12-08-2013, 12:38 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: INDIA
Member: 463150 Status: Offline Thanks Meter: 91 | c2-00 only nokia (Mass Memory File Detected) Processing Image File : rm704__03.99.mcusw Processing Image File : rm704__03.99.ppm_mh Processing Image File : rm704__03.99.image_mh_jblack_059C1G4 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 1220180E25101829 Original Product Code: 059C1H5 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\352409057275841\3524090572758 41_32342.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\352409057275841\3524090572758 41_CERTIFICATE_D7109272.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\352409057275841\3524090572758 41_PMM_PROT_5A082B7B.bin Security Code: 12345 Data Sections : 04 Current File : rm704__03.99.mcusw Compile Name: rm704__03.99.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 27266440 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 2A3C Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A82 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 2B96 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41BBFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 25952256 bytes Data Checksum: 1244 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm704__03.99.ppm_mh Compile Name: package_mh.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 3902048 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41BC0000~0x421BFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 3898704 bytes Data Checksum: D628 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm704__03.99.image_mh_jblack_059C1G4 Compile Name: package_mh_jblack_059C1G4.image.fls Image Type : CONTENT Package Data Size : 11930896 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x421C0000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 11927552 bytes Data Checksum: 1BC7 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:06:14 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) WARNING: Phone is not in the Required Mode... Disconnect the Phone and Power it Up Manually. Scanning USB Ports... ================================================== ==== ERROR: Active Phone Handle was NOT DETECTED ================================================== ==== TIP: Make sure that Phone USB Connection Mode is OVI Suite Mode or PC Suite Mode ================================================== ==== ================================================== ==== Selected VPL File: RM704_059C1G4_03.99_039.vpl ================================================== ==== Variant Details : Software Version : 03.99 Product Type : Product Code : Variant Version : 039 i tried with same product code also but same only nokia or sometimes white light |
