Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 08-22-2012, 22:47   #1 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
C3 614 Problem / Cant Flash
I Cant Read Boot in This C3 614 ;(
UTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
ERROR: CANNOT READ BOOTROM
CMT Secondary Loader: C:\ATF\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_usb2nd.fg
Secondary Loader Sent....
ERROR: TRANSMISSION_TYPE_REQUEST_BB5 FAILED 0x00
TIPS:
1. Make Sure your Battery Power is Enough...
2. Make Sure Connectivity Drivers are installed...
3. DO NOT USE USB HUBS...
4. Use an ORIGINAL NOKIA CA-101D USB Cable...
Flashing Failed....
Booting/Flashing Failed...
Please Try Again...
Not a cable Problem.
This is Another C3 and no problem for flash
START READING RPL DATA
IMEI: 358608043346210
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
NPC CERTIFICATE INFORMATION (CMT):
IMEI : 385060834432601
PRODUCT CODE : 059D9P8
WLAN ID : 10:F9:EE:61:5D:69
BLUETOOTH ID : 10:F9:EE:61:1E:E2
PUBLIC_ID : 0000000000048CA975130097EECC0EDECFB04B6C
PAPUB_KEYS_HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
CCC CERTIFICATE INFORMATION (CMT):
HWC CERTIFICATE INFORMATION (CMT):
RPL Backup was Successful...
Plain RPL saved to:
C:\ATF\AdvanceBox Turbo Flasher\Nokia\Backup\358608043346210\3586080433462 10_063857.rpl
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
ImagePath: C:\Archivos de programa\Nokia\Phoenix\Products\RM-614\
ImageFilename: rm614__08.65.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
Certificate 5
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 00020000
Partition 2
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 02A00000
Partition 3
Start Address : 07540000
Partition 4
Start Address : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200020000025E0000000000080000000102A0000004B400 000000000A0000000107540000006000000000000B00000001 07B40000001800000D
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x90 (144)
ERASE Blocks : 0x03 (3)
0 ERASE_AREA_BB5 0x12
Block Length : 0x2B (43)
Device Index : 0x00
0 : 00000000-0001FFFF
1 : 00020000-000203FF
2 : 00060000-012FFFFF
3 : 01300000-01DFFFFF
4 : 02600000-029FFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B0003000002000000 0203FF120B00030000060000012FFFFF120B00030001300000 01DFFFFF120B00030002600000029FFFFF11
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
Successfully Erased...
Total blocks to write : 528
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS [697F747788AD72E77DB3BC8DFEC0C28DA22F16D8]
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : MCUSW1
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : ISA+DYNSW
ImageFilename: rm614__08.65.ppm_l
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01E00000-025FFFFF
ERASE_REQUEST_BB5 : 5001120B00030001E00000025FFFFF9E
Total blocks to write : 104
ImageFilename: rm614__08.65_009.image_l_claro_ca_golden_white_v2_ 9c1z4
StartErase_DCT5...
BlockLength : 0x3F (63)
ERASE Blocks : 0x02 (2)
Device Index : 0x00
0 : 02A00000-0753FFFF
Device Index : 0x00
Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5001120B00030002A000000753FFFFE4
FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
Total blocks to write : 242
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
STATUS_REQUEST_BB5...
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000000
Additional Bad : 00000000
Correctable ECC : 00000000
FlashInfo.RestartMode : 2
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:08
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
SW: V 08.65 12-05-11 RM-614 (c) Nokia
CONFIG KEY : 8000000000000000
PROVIDER KEY : 7223100000000000
NETWORK NAME : AMX MORROCO S.A;MORROCO [GSM]
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Close
Block [2] 1:Close
Block [3] 1:Close
SIMLOCK STATE : LOCKED
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
SUPER_DONGLE_TEST : PASSED
SECURITY_CODE : 12345
SL3 Phone detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
Old 08-23-2012, 02:43   #2 (permalink)
malka4u's Avatar
Member: 1626780
did you try with FBUS cable?
Old 08-23-2012, 08:44   #3 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
If one C3 working & another C3 not working then conclusion is cable & tool both OK.
What problem with your C3 , which one not booting
Br - srinibas
Old 08-23-2012, 10:15   #4 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
@el-polaco
If you can BUS Check/Backup RPL in USB Mode. Then Authorization should
also work, as its same. Try to Authorize Phone once again, make sure phone's
battery is charged enough, remove battery, insert after few seconds, press
Authorize Button, when process bar starts 1, 2, 3 .... here you insert USB cable
to POWERED OFF phone and let ATF SW do the rest ...
Old 08-23-2012, 10:16   #5 (permalink)
Member: 643472
Sonork: 100.96901
C3-00 RM-614 doesn't have FBUS cable.
Old 08-23-2012, 14:51   #6 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
C3 rm 614
Not Cable Problem, i have 2 c3, one is ok, but the Other cant boot/authorize.
Using same cable and same battery
maybe hardware problem.....you tell me what you mean
The Phone is comming totally Dead
thnks Angel
polaco
Old 08-23-2012, 15:06   #7 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
thnks Angel
polaco
We already answer you - C3 614 Problem / Cant Flash
Br - srinibas
Old 08-23-2012, 15:19   #8 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1587812
@el-polaco
BRO TELL US ABOUT UR SET WITCH ONE IS NOW DEAD HOW BECOME DEAD...
IN FLASHING ????
BRO
Old 08-23-2012, 15:20   #9 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
Br - srinibas
this link to make a Loop, You taught to The_Laser ? Not helps....
C3 614 Back To customer for Hardware Problem.. (the Phone Have a big Crash) never Power On
With The same cable. i read Yesterday this ASHA Post here all successfuly flashed, unlocked and repaired phones with ATF software.
Best regards
polaco
Old 08-23-2012, 15:31   #10 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Best regards
polaco
I think you have English understanding problem ? How told you the cable problem ?
A new born baby of this field know where problem . particular set have hardware problem .
In my 1st reply i have clear that . but you not try to understand & argue in same point
srinibas
Old 08-23-2012, 15:54   #11 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
srinibas
I was struck by your way to see a Link (Looping thread) seems ironic. -
Yes, My English is Horrible but I see users who write worse than me , Not if I look like a baby. (41 years old
Please close this Thread, is hardware problem.
ATF Work Perfect......
And Cable too
The_Polack
Old 08-23-2012, 15:59   #12 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
The_Polack
Relay need to close the thread
The Following User Says Thank You to srinibas For This Useful Post:
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-16-1999 00:44
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.38475 seconds with 11 queries
