Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 01-14-2011, 12:04   #1 (permalink)
mmrozibul's Avatar
Member: 725443
C1-01 RM-607 flashing error!
Model listed in infenion tab but flahing failed! I am used 6.0, 6.10 ,6.30 version.
Here is log of bus check (using live phone option)
Booting Phone...
ERROR: Unknown CPU Detected !!!
This phone is not yet supported...
CPU ID: 1C8C81000326800000
Flashing ERROR
another log of simple buscheck
VBATT OFF...
VBATT ON
Setting VBATT Done!...
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
VBATT OFF...
VBATT ON
Booting Phone...
ERROR: Phone did not Boot !!!
Make sure that you plugged the cable to the
RJ-45 Port Marked << EXTENSION >>
|| FLASHBUS EXTENSION ||
|| | | (O) (O) (O) | CABLE | ||
PLUG IN
CABLE HERE
Try booting this phone with "Live Phone" option
Check the option beside the "Scan Phone" button
Flashing ERROR
phone is alive and ok.
I also try with restore box but no success.
whats the problem.
Old 01-14-2011, 12:45   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
@mmrozibul
This model is not supported now, sure in next release.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 01-14-2011, 15:17   #3 (permalink)
mmrozibul's Avatar
Member: 725443
Thanks for good support.
Old 01-14-2011, 15:19   #4 (permalink)
Member: 643472
Sonork: 100.96901
Here is TEST logs ;o))
MCU: V 03.35 02-12-10 RM-607 (c) Nokia
IMEI: 353799045629300
Model : C1-01
Mastercode : 7272074121
Product Serial Number: HUB444937
Product Code : 0596365
Module Code : 0204427
Basic Production Code: 0585582
Default SN Type : 0
MCU SW Version : V 03.35 02-12-10 RM-607 (c) Nokia V
BT MCM Version : 19b5-22012
PPM Version : V 03.35 02-12-10 RM-607 (c) Nokia
HW Version : 1000
RFIC Version : 96
LCD Version : AUO
Content Pack Version : Content: v_0596365 V 03.35 02-12-10 RM-607 (c) Nokia
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000003000B
Asic : 11
Provider : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_SIMLOCK_TEST : PASSED
ST_LCD_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : NORMAL MODE
Dynamic Camera Configuration
DCC ID : NI00CS0000040C213402
DCC Ver: 002005
Status : OK
Old 01-14-2011, 15:24   #5 (permalink)
mmrozibul's Avatar
Member: 725443
Is it with 6.30 version? or for next update?
Old 01-14-2011, 15:26   #6 (permalink)
Member: 643472
Sonork: 100.96901
New version logs, v6.30 does not support this.
Old 01-14-2011, 15:27   #7 (permalink)
mmrozibul's Avatar
Member: 725443
Ok thank u we are waiting for update.
Old 01-14-2011, 15:29   #8 (permalink)
mmrozibul's Avatar
Member: 725443
Another thing we bought new box today but dct4 and infenion not boot but bb5 boot ok,try with restore box but no luck.It may be new pcb,what to do now?
Old 01-14-2011, 15:32   #9 (permalink)
Member: 643472
Sonork: 100.96901
Hello, select new pcb in 'Product Support' tab and restore box
Old 01-14-2011, 15:42   #10 (permalink)
mmrozibul's Avatar
Member: 725443
already done by this but no progress.
Old 01-14-2011, 15:50   #11 (permalink)
Member: 643472
Sonork: 100.96901
What cables are you using ? Did you try change cable ?
Old 01-14-2011, 15:53   #12 (permalink)
mmrozibul's Avatar
Member: 725443
I said i solve my previous problem by modify pcb,but i think this box comes with new types of pcb (Without LT1930) so how can i modify this pcb? or solve problem?
Old 01-14-2011, 15:55   #13 (permalink)
Member: 643472
Sonork: 100.96901
if BB5 flash OK then DCT4 should also.
Old 01-14-2011, 15:55   #14 (permalink)
mmrozibul's Avatar
Member: 725443
problem is same as my previous box dct4 info ok but boot not ok,BB5 boot-info- flash everthing ok,Infenion boot-info-flash everything failed.
Old 01-14-2011, 15:59   #15 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Contact me in sonork. I will teamviewer with you and check.
Thomas
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-28-1999 15:57
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 1.11026 seconds with 11 queries
