Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 06-29-2012, 10:22   #1 (permalink)
debsden's Avatar
Member: 466182
Sonork: 100.1604458
C2-03 showing "Local Mode" only....
Model - Nokia c2-03
Problem - Whenever trying to on handset it showing "Local Mode" only...
Log...
Number of Image Files: 3
  Processing Image File :
   rm702__07.48.mcusw
   rm702__07.48.ppm_mh1
   rm702__07.48_006.image_mh1_ctv_in_9k4z2
  AUTO SELECTED DEAD USB FLASHING...
  1. Remove USB and Battery...
  2. Insert USB.
  3. Insert Battery. (Some phones boot automatically)
  4. Please Power on phone shortly...
  Infineon USB Boot: F00A1FB300020303010100FF
  Sending PBL...
  PBL Successfully Sent...
  Sending SBL...
  SBL Successfully Sent...
  Setting Transmission Speed Done...
  Flash Chip Manufacturer: Samsung Electronics Corp.
  Flash Boot Successful...
  Sections         : 04
  Current File    : rm702__07.48.mcusw
  Compile Name: rm702__07.48.mcusw_ebl_psi.fls
  Image Type   : Main Firmware
  Data Size       : 29363592 Bytes
  Sending Certificate Block
  FIRMWARE Certificate Block Sent Successfully...
   Processing Section 01 of 04
  FIRMWARE Erase Block: 0x40000000~0x4001FFFE
  Start Erasing...
  Erasing Please Wait...
  Block Erase Done...
  Preparing Data Blocks...
  Data Size: 131072 bytes
  Data Checksum: EE63
  Uploading Data Blocks to phone...
  Block Write Successful...
  FIRMWARE Data Blocks uploaded to phone...
   Processing Section 02 of 04
  FIRMWARE Erase Block: 0x40040000~0x4005FFFE
  Start Erasing...
  Block Erase Done...
  Data Checksum: 7AB2
   Processing Section 03 of 04
  FIRMWARE Erase Block: 0x40060000~0x4015FFFE
  Start Erasing...
  Block Erase Done...
  Data Size: 1048576 bytes
  Data Checksum: C893
   Processing Section 04 of 04
  FIRMWARE Erase Block: 0x40280000~0x41DBFFFE
  Start Erasing...
  Block Erase Done...
  Data Size: 28049408 bytes
  Data Checksum: 6FB2
  Data Verification Successful...
  Sections         : 01
  Current File    : rm702__07.48.ppm_mh1
  Compile Name: package_mh1.ppm_ebl_psi.fls
  Image Type   : PPM Image
  Data Size       : 5094828 Bytes
  PPM Certificate Block Sent Successfully...
   Processing Section 01 of 01
  PPM Erase Block: 0x41DC0000~0x424BFFFE
  Start Erasing...
  Block Erase Done...
  Data Size: 5091484 bytes
  Data Checksum: C19E
  PPM Data Blocks uploaded to phone...
  Sections         : 01
  Current File    : rm702__07.48_006.image_mh1_ctv_in_9k4z2
  Compile Name: package_mh1_ctv_in.image.fls
  Image Type   : CONTENT Package
  Data Size       : 14290192 Bytes
  CONTENT Certificate Block Sent Successfully...
  CONTENT Erase Block: 0x424C0000~0x43E1FFFE
  Start Erasing...
  Block Erase Done...
  Data Size: 14286848 bytes
  Data Checksum: C3B9
  CONTENT Data Blocks uploaded to phone...
  Total Flashing Time (Erase + Flashing) : 00:03:21
  (Booting time is NOT Included)
  Waiting for Phone to Start-Up..(Max 150 seconds)
  Scanning USB Ports...
               Basic Phone Information
  MCU Version: V 07.48 23-02-12 RM-702 (c) Nokia
  IMEI Plain : 12345610654321?
