocks : 540
Entry Point: 0x00E4
Is128k: True
Boot Check, Please wait...
MCUID Response
MessageID : 92
msbUPP_ID : 21
lsbUPP_ID : 42
Boot OK
Boot File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia
DataLen : 000009D8
Secondary Loader Sent...
Boot OK!
MCU_CONFIGURATION_RESPONSE_DCT4_MUL3
DCT4 Mess 9F MUL3 Mess 9F
TransMode : 03
NumFlash : 02
DevAddr0 : 01
ManuId0 : 0020 - ST
DevId0 : 882E - Type not in database
ExtId0 : 0000
RevId0 : 7121
SectorSize0: 11
Reserved0 : 00
DevAddr1 : 02
ManuId1 : 0000 - Flash
DevId1 : 0001 - not used
ExtId1 : 0000
RevId1 : 0000
SectorSize1: 00
Reserved1 : 00
ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
CheckSum : 56
ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR
SearchForBootstrap_DCT4 : No Error
Algo Match File : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_intel.fia
ALGO SENT..
Perform AUTHENTICATION..
MSID: 84AF5B1B0D30D1BDAA994CAAA5
DecodedMSID: 84D097BAE9009F7905AA000000
EncodedFAID: 96F9DA83B95E853E6B49E01B
Authentication : SUCCESSFULL
Erasing address:
>> 01000000 : 0101FFFF
BB_PROGRAMMING_STATUS_REQUEST : 04 FF
ProgrammingStatus_DCT4 : No Error - 0 (0x00)
>> 01020000 : 0187FFFF
>> 01E60000 : 01FDFFFF
Erasing Done
Flashing ImageFile
ContinueFlash_DCT4 Complete
Write Time Elapse : 00:01:17
FLASH Mode Set to : PHONEMODE_FLASHBUS
BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status
First Byte OK
Second Byte OK
BB_PERM_DATA_RESTORE_REQ : 18 FF
BB_RESTART : 07 FF
MCURestart : SUCCESS
Making delay between files for 6000ms
ImageFile:C:\Program Files\Nokia\Phoenix\Products\RM-94\rm94__05.22c
PhoneType : DCT4
> 1131
> 1130
> 2140
> 2141
> 2142
> 2143
> 3161
> 3160
Program Sending Speed : 3250000Hz
Number of Blocks : 106
Entry Point: 0x00D8
Is128k: True
MCUID Response
MessageID : 92
msbUPP_ID : 21
lsbUPP_ID : 42
Boot OK
DataLen : 000009D8
Boot OK!
TransMode : 03
NumFlash : 02
DevAddr0 : 01
ManuId0 : 0020 - ST
ExtId0 : 0000
RevId0 : 7121
SectorSize0: 11
Reserved0 : 00
DevAddr1 : 02
ExtId1 : 0000
RevId1 : 0000
SectorSize1: 00
Reserved1 : 00
CheckSum : 56
ALGO SENT..
MSID: 849A5D28D7836A76C2EBE1F147
DecodedMSID: 843E4EBAE9009F7905A9000000
EncodedFAID: EFAC706E6334A34ED7562099
Erasing address:
>> 01880000 : 01A7FFFF
Erasing Done
Flashing ImageFile
Write Time Elapse : 00:00:15
First Byte OK
Second Byte OK
BB_RESTART : 07 FF
ImageFile:C:\Program Files\Nokia\Phoenix\Products\RM-94\rm94__05.22.image_c
PhoneType : DCT4
> 1131
> 1130
> 2140
> 2141
> 2142
> 2143
> 3161
> 3160
Number of Blocks : 100
Entry Point: 0x00DF
Is128k: False
C:\Program Files\Nokia\Phoenix\Products\RM-94\rm94__05.22.image_c_128k
PhoneType : DCT4
> 1131
> 1130
> 2140
> 2141
> 2142
> 2143
> 3161
> 3160
Number of Blocks : 104
Entry Point: 0x00DF
Is128k: False
MCUID Response
MessageID : 92
msbUPP_ID : 21
lsbUPP_ID : 42
Boot OK
DataLen : 000009D8
Boot OK!
TransMode : 03
NumFlash : 02
DevAddr0 : 01
ManuId0 : 0020 - ST
ExtId0 : 0000
RevId0 : 7121
SectorSize0: 11
Reserved0 : 00
DevAddr1 : 02
ExtId1 : 0000
RevId1 : 0000
SectorSize1: 00
Reserved1 : 00
CheckSum : 56
ALGO SENT..
