Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 02-13-2012, 17:52   #1 (permalink)
Member: 1285436
C2-03 white display
I have one NOKIA C2-03 RM-702 handset... Condition of the set was dead before.. Flashing Completed info all OK.. Bt now the condtion is white display.. Set will remain white for 5 sec and get switch off.. Here its the log
Number of Image Files: 3
Processing Image File :
rm702__07.29.mcusw
rm702__07.29.ppm_mh1
rm702__07.29_004.image_mh1_ctv_in_9k4z2
AUTO SELECTED DEAD USB FLASHING...
If Flashing DOES NOT Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Sections : 04
Current File : rm702__07.29.mcusw
Compile Name: rm702__07.29.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 29363592 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 04
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: EE63
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 04
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7AB2
Processing Section 03 of 04
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: F0C6
Processing Section 04 of 04
FIRMWARE Erase Block: 0x40280000~0x41DBFFFE
Start Erasing...
Block Erase Done...
Data Size: 28049408 bytes
Data Checksum: 6841
Data Verification Successful...
Sections : 01
Current File : rm702__07.29.ppm_mh1
Compile Name: package_mh1.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 5053612 Bytes
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x41DC0000~0x424BFFFE
Start Erasing...
Block Erase Done...
Data Size: 5050268 bytes
Data Checksum: 3FC6
PPM Data Blocks uploaded to phone...
Sections : 01
Current File : rm702__07.29_004.image_mh1_ctv_in_9k4z2
Compile Name: package_mh1_ctv_in.image.fls
Image Type : CONTENT Package
Data Size : 14159120 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x424C0000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 14155776 bytes
Data Checksum: 57D5
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:03:32
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Elapsed Time: 5 Seconds...
Elapsed Time: 10 Seconds...
Scanning USB Ports...
Basic Phone Information
MCU Version: V 07.29 29-11-11 RM-702 (c) Nokia
IMEI Plain : 359065045661949
IMEI Spare : A359065045661940
IMEI SV : 33590650456619409F
Phone Model: K C2-03
Category : Phone
Phone Type : RM-702
Extended Phone Information
Product Serial Number: D476CC0AI
Product Code : 059K4Z2
Module Code : 0204579
Basic Production Code: 059C0J7
Long Production SN : 0
PPM SW Version : V 07.29 29-11-11 RM-702 (c) Nokia MH1
BT MCM Version : 19b5-22012
MCU SW Version : V 07.29 29-11-11 RM-702 (c) Nokia
HW Version : 2000
RFIC Version : Dummy RFIC version
LCD Version : TPO
FWID Version : kV 07.29 29-11-11 RM-702 (c) Nokia V 07.29 29-11-11 RM-702 (c) Nokia MH1 059K4Z2 001
Content Pack Version : Content: ctv IN V 07.29 29-11-11 RM-702 (c) Nokia
Bluetooth ID : 281:AF:37:73E
CS Type : GSM900, GSM1800
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 800000000003000B
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SECURITY_CODE : 12345
PHONE_MODE : TEST
Dynamic Camera Configuration
DCC ID : 06150123
DCC Ver: 007025
Status : OK
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
PLs help
Old 02-14-2012, 09:35   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Hi,
It looks like hardware problem to me..
Old 02-15-2012, 06:12   #3 (permalink)
Member: 1285436
Hello Angel... Last tym also i got the same problem in X3-02 at that time when i change the touch screen it worked fine for me... This time i changed the LCD TOUCH and also strip... Complaint remains same.. Tried to heat usb section ... No luck
Old 04-28-2012, 14:39   #4 (permalink)
Member: 1238726
i have also white screen c2 please help
3390 v7.03 f_loader and partial flash needed Bads Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 03-17-2001 18:05
What "ID"enter for crack WinTesla 6.03 Baza Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 10-09-2000 12:55
Blue LEDs in your Display SUPER! GM Nokia Hardware & Hardware-Repair Area 0 06-25-2000 12:47
blue Display in Nokia Cellphones TheDon Nokia Hardware & Hardware-Repair Area 0 10-29-1999 18:28
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
Page generated in 0.24626 seconds with 11 queries
