Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 07-05-2012, 16:50   #31 (permalink)
mobilefactor's Avatar
Member: 1560569
usb flash not working
Hi,
after the audate of v8.95 I did try to flash Nkia C5 RM-745 via usb. Mobile has no problem ... I need to change the language.
the bug is --- when I click FLASH
Number of Image Files : 5
apean on ATF log then nothing happen.
Old 07-05-2012, 17:26   #32 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Originally Posted by mobilefactor View Post
Hi,
Can you post the screenshot ???
Br - srinibas
Old 07-05-2012, 17:57   #33 (permalink)
Member: 1560569
Old 07-05-2012, 18:22   #34 (permalink)
Advance-Box's Avatar
Member: 651945
@mobilefactor
tap the "SPACE BAR" on your Keyboard...
It seems the pop up message "Are you sure you want to flash...." is not appearing
on your PC. So just click "SPACE BAR" 1 time and it will click the INVISIBLE "YES"
button promptly.
Try other skin if this trick works for you...
B.R.
Old 07-05-2012, 18:30   #35 (permalink)
Member: 1560569
I get the confirm alert when I click on FLASH.... but nothing
also the ATF is not in busy status after that... when I click scan again .. it is scanning the phone...
by the way I could read 120 pm and atf network ... no prob.
Old 07-05-2012, 18:34   #36 (permalink)
Member: 651945
I am downloading this flash file which you have now...
Seems another user also have a similar problem with the exact same phone
model...
085253.bmp - 4shared.com - photo sharing - download image
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 07-05-2012, 18:48   #37 (permalink)
Member: 1560569
I got it .. thanks the prob is solved ...
The Flash Files were not OK
I did download other dump and it works fine
I trust this amazing BOX .. I just liked it ....
Thanks
Old 07-06-2012, 11:53   #38 (permalink)
nnaeem11's Avatar
Member: 144640
Sonork: nnaeem11
again problem with network ID it shows other then T-Mobile USA
17:26:33 : Scanning USB Ports...
17:26:34 :
17:26:34 : ================================================
17:26:34 :             Basic Phone Information
17:26:34 : MCU Version: V ICPR82_10w12.13 09-09-10 RM-658 (c) Nokia
17:26:34 : IMEI Plain : 352002041192576
17:26:34 : IMEI Spare : A352002041192570
17:26:34 : IMEI SV    : 33520020411925751F
17:26:34 : Phone Model: Nokia E73
17:26:34 : Category   : Classic Phone
17:26:34 : Phone Type : RM-658
17:26:34 :
17:26:34 :            Extended Phone Information
17:26:34 : Product Serial Number: C9C677040
17:26:34 : Product Code         : 059B7N9
17:26:34 : Basic Production Code: 0593664
17:26:34 : Long Production SN   : 0
17:26:34 : MCU SW Version       : V ICPR82_10w12.13 09-09-10 RM-658 (c) Nokia
17:26:34 : HW Version           : 1000
17:26:34 : RFIC Version         : |Vapaus_5.1 | Mikki_1.1
17:26:34 : DSP Version          : ICPR82_10w12.13
17:26:35 : Content              : -044.008\ 15-Sep-2010\ UDA_T-Mobile_US\ rm658
17:26:35 : APE BT Version       : HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12652.
