Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 07-14-2012, 18:04   #1 (permalink)
Member: 984102
C5.00 just vibrate need solution?
i just backed up the certificate with HWK but not the PM so plz is there any way to alive the phone again other than the RPL?
here is the log with MXBOX
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID:
2526F511
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver:
1.1]
CMT EM0 ID:
00000C35
CMT EM1 ID:
00000C30
CMT PUBLIC ID:
0AF000144ADC0344E3B947CCD12E3E460EA31B53
CMT ASIC MODE ID:
00
CMT ROOT KEY HASH:
916F75217F32081248B15C38DFC8E81B
CMT ROM ID:
E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType:
NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:
CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:
CMT
Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:
CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:
CMT
Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:
CMT
Suggested algorithm:
XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
2526F511
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS is blank/erased.
Original Imei:
35903904963278
Original Product code:
059F0V7
Bluetooth ID:
9CCAD9480976
SIMLOCK PA identifier:
[0]
PA_SIMLOC30
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C5-00 USB Phonet, PORT_ID:
1A819FB9
Verifying communication to device OK.
Phone type:
RM-645 (Nokia C5-00)
SW version:
V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia
ApeCoreSw:
071.005
Imei plain:
12345610654321-?
Battery voltage: 3628 mV, current:
113 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
Old 07-14-2012, 19:18   #2 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1587812
@kal jan
bro its not the HWK r MX-key section go to write section and post there its will be better..
f u have Atf box post here the ATF logs then we will check.
bro
The Following User Says Thank You to gsm_new1 For This Useful Post:
Old 07-15-2012, 07:13   #3 (permalink)
debeliamark's Avatar
Member: 4627
Sonork: 57528:debeliamark
Originally Posted by kal jan View Post
Imei plain: [/SIZE]12345610654321-?
113 mA
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
After this that is shown above solution is only RPL service ... if you haven't CRT and Simlock backups
The Following User Says Thank You to debeliamark For This Useful Post:
Old 07-15-2012, 10:08   #4 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
@kal jan
Next time if you get any RAPU phone with "vibrate problem"
try to Read Full Flash first, after you can do erase flash. So,
if simlocks are alive inside, we could repair it without to buy
new RPL file.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
needed pinout for carkit(N61xx) mobileinfo Nokia Hardware & Hardware-Repair Area 1 12-27-2006 10:20
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.29531 seconds with 11 queries