MSID: 846823546310E38C6B645DA4D1
DecodedMSID: 841C15BAE3009F7905AD0005BD
EncodedFAID: 26681FDA0D091785172A5500
Erasing address:
>> 01A80000 : 01E5FFFF
Erasing Done
Flashing ImageFile
Write Time Elapse : 00:00:13
First Byte OK
Second Byte OK
BB_RESTART : 07 FF
Time Elapse : 00:04:15
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
ERROR : PHONE READ INFO FAILED
Old 05-21-2012, 14:12   #28 (permalink)
Member: 367928
C2.02 RM 692 with contact service
i try to flesh with latest ver and same product code but after fleshing no local mode (still contact service)
i try three time same result then i flesh it with hwk with same files, and contact service gone, phone is working now,
is it bug or some thing else,
before this i flesh many c2-03 phone with ATF with our any problem, but this time plzzzz chk it thankss
log of atf
USB Phone BUSCheck Boot
17:55:35 : ================================================== ====
17:55:35 :
17:55:35 : 1. Remove USB and Battery...
17:55:35 : 2. Insert USB.
17:55:35 : 3. Insert Battery. (Some phones boot automatically)
17:55:35 : 4. Please Power on phone shortly...
17:55:35 :
17:55:40 :
17:55:40 : Infineon USB Boot: F00A1FB300020303010100FF
17:55:40 : Sending PBL...
17:55:43 : PBL Successfully Sent...
17:55:43 : Sending SBL...
17:55:43 : SBL Successfully Sent...
17:55:43 : Setting Transmission Speed Done...
17:55:43 : Flash Chip Manufacturer: Samsung Electronics Corp.
17:55:43 : Flash Boot Successful...
17:55:43 :
17:55:43 : Infineon USB Buscheck Done
17:55:43 : Phone Restart Mode: TEST MODE
17:55:43 :
17:55:43 : Process Done...
17:56:23 :
17:56:23 :
17:56:23 : ================================================== ====
17:56:23 : USB Phone BUSCheck Boot
17:56:23 :
17:56:23 : 1. Remove USB and Battery...
17:56:23 : 2. Insert USB.
17:56:23 : 3. Insert Battery. (Some phones boot automatically)
17:56:23 : 4. Please Power on phone shortly...
17:56:23 :
17:56:29 :
17:56:29 : Infineon USB Boot: F00A1FB300020303010100FF
17:56:29 : Sending PBL...
17:56:32 : PBL Successfully Sent...
17:56:32 : Sending SBL...
17:56:32 : SBL Successfully Sent...
17:56:32 : Setting Transmission Speed Done...
17:56:32 : Flash Chip Manufacturer: Samsung Electronics Corp.
17:56:32 : Flash Boot Successful...
17:56:32 :
17:56:32 : Infineon USB Buscheck Done
17:56:32 : Phone Restart Mode: TEST MODE
17:56:32 :
17:56:32 : Process Done...
17:57:42 : Number of Image Files: 3
17:57:42 :
17:57:42 : Processing Image File :
17:57:42 : rm692__07.48a.mcusw
17:57:42 : rm692__07.48a.ppm_mh1
17:57:42 : rm692__07.48a.image_mh1_059H0R8
17:57:43 :
17:57:43 :
17:57:43 : AUTO SELECTED DEAD USB FLASHING...
17:57:43 :
17:57:43 : If Phone Booting does not Start in 5 Seconds,
17:57:43 : Then Perform Steps 1, 2, 3 and 4...
17:57:43 :
17:57:43 : 1. Remove USB and Battery...
17:57:43 : 2. Insert USB.
17:57:43 : 3. Insert Battery. (Some phones boot automatically)
17:57:43 : 4. Please Power on phone shortly...
17:57:43 :
17:57:46 :
17:57:46 : Infineon USB Boot: F00A1FB300020303010100FF
17:57:46 : Sending PBL...
17:57:49 : PBL Successfully Sent...
17:57:49 : Sending SBL...
17:57:49 : SBL Successfully Sent...
17:57:50 : Setting Transmission Speed Done...
17:57:50 : Flash Chip Manufacturer: Samsung Electronics Corp.
17:57:50 : Flash Boot Successful...
17:57:50 :
17:57:50 :
17:57:50 :
17:57:50 : Sections : 04
17:57:50 : Current File : rm692__07.48a.mcusw
17:57:50 : Compile Name: rm692__07.48a.mcusw_ebl_psi.fls
17:57:50 : Image Type : Main Firmware
17:57:50 : Data Size : 29363592 Bytes
17:57:50 :
17:57:50 : Sending Certificate Block
17:57:50 : FIRMWARE Certificate Block Sent Successfully...
17:57:50 : Processing Section 01 of 04
17:57:50 : FIRMWARE Erase Block: 0x40000000~0x4001FFFE
17:57:50 : Start Erasing...
17:57:50 : Erasing Please Wait...
17:57:50 : Block Erase Done...
17:57:50 : Preparing Data Blocks...
