Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-02-2014, 00:23   #1 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
C3-00 security code flash fail
Number of Image Files: 3
Processing Image File :
 rm614__07.20.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed    : 650000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 6500000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  528
Entry Point:  0x01F2
Page Format : -1
MAX PAGE : 0x0000E000
 rm614__07.20.ppm_s
CMT Type : BB5
Number of Blocks :  137
Entry Point:  0x0113
Page Format : -1
 rm614__07.20_001.image_s_ctv_my_9f9c3
CMT Type : BB5
Number of Blocks :  282
Entry Point:  0x0147
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 86  (0x56) bytes returned
Number of Sub Blocks 6 (0x06)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 17  (11)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000000
     ID DWORD    1 : 00000000
     ID DWORD    2 : 22000509
     ID DWORD    3 : 200C0000
  2  EM_ASIC_ID 02
     Block Length  : 5  (05)
     ID DWORD    0 : 00005361
  3  PUBLIC_ID 12
     Block Length  : 21  (15)
     ID DWORD    1 : 0000FF06
     ID DWORD    2 : E7B03583
     ID DWORD    3 : 838DBF6E
     ID DWORD    4 : D45AAAE5
  4  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  5  ROOT_KEY_HASH 14
     Hash          :  1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
  6  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : DE56D582
     CRC         1 : BDDE7A3A
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_usb2nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> Type not in database
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> Type not in database
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0030 -> Type not in database
   Revision ID       : 0431
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              : XSR 1.6
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   Size              : 08000000 (128 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_XSR16_usbalg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
 START READING RPL DATA
IMEI: 351935055110615
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
NPC CERTIFICATE INFORMATION (CMT):
IMEI           : 351935055110615
PRODUCT CODE   : 059F9C3
WLAN ID        : F4:8E:09:12:B4:39
BLUETOOTH ID   : F4:8E:09:10:DF:79
PUBLIC_ID      : 000000000000FF06E7B03583838DBF6ED45AAAE5
PAPUB_KEYS_HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\351935055110615\351935055110615_121831.rpl
PA PUBLIC KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
  PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index   : 00
CMT PAPUBKEYS HASH:
Reading : ISA-USER... OK!
PHONE FIRMWARE VERSION:
V 08.63 25-03-11 RM-614 (c) Nokia
Flash File Version: V 07.20 29-10-10 RM-614 (c) Nokia.0.0.0
Your Flash Files are OLD. You need firmware version
or NEWER. Please Download NEW FIRMWARE VERSION!!!
FlashInfo.RestartMode : Test Mode
Flashing Failed....
 Booting/Flashing Failed...
 Please Try Again...
Old 04-02-2014, 06:09   #2 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
i have check the log it the firmware i was flash with it a old version then i do high version as it show on log and it solve
 rm614__08.63.mcusw
CMT Type : BB5
Entry Point:  0x01F2
Page Format : -1
 rm614__08.63.ppm_tk
CMT Type : BB5
Number of Blocks :  105
Entry Point:  0x0113
Page Format : -1
 rm614__08.63_005.image_tk_voda_tr_9d166
CMT Type : BB5
Number of Blocks :  286
Entry Point:  0x0147
Page Format : -1
2. Insert USB.
BootFlashMode_DCT5
READING BOOTROM
  1  SYSTEM_ASIC_ID 01
  2  EM_ASIC_ID 02
  3  PUBLIC_ID 12
  4  ASIC_MODE_ID 13
     Mode Id       : 00
  5  ROOT_KEY_HASH 14
  6  ROM_ID 15
     CRC         0 : DE56D582
     CRC         1 : BDDE7A3A
 MessageID  : C1
 SubBlocks  : 06
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 01
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0431
   Block Length      : 09
   Data              : XSR 1.6
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
FUR control Ok
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\351935055110615\351935055110615_55646.rpl
    BB Asic Index   : 00
CMT PAPUBKEYS HASH:
ImagePath: C:\Users\Dot.Cell\Downloads\Compressed\navifirmplus_3.2\NaviFirm+\Fw\059D166\
ImageFilename: rm614__08.63.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
Certificate 5
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00010000
            Spare             : FFFFFFFF
            Num Partitions    : 00000004
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 00020000
            Partition    2
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 02A00000
            Partition    3
              Start Address   : 07540000
            Partition    4
              Start Address   : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200020000025E0000000000080000000102A0000004B400000000000A0000000107540000006000000000000B0000000107B40000001800000D
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0x90  (144)
ERASE Blocks :  0x03  (3)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x2B (43)
            Device Index     : 0x00
               0             : 00000000-0001FFFF
               1             : 00020000-000203FF
               2             : 00060000-012FFFFF
               3             : 01300000-01DFFFFF
               4             : 02600000-029FFFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x02000000
            Format Info      : 000000000000000A0000000100000002000000640000000200000002000000010000000000000000
     2   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000B0000000000000002000000640000000200000002000000010000000000000000
ERASE_REQUEST_BB5  : 5005120B000300000000000001FFFF120B00030000020000000203FF120B00030000060000012FFFFF120B0003000130000001DFFFFF120B00030002600000029FFFFF11
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A00000001000000020000006400000002000000020000000100000000000000003B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B00000000000000020000006400000002000000020000000100000000000000003B
Successfully Erased...
Total blocks to write : 528
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS [697F747788AD72E77DB3BC8DFEC0C28DA22F16D8]
>>  CMT Rootkey Hash CERT : UPDAPP
>>  CMT Rootkey Hash CERT : MCUSW
>>  CMT Rootkey Hash CERT : MCUSW1
>>  CMT Rootkey Hash CERT : GENIO_INIT
>>  CMT Rootkey Hash CERT : ISA+DYNSW
ImageFilename: rm614__08.63.ppm_tk
StartErase_DCT5...
BlockLength  :  0x0E  (14)
ERASE Blocks :  0x01  (1)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 01E00000-025FFFFF
ERASE_REQUEST_BB5  : 5001120B00030001E00000025FFFFF9E
Total blocks to write : 105
ImageFilename: rm614__08.63_005.image_tk_voda_tr_9d166
StartErase_DCT5...
BlockLength  :  0x3F  (63)
ERASE Blocks :  0x02  (2)
            Device Index     : 0x00
               0             : 02A00000-0753FFFF
            Device Index     : 0x00
            Format Info      : 00000000000000080000000000000002000000640000000200000002000000010000000000000000
ERASE_REQUEST_BB5  : 5001120B00030002A000000753FFFFE4
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000800000000000000020000006400000002000000020000000100000000000000003E
Total blocks to write : 286
ContinueFlash_DCT5 Complete
Continue Flash Complete :  : No Error - 0 (0x00)
STATUS_REQUEST_BB5...
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000002
          Additional Bad    :  00000002
          Correctable ECC   :  00000000
FlashInfo.RestartMode : 2
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:09
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
SW: V 08.63 25-03-11 RM-614 (c) Nokia
CONFIG KEY    :  0000000000000000
PROVIDER KEY  :  2440700000000000
NETWORK NAME  :  Nokia Default;Finland
LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
SIMLOCK TABLE :
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE :  Not Locked
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SUPER_DONGLE_TEST  : PASSED
SECURITY_CODE          : 665123
               SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
Old 04-02-2014, 18:04   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
@chris2007
Yup, ATF box will not allow if you flashing with lower version files/downgrading. Because result will be dead/nokia hang phone
Page generated in 0.18042 seconds with 8 queries
