05-21-2011, 02:16 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | is this mother board is good for local brute force? plz check it and let me know then i will buy it Regards |
05-21-2011, 02:20 | #2 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Quote:
yes, for 1 Slide (two Card) no more b/r the_polack | |
05-21-2011, 02:45 | #4 (permalink) |
No Life Poster Join Date: Sep 2010 Location: philippines
Member: 1388679 Status: Offline Sonork: 1597516:GsmSolution Thanks Meter: 2,757 | GIGABYTE G1 assassin is good for bruteforce br |
The Following User Says Thank You to GsmSolution. For This Useful Post: |
05-21-2011, 03:05 | #5 (permalink) |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Best MoBo Model 890FXA-GD70 Brand MSI Model 890FXA-GD70 Supported CPU CPU Socket Type AM3 CPU Type Phenom II / Athlon II / Sempron 100 Series FSB 2600MHz Hyper Transport (5200 MT/s) Chipsets North Bridge AMD 890FX South Bridge AMD SB850 Memory Number of Memory Slots 4×240pin Memory Standard DDR3 2133 (O.C.)/1800 (O.C.)/1600 (O.C.)/1333/1066 Maximum Memory Supported 16GB Channel Supported Dual Channel Expansion Slots PCI Express 2.0 x16 4 PCI Express x4 1 PCI Express x1 1 PCI Slots 1 Storage Devices PATA 1 x ATA133 2 Dev. Max SATA 3Gb/s 1 SATA 6Gb/s 6 x SATA 6Gb/s SATA RAID SATA 6Gb/s: RAID 0/ 1/ 5/ 10 Onboard Video Onboard Video Chipset None Onboard Audio Audio Channels 8 Channels Onboard LAN LAN Chipset Realtek 8111DL Max LAN Speed Dual 10/100/1000Mbps Rear Panel Ports PS/2 2 USB 1.1/2.0 5 x USB 2.0 USB 3.0 2 x USB 3.0 eSATA 1 x eSATA 3Gb/s S/PDIF Out 1 x Optical, 1 x Coaxial Audio Ports 6 Ports Onboard USB Onboard USB 6 x USB 2.0 Onboard 1394 Onboard 1394 2x 1394a Physical Spec Form Factor ATX Dimensions 12.0" x 9.6" Power Pin 24 Pin b/r The_Polack |
The Following User Says Thank You to el-polaco For This Useful Post: |
05-21-2011, 05:23 | #6 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: colombia
Member: 576776 Status: Offline Thanks Meter: 133 | Quote:
The Following User Says Thank You to mauriciopineros For This Useful Post: |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