17:57:50 : Data Size: 131072 bytes
17:57:50 : Data Checksum: 20BF
17:57:50 : Uploading Data Blocks to phone...
17:57:51 : Block Write Successful...
17:57:51 : FIRMWARE Data Blocks uploaded to phone...
17:57:51 : Processing Section 02 of 04
17:57:51 : FIRMWARE Erase Block: 0x40040000~0x4005FFFE
17:57:51 : Start Erasing...
17:57:51 : Erasing Please Wait...
17:57:51 : Block Erase Done...
17:57:51 : Preparing Data Blocks...
17:57:51 : Data Size: 131072 bytes
17:57:51 : Data Checksum: 7AB2
17:57:51 : Uploading Data Blocks to phone...
17:57:51 : Processing Section 03 of 04
17:57:51 : FIRMWARE Erase Block: 0x40060000~0x4015FFFE
17:57:53 : Block Erase Done...
17:57:53 : Preparing Data Blocks...
17:57:53 : Data Size: 1048576 bytes
17:57:53 : Data Checksum: C695
17:57:53 : Uploading Data Blocks to phone...
17:57:55 : Block Write Successful...
17:57:55 : FIRMWARE Data Blocks uploaded to phone...
17:57:55 : Processing Section 04 of 04
17:57:55 : FIRMWARE Erase Block: 0x40280000~0x41DBFFFE
17:57:55 : Start Erasing...
17:57:55 : Erasing Please Wait...
17:58:52 : Block Erase Done...
17:58:52 : Preparing Data Blocks...
17:58:52 : Data Size: 28049408 bytes
17:58:52 : Data Checksum: 526A
17:58:52 : Uploading Data Blocks to phone...
17:59:26 : Block Write Successful...
17:59:26 : FIRMWARE Data Blocks uploaded to phone...
17:59:26 : Data Verification Successful...
17:59:26 :
17:59:26 :
17:59:26 : Sections : 01
17:59:26 : Current File : rm692__07.48a.ppm_mh1
17:59:26 : Compile Name: package_mh1.ppm_ebl_psi.fls
17:59:26 : Image Type : PPM Image
17:59:26 : Data Size : 5144484 Bytes
17:59:26 :
17:59:26 : Sending Certificate Block
17:59:26 : PPM Certificate Block Sent Successfully...
17:59:26 : Processing Section 01 of 01
17:59:26 : PPM Erase Block: 0x41DC0000~0x424BFFFE
17:59:26 : Start Erasing...
17:59:26 : Erasing Please Wait...
17:59:42 : Block Erase Done...
17:59:42 : Preparing Data Blocks...
17:59:42 : Data Size: 5141140 bytes
17:59:42 : Data Checksum: 73C0
17:59:42 : Uploading Data Blocks to phone...
17:59:48 : Block Write Successful...
17:59:48 : PPM Data Blocks uploaded to phone...
17:59:48 : Data Verification Successful...
17:59:49 :
17:59:49 :
17:59:49 : Sections : 01
17:59:49 : Current File : rm692__07.48a.image_mh1_059H0R8
17:59:49 : Compile Name: package_mh1_059H0R8.image.fls
17:59:49 : Image Type : CONTENT Package
17:59:49 : Data Size : 13896976 Bytes
17:59:49 :
17:59:49 : Sending Certificate Block
17:59:49 : CONTENT Certificate Block Sent Successfully...
17:59:49 : Processing Section 01 of 01
17:59:49 : CONTENT Erase Block: 0x424C0000~0x43E1FFFE
17:59:49 : Start Erasing...
17:59:49 : Erasing Please Wait...
18:00:48 : Block Erase Done...
18:00:48 : Preparing Data Blocks...
18:00:48 : Data Size: 13893632 bytes
18:00:48 : Data Checksum: 1F48
18:00:48 : Uploading Data Blocks to phone...
18:01:05 : Block Write Successful...
18:01:05 : CONTENT Data Blocks uploaded to phone...
18:01:05 : Data Verification Successful...
18:01:05 : Total Flashing Time (Erase + Flashing) : 00:03:16
18:01:05 : (Booting time is NOT Included)
18:01:05 :
18:01:05 : Waiting for Phone to Start-Up..(Max 150 seconds)
18:01:05 :
18:08:08 :
18:08:08 :
18:08:08 : WARNING: Phone is not in the Required Mode...
18:08:08 : Disconnect the Phone and Power it Up Manually.
HWK LOg
Executive Path:
Please Wait ...
