08-21-2012, 09:48 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Bangladesh Age: 40
Member: 717313 Status: Offline Sonork: 100.1611706 Thanks Meter: 45 | C2-05 plz help how to solved ............... flashing log ..... Number of Image Files: 3 Processing Image File : rm724__08.69.mcusw Processing Image File : rm724__08.69.ppm_ge Processing Image File : rm724__08.69.image_ge_lgold_059J3F7 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Sections : 04 Current File : rm724__08.69.mcusw Compile Name: rm724__08.69.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26742152 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 04 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 8FA1 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 04 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7ADA Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 04 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 3379 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 of 04 FIRMWARE Erase Block: 0x40280000~0x41B3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 25427968 bytes Data Checksum: 6229 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Data Verification Successful... Sections : 01 Current File : rm724__08.69.ppm_ge Compile Name: package_ge.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4122908 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x41B40000~0x4223FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4119564 bytes Data Checksum: 503D Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Sections : 01 Current File : rm724__08.69.image_ge_lgold_059J3F7 Compile Name: package_ge_lgold_059J3F7.image.fls Image Type : CONTENT Package Data Size : 15863056 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x42240000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 15859712 bytes Data Checksum: 961A Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:03:35 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 08.69 17-04-12 RM-724 (c) Nokia IMEI Plain : 351674054820169 IMEI Spare : A351674054820160 IMEI SV : 33516740548201609F Phone Model: K C2-05 Category : Entry Phone Phone Type : RM-724 ================================================ Extended Phone Information ================================================ Product Serial Number: 72051F4AH Product Code : 059J898 Module Code : 0204806 Basic Production Code: 059D2P1 Long Production SN : 0 PPM SW Version : V 08.69 17-04-12 RM-724 (c) Nokia GE BT MCM Version : 19b5-22012 MCU SW Version : V 08.69 17-04-12 RM-724 (c) Nokia HW Version : 1000 RFIC Version : Dummy RFIC version LCD Version : TPO FWID Version : jV 08.69 17-04-12 RM-724 (c) Nokia V 08.69 17-04-12 RM-724 (c) Nokia GE 059J898 001 Content Pack Version : Content: ge_lgold_059J3F7 V 08.69 17-04-12 RM-724 (c) Nokia Bluetooth ID : 04:5A:95:84:B5:CC CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0000000000000000 PROFILE_BITS : 0000000000030000 ASIC : 11 PROVIDER : Unknown Provider Unable to read SP Data.. SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : FAILED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01022C00 DCC Ver: XXXXXX ERROR: DCC File Mismatched! Required DCC File: 01022C00 Write the correct DCC to Fix the Problem ================================================== ==== Selected VPL File: RM724_059G010_08.69_999.vpl ================================================== ==== Variant Details : RM-724 EURA AZ DGRAY LATIN AZ Software Version : 08.69 Product Type : RM-724 Product Code : 059G010 Variant Version : 999 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
08-21-2012, 11:04 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | @ rajibsaha Looks your mobile have full damaged the PM area , not possible as now . @ <<SAMRAT>> Wrong answer Br - srinibas |
08-22-2012, 05:45 | #5 (permalink) |
No Life Poster Join Date: Mar 2008 Location: india Age: 39
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | chek this link bro ....and us this method ....u r prob to solve....u r hpayy .... and post result http://forum.gsmhosting.com/vbb/f609...01/index3.html |
08-23-2012, 10:59 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @rajibsaha How did your phone's simlock was corrupted ??? If its after reset counters by other tool, then here is the solution: http://forum.gsmhosting.com/vbb/f609...hones-1497095/ In all other case, just Nokia RPL is the solution... if SIMLock are really damaged! BR |
MY-C2! any way to unlock this phone ? | infogsm | ARM9 BASED M62 / M62+ | 27 | 01-08-2004 00:37 |
Sagem MY-C2 Cables and Terminator Dongles >> | mobile-bits | Main Sales Section | 0 | 11-04-2003 01:56 |
Can you remove second c2 on z5 board and without any care more, just remove ? | DREAMGSM | Samsung Hardware Repair | 0 | 05-27-2003 11:20 |
C2.00.20 lp7 needed | Skoku | Motorola Old Legacy (EMMI) | 6 | 08-26-2002 12:49 |
f_loader for 8210 v 5.26 or C2 flash | greenapple | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 07-31-2001 02:25 |