  IMEI Spare : A123456106543210
  IMEI SV    : 31234561065432115F
  Phone Model: K        C2-03
  Category   : Phone
  Phone Type : RM-702
              Extended Phone Information
  Product Serial Number: B28BF95AI
  Product Code         : 059K4Z2
  Module Code          : 0204579
  Basic Production Code: 059C0J7
  Long Production SN   : 0
  PPM SW Version       : V 07.48 23-02-12 RM-702 (c) Nokia             MH1
  MCU SW Version       : V 07.48 23-02-12 RM-702 (c) Nokia
  HW Version           : 2000
  RFIC Version         : Dummy RFIC version
  LCD Version          : TPO
  FWID Version         : kV 07.48 23-02-12 RM-702 (c) Nokia            V 07.48 23-02-12 RM-702 (c) Nokia             MH1 059K4Z2 001
  Content Pack Version : Content: ctv IN V 07.48 23-02-12 RM-702 (c) Nokia
  Bluetooth ID         : 00:02:5B:00:A5:A5
  CS Type              : GSM900, GSM1800
    ********** SIMLOCK INFO  **********
  CONFIG_DATA  : 0000000000000000
  PROFILE_BITS : 0000000000030000
  ASIC         : 11
  PROVIDER     : Unknown Provider
  Unable to read SP Data..
  SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
  SIMLOCK_TEST             : PASSED
  SECURITY_TEST           : PASSED
  SECURITY_CODE          : 885592555
  PHONE_MODE              : TEST
  Selected VPL File:
  RM702_059K4Z2_07.48_006.vpl
  Variant Details     : RM-702 VAR INDIA-MH1 IN CV CBLACK
  Software Version : 07.48
  Product Type       : RM-702
  Variant Version    : 006
  FACTORY SET TO : Full Factory Set
   FAILED
  FACTORY SET TO : User Data
   OK
  FACTORY SET TO : Leave Factory
   OK
  FACTORY SET TO : Service Center
   OK
  FACTORY SET TO : Software Upgrade
   OK
  FACTORY SET TO : Production Tune
   OK
  ERROR: Life timer Reset Failed
What to do?
Br,
Old 06-29-2012, 10:23   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Hi,
Try to flash with lower version files...
Old 06-29-2012, 10:25   #3 (permalink)
debsden's Avatar
Member: 466182
Sonork: 100.1604458
Originally Posted by ..::Angel::.. View Post
Hi,
Can Flash with v7.29 ?
Old 06-29-2012, 10:27   #4 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Yes you can flash
Br - srinibas
Old 06-29-2012, 10:34   #5 (permalink)
Member: 643472
Sonork: 100.96901
Hi,
Yes, if not solve - try some other files - more older version...
As this problem also comes from software, so first chk all the
possible way... Then you can go for hardware if its not solved
flashing.
Old 06-29-2012, 11:57   #6 (permalink)
debsden's Avatar
Member: 466182
Sonork: 100.1604458
Flashed with v7.29 and v6.98 but same problem.....
Is it a hardware problem ?
Log.....v7.29
   rm702__07.29.mcusw
   rm702__07.29.ppm_mh1
   rm702__07.29_004.image_mh1_ctv_in_9k4z2
  2. Insert USB.
  Sending PBL...
  Sending SBL...
  Sections         : 04
  Current File    : rm702__07.29.mcusw
  Compile Name: rm702__07.29.mcusw_ebl_psi.fls
  Start Erasing...
  Block Erase Done...
  Data Checksum: EE63
  Start Erasing...
  Block Erase Done...
  Data Checksum: 7AB2
  Start Erasing...
  Block Erase Done...
  Data Checksum: F0C6
  Start Erasing...
  Block Erase Done...
  Data Checksum: 6841
  Sections         : 01
  Current File    : rm702__07.29.ppm_mh1
  Data Size       : 5053612 Bytes
  Start Erasing...
  Block Erase Done...
  Data Size: 5050268 bytes
  Data Checksum: 3FC6
  Sections         : 01
  Current File    : rm702__07.29_004.image_mh1_ctv_in_9k4z2
  Data Size       : 14159120 Bytes
  Start Erasing...
  Block Erase Done...