17:26:35 : AHNE Version         : 11
17:26:35 : APE SW Core Version  : 044.008
17:26:35 : Variant Version      : 044.008044.008.01.01044.008.200.01
17:26:35 : APE Test Version     : 0.012
17:26:35 : RETU Version         : 40
17:26:35 : TAHVO Version        : 00
17:26:35 : APE HW Version       : 256
17:26:35 : APE ADSP SW Version  : 256
17:26:35 : Wireless LAN ID      : 20:D6:07:60:8A:2A
17:26:35 : Bluetooth ID         : 20:D6:07:60:3C:20
17:26:35 : CS Type              : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA IV, WCDMA VIII
17:26:35 :
17:26:35 : ================================================
17:26:35 :               Simlock Information
17:26:35 : CONFIG KEY    :  8000000000000000
17:26:35 : PROVIDER KEY  :  3102000000000000
17:26:35 : NETWORK NAME  :  Union Telephone Company ;United States [GSM]
17:26:35 : LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
17:26:35 : SIMLOCK TABLE :
17:26:35 :    Block [1]  1:Close
17:26:35 :    Block [2]  1:Close
17:26:35 :    Block [3]  1:Close
17:26:35 :    Block [4]  1:Close
17:26:35 :    Block [5]  1:Close
17:26:35 :    Block [6]  1:Close
17:26:35 :    Block [7]  1:Close
17:26:35 :    Block [8]  1:Close
17:26:35 :    Block [9]  1:Close
17:26:35 :    Block [10]  1:Close
17:26:35 :    Block [11]  1:Close
17:26:35 :    Block [12]  1:Close
17:26:35 :    Block [13]  1:Close
17:26:35 :    Block [14]  1:Close
17:26:35 : SIMLOCK STATE :  LOCKED
17:26:35 :
17:26:36 : SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
17:26:36 : SIMLOCK_TEST             : PASSED
17:26:36 : SECURITY_TEST           : PASSED
17:26:36 : SECURITY_CODE          : ENCRYPTED
17:26:36 : PHONE_MODE              : RF INACTIVE
17:26:36 :
17:26:36 : WARNING: DCC Unavailable in Current State
17:26:36 : Change Phone Mode to TEST MODE
17:26:36 :
17:26:40 :
17:26:40 : Make sure you have installed the
17:26:40 : COMPLETE Flash Package for this Phone...
17:26:40 :
17:26:40 : Goto "Settings" --> "Nokia Settings" and verify that
17:26:40 : the Folder where you installed your Flash Files are
17:26:40 : in the "PRODUCT PATH TO SCAN" List...
Old 07-26-2012, 22:19   #39 (permalink)
Member: 321538
I have been unlocking bb5 sl1 and 2 phones and every time ,for direct unlock,it says (wrong simlock rpl data). after two or three times tries satarts with the message ( rpl data accepted) and succeed. I am using atf v8.95
atf team please fix it . unlock pm308 codes also wont work, it says that do direct unlock
Old 07-31-2012, 17:54   #40 (permalink)
Member: 321538
20:52:18 : Extended Phone Information
20:52:18 : ================================================
20:52:18 : Product Serial Number: SAO567658
20:52:18 : Product Code : 0556459
20:52:18 : Basic Production Code: 0545341
20:52:19 : Long Production SN : 0
20:52:19 : MCU SW Version : V ICPR71_09w14.3 17-02-10 RM-244 (c) Nokia
20:52:19 : HW Version : 0605
20:52:19 : RFIC Version : 17141715
20:52:20 : DSP Version : siiri_ICPR71_09w10a2
20:52:21 : AHNE Version : 11
20:52:21 : APE SW Core Version : 411.34.001
20:52:21 : Variant Version : 411.34.001411.34.001_v08
20:52:21 : APE Test Version : rm244ENO708.1_100.15.37v020
20:52:21 : RETU Version : 15
20:52:21 : TAHVO Version : 22
20:52:21 : APE HW Version : 256
20:52:21 : APE ADSP SW Version : 256
20:52:21 : Wireless LAN ID : 00:1FE:90:E2:15
20:52:21 : Bluetooth ID : 00:1FE:8C:EA:75
20:52:22 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA V
20:52:22 :
20:52:22 : ================================================
20:52:22 : Simlock Information
20:52:22 : CONFIG KEY : 8000000000000000
20:52:22 : PROVIDER KEY : 2380100000000000
20:52:22 : NETWORK NAME : TDC Mobil APS;Denmark [GSM]
20:52:22 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
20:52:22 : SIMLOCK TABLE :
20:52:22 : Block [1] 1:Close
20:52:22 : SIMLOCK STATE : LOCKED
20:52:22 :
20:52:22 : SIMLOCK_TYPE : PA_SL2
20:52:22 : SIMLOCK_TEST : PASSED
20:52:22 : SECURITY_TEST : PASSED
20:52:22 : SECURITY_CODE : 12345
20:52:23 : PHONE_MODE : LOCAL
20:52:28 : DCC ID : NOT USED
20:52:28 :
20:52:28 :
20:52:28 : ================================================
20:52:28 : SL1/SL2 Simlock RPL Stand Alone Edition
20:52:28 : Generating Simlock Data RPL...