UFxBoot V2.2 (c) SarasSoft 2003. Id: 65 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007. S/n: 4nnnnn
HID: Fnnnnnnnnnnnnnn
HWK: nnnnnn
Features: 00000001
Licence : True
LogFile: .\_!_LOG\78315_52120126_2811_LOG.txt
Insert USB Cable to Switched ON Phone
Insert USB Cable to Switched OFF Phone and Power ON
Process Failed, Repowering Mobile
IF_USB: XGOLD21x
IF_SBL: XGOLD213, Ok
IF_EBL: Quantum_Bootloader_10.46_M1S1 10.46, Mode: CC
FL_ID : EC001230, Samsung K5N1258ACM 512Mb
MCU FLASH BUNDLE: rm692__07.48a.mcusw
Flash File: rm692__07.48a.mcusw_ebl_psi.fls
Erase Area: 0x40000000 - 0x4001FFFE...Erasing
Erase Area: 0x40000000 - 0x4001FFFE, Erased: 00:00
Write Area: 0x40000000 - 0x4001FFFE...Writing
Write Area: 0x40000000 - 0x4001FFFE, Written: 00:00
Erase Area: 0x40040000 - 0x4005FFFE...Erasing
Erase Area: 0x40040000 - 0x4005FFFE, Erased: 00:00
Write Area: 0x40040000 - 0x4005FFFE...Writing
Write Area: 0x40040000 - 0x4005FFFE, Written: 00:00
Erase Area: 0x40060000 - 0x4015FFFE...Erasing
Erase Area: 0x40060000 - 0x4015FFFE, Erased: 00:02
Write Area: 0x40060000 - 0x4015FFFE...Writing
Write Area: 0x40060000 - 0x4015FFFE, Written: 00:01
Erase Area: 0x40280000 - 0x41DBFFFE...Erasing
Erase Area: 0x40280000 - 0x41DBFFFE, Erased: 00:55
Write Area: 0x40280000 - 0x41D3FFFE...Writing
Write Area: 0x40280000 - 0x41D3FFFE, Written: 00:32
Erase Area: 0x43E20000 - 0x43E5FFFE...Erasing
Erase Area: 0x43E20000 - 0x43E5FFFE, Erased: 00:00
PPM FLASH BUNDLE: rm692__07.48a.ppm_mh1
Flash File: package_mh1.ppm_ebl_psi.fls
Erase Area: 0x41DC0000 - 0x424BFFFE...Erasing
Erase Area: 0x41DC0000 - 0x424BFFFE, Erased: 00:10
Write Area: 0x41DC0000 - 0x422A7292...Writing
Write Area: 0x41DC0000 - 0x422A7292, Written: 00:05
CNT FLASH BUNDLE: rm692__07.48a.image_mh1_059H0R8
Flash File: package_mh1_059H0R8.image.fls
Erase Area: 0x424C0000 - 0x43E1FFFE...Erasing
Erase Area: 0x424C0000 - 0x43E1FFFE, Erased: 00:28
Write Area: 0x424C0000 - 0x431FFFFE...Writing
Write Area: 0x424C0000 - 0x431FFFFE, Written: 00:15
Erase Area: 0x43E60000 - 0x43F3FFFE...Erasing
Erase Area: 0x43E60000 - 0x43F3FFFE, Erased: 00:02
Flashing Done: 02:41
ShutDown Done
MCU SW : V 07.48a 06-04-12 RM-692 (c) Nokia
PPM SW : V 07.48a 06-04-12 RM-692 (c) Nokia MH1
CNT SW : mh1_059H0R8 V 07.48a 06-04-12 RM-692 (c) Nokia
Product : C2-02
Platform: Infineon
Prd.Code: 059H0R8
Bpr.Code: 059D008
Mod.Code: 0204666
Prod.Sn : CC36AFAAI
HW Vers : 2000
RFIC Ver: Dummy RFIC version
LCD Type: TPO
BT MCM : 19b5-22012
BT Id : B0 5C E5 91 0E FA
CAM Prim: 06150123_007025
IMEI : 358641-04-857414-8
SL Conf : 001-01-00000000000
SL Prof : 800000000003000-B
SL Var : 00003586410485741400
SL Aux : 000B0000
HW Sig : C420FC9442D93297
Box Id : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
Reading PM: 0-400
Old 05-24-2012, 15:47   #29 (permalink)
nnaeem11's Avatar
Member: 144640
Sonork: nnaeem11
i m having trouble with most of Broadcom sets and also this one here not going for flashing else is showing every thing good can backup RPL and IMP PM/PP but not able to flash it
Old 06-19-2012, 12:14   #30 (permalink)
alex_030385's Avatar
Member: 875541
Sonork: 100.1604468
sometimes i have 3 unit for unlock decrypted pm 120 idont notice the one are already unlock ...but pm decrypted....
can you add warning or pm will not decrypt if phone are already unlock...
br,
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! FREECELLUK Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-26-1999 22:48
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.83237 seconds with 12 queries