  Data Size: 14155776 bytes
  Data Checksum: 57D5
  Total Flashing Time (Erase + Flashing) : 00:03:19
  MCU Version: V 07.29 29-11-11 RM-702 (c) Nokia
  IMEI SV    : 31234561065432109F
  Category   : Phone
  Phone Type : RM-702
  PPM SW Version       : V 07.29 29-11-11 RM-702 (c) Nokia             MH1
  MCU SW Version       : V 07.29 29-11-11 RM-702 (c) Nokia
  HW Version           : 2000
  LCD Version          : TPO
  FWID Version         : kV 07.29 29-11-11 RM-702 (c) Nokia            V 07.29 29-11-11 RM-702 (c) Nokia             MH1 059K4Z2 001
  Content Pack Version : Content: ctv IN V 07.29 29-11-11 RM-702 (c) Nokia
  ASIC         : 11
  SECURITY_CODE          : 12345
  PHONE_MODE              : TEST
  Selected VPL File:
   FAILED
   OK
   OK
   OK
   OK
   OK
Log......v6.98
 rm702__06.98.mcusw
 rm702__06.98.ppm_r
 rm702__06.98_003.image_r_ctv_cn_9l4t7
2. Insert USB.
Sending PBL...
Sending SBL...
Sections         : 04
Current File    : rm702__06.98.mcusw
Compile Name: rm702__06.98.mcusw_ebl_psi.fls
Start Erasing...
Block Erase Done...
Data Checksum: EE63
Start Erasing...
Block Erase Done...
Data Checksum: 7AB2
Start Erasing...
Block Erase Done...
Data Checksum: E0F1
Start Erasing...
Block Erase Done...
Data Checksum: C53F
Sections         : 01
Current File    : rm702__06.98.ppm_r
Compile Name: package_r.ppm_ebl_psi.fls
Data Size       : 5922884 Bytes
Start Erasing...
Block Erase Done...
Data Size: 5919540 bytes
Data Checksum: 5DBD
Sections         : 01
Current File    : rm702__06.98_003.image_r_ctv_cn_9l4t7
Compile Name: package_r_ctv_cn.image.fls
Data Size       : 12586256 Bytes
Start Erasing...
Block Erase Done...
Data Size: 12582912 bytes
Data Checksum: 944A
Total Flashing Time (Erase + Flashing) : 00:03:22
MCU Version: V 06.98 14-10-11 RM-702 (c) Nokia
IMEI SV    : 31234561065432107F
Category   : Phone
Phone Type : RM-702
PPM SW Version       : V 06.98 14-10-11 RM-702 (c) Nokia             R
MCU SW Version       : V 06.98 14-10-11 RM-702 (c) Nokia
HW Version           : 2000
LCD Version          : TPO
FWID Version         : iV 06.98 14-10-11 RM-702 (c) Nokia            V 06.98 14-10-11 RM-702 (c) Nokia             R 059K4Z2 001
Content Pack Version : Content: CTV CN V 06.98 14-10-11 RM-702 (c) Nokia
ASIC         : 11
PHONE_MODE              : TEST
 FAILED
 OK
 OK
 OK
 OK
 OK
And thnx to both of you for your support
Br,
Old 06-29-2012, 12:11   #7 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Yes it may b a hardware problem . . . .
You receive the set with Local mode or after flash it show Local mode ?
Post the original product code
Br - srinibas
Old 06-29-2012, 12:24   #8 (permalink)
debsden's Avatar
Member: 466182
Sonork: 100.1604458
Br - srinibas
Receive the set with Local mode.....
Original product code - 059K4Z2 (thats why 1st I've flashed with v7.48..same product code)
Old 06-29-2012, 12:36   #9 (permalink)
Member: 1240161
Sonork: 100.1613544
Try to do it with the highest version and set into normal mode by soft after flashing.
If it still persist.. then it must be hardware.
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 07-25-2000 00:51
Only MAX232 ??? AMIGO Nokia Hardware & Hardware-Repair Area 7 04-12-2000 09:41
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed spterminator Main Sales Section 0 08-08-1999 05:08
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
Page generated in 0.56313 seconds with 11 queries