20:52:29 : ERROR: Wrong Simlock RPL data
20:52:43 :
20:52:43 : ================================================
20:52:43 : Basic Phone Information
20:52:43 : MCU Version: V ICPR71_09w14.3 17-02-10 RM-244 (c) Nokia
20:52:43 : IMEI Plain : 352073020230612
20:52:43 : IMEI Spare : A352073020230610
20:52:43 : IMEI SV : 33520730202306137F
20:52:43 : Phone Model: Nokia E51
20:52:43 : Category : Smartphone
20:52:43 : Phone Type : RM-244
20:52:43 :
20:52:43 :
20:52:43 :
20:52:43 : SL1/SL2 Simlock RPL Stand Alone Edition
20:52:43 : Generating Simlock Data RPL...
20:52:44 : OK: Simlock RPL Accepted
20:52:46 :
20:52:46 :
20:52:46 : ================================================
20:52:46 : Basic Phone Information
20:52:47 : MCU Version: V ICPR71_09w14.3 17-02-10 RM-244 (c) Nokia
20:52:47 : IMEI Plain : 352073020230612
20:52:47 : IMEI Spare : A352073020230610
20:52:47 : IMEI SV : 33520730202306137F
20:52:47 : Phone Model: Nokia E51
20:52:47 : Category : Smartphone
20:52:47 : Phone Type : RM-244
20:52:47 :
20:52:47 : ================================================
20:52:47 : Extended Phone Information
20:52:47 : Product Serial Number: SAO567658
20:52:47 : Product Code : 0556459
20:52:47 : Basic Production Code: 0545341
20:52:47 : Long Production SN : 0
20:52:48 : MCU SW Version : V ICPR71_09w14.3 17-02-10 RM-244 (c) Nokia
20:52:48 : HW Version : 0605
20:52:48 : RFIC Version : 17141715
20:52:48 : DSP Version : siiri_ICPR71_09w10a2
20:52:49 : AHNE Version : 11
20:52:50 : APE SW Core Version : 411.34.001
20:52:50 : Variant Version : 411.34.001411.34.001_v08
20:52:50 : APE Test Version : rm244ENO708.1_100.15.37v020
20:52:50 : RETU Version : 15
20:52:50 : TAHVO Version : 22
20:52:50 : APE HW Version : 256
20:52:50 : APE ADSP SW Version : 256
20:52:50 : Wireless LAN ID : 00:1FE:90:E2:15
20:52:50 : Bluetooth ID : 00:1FE:8C:EA:75
20:52:51 : CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA V
20:52:51 :
20:52:51 : ================================================
20:52:51 : Simlock Information
20:52:52 : CONFIG KEY : 0000000000000000
20:52:52 : PROVIDER KEY : 2440700000000000
20:52:52 : NETWORK NAME : Nokia Default;Finland
20:52:52 : LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
20:52:52 : SIMLOCK TABLE :
20:52:52 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
20:52:52 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
20:52:52 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
20:52:52 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
20:52:52 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
20:52:52 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
20:52:52 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
20:52:52 : SIMLOCK STATE : Not Locked
20:52:52 :
20:52:52 : SIMLOCK_TYPE : PA_SL2
20:52:52 : SIMLOCK_TEST : PASSED
20:52:52 : SECURITY_TEST : PASSED
20:52:52 : SECURITY_CODE : 12345
20:52:57 : CMLA_KEY : PASSED
20:52:57 : SUPER_DONGLE_TEST : PASSED
20:52:57 :
Old 08-13-2012, 18:48   #41 (permalink)
Member: 321538
atf team,
I think you should add the shortcut keys for flash and stop process as well as factory reset of phone , in ur software.
thanks
Old 08-14-2012, 06:06   #42 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
atf team,
thanks
FLASH , STOP process & Factory reset already have with very easy option ,
Cant understand your recommendation , pls post in detail
Br - srinibas
Old 08-22-2012, 12:29   #43 (permalink)
alkesh02's Avatar
Member: 681959
Booting Phone via FBUS...
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
SET BSI Load Done
SET BSI Load Done
BootFlashModeDCT5Ex Failed
Box type Big CHEK MANY MOBILE
Old 08-22-2012, 15:43   #44 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
SET BSI Load Done
SET BSI Load Done
SET BSI Load Done
Hello answer here - ERROR: FBUS Boot FAILED
& not create post in multiple thread . otherwise you will b ignore
Br - srinibas
Old 08-22-2012, 18:29   #45 (permalink)
alkesh02's Avatar
Member: 681959
ok ok big brother
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! FREECELLUK Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-26-1999 22:48
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.26634 seconds with 12 queries
