10-06-2011, 20:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Inside Technology
Member: 725443 Status: Offline Sonork: 100.1601305 Thanks Meter: 330 | C5-00 phone startup failed - (Solution Inside) MCU Version: V ICPR82_10w18.5.2 16-07-10 RM-645 (c) Nokia IMEI Plain : 12345610654321? IMEI Spare : A123456106543210 IMEI SV : 31234561065432111F Phone Model: Nokia C5-00 Product Serial Number: 0 Default SN Type : 0 PPM Version : V ICPR82_10w18.5.2 16-07-10 RM-645 (c) Nokia RFIC Version : |Vapaus_6.5 | Mikki_1.1 DSP Version : ICPR82_10w18.5.1 AHNE Version : 11 APE SW Core Version : 032.010 APE Variant Version : 032.010032.010.01.01032.010.C00.01 APE Test Version : rm645_ENO_v_0.ncp71_17_001 Retu Version : 35 Tahvo Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** Unable to read SP Data.. SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 PHONE_MODE : TEST MODE but when read rpl : START READING RPL DATA Reading : NPC (CMT) OK Reading : VARIANT (CMT) VARIANT : Empty Reading : CCC (CMT) OK Reading : HWC (CMT) OK Reading : R&D (CMT) OK Reading : PARTNERC (CMT) PARTNERC : Empty Reading : MDM_KEYS (CMT) MDM_KEYS : Empty FINISHED READING RPL DATA RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\357006046809147\357006046809147_10311.rpl FlashInfo.RestartMode : 2 (and there is npc data in rpl file but when scan phone it shows IMEI as 12345610654321?) I only flashed the phone with 32.010 version file by usb and nothing, but whats wrong? what to do? |
10-06-2011, 20:34 | #2 (permalink) |
Member: 725443 Status: Offline Sonork: 100.1601305 Thanks Meter: 330 | here is npc [CERT_PROG_DATA_OUT_CMT] NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303539463057334300000000 NPC_DATA_2=00000000000000000000000013080298D480414 E180D0200646F72420000000027300119A6DA0344 NPC_DATA_3=4737A00B21DC1A268BBC12C35F18D62F8F3D105 EEFB6633F44614F8C6DCCA7E8F247B26556A3E623 NPC_DATA_4=90E705EE474C64175F2EC4D0000000000000000 000000000000000000200000047534D0000000000 NPC_DATA_5=3375000664081974FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=F240A12AA804000000000000000000000000000 0000000000000000000000000125919ACE8FFE11A NPC_DATA_7=7B8BE98A31C15B7BD52F2EBA4B844E7A75F8DCF 2DC6996C18D65CAF0FE01A58057430712C0E6A2A8 NPC_DATA_8=C21025043132D2DC200148197B073AE1077EBEF B17709F901CD4BF691695CDD10E1A2CC7CFACED54 NPC_DATA_9=AAC691248EED0FC67EAE621B0E6AEDA2314E343 0EB172732250A3CE4E06A319D5F76F0CFB7BA894E |
10-07-2011, 01:22 | #3 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brazil Age: 41
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | follow up the tab and rewrite the IMEI RPL saved (C: \ AdvanceBox Turbo Flasher \ Nokia \ backup). Advence The Turbo Flash creates a folder with the IMEI number of your device and puts it all inside beckup's! (look at the IMEI of your phone on the label and write the rpl correct). Then go PM tab and select write pm and select the file you have (but not locked or something) and rewrite it too! Test the device and see that this 100% PS: if you need to write a standalone pm or by selecting clicking sx4 server, correct the SuperDongle! sorry my bad english! |
10-07-2011, 04:53 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @mmrozibul Your Phone is RM-745, C5-00.2... That is why you are getting BAD IMEI and BAD SIMLOCKS because you flashed it with C5-00 RM-645... So just download firmware 071.003 for RM-745 C5-00.2 and flash it to your phone :O) Download Navifirm Here: http://www.symbian-toys.com/navifirm.aspx#download Select it on ATF Software like this: B.R> Last edited by Advance-Box; 10-07-2011 at 05:05. |
The Following 5 Users Say Thank You to Advance-Box For This Useful Post: |
10-07-2011, 05:13 | #7 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
The trick is to Extract Original Product code from RPL Backup (NPC)... Take the HEX and put it into a HEX editor to expose the ASCII equivalent.. Then search the ASCII Equivalent in Naivifirm... Like this: | |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
10-07-2011, 07:13 | #10 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Chittagong, Bangladesh Age: 40
Member: 866650 Status: Offline Sonork: mdsalimkhan_05 Thanks Meter: 147 | Quote:
10-08-2011, 00:39 | #12 (permalink) |
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | that goes for all models of Nokia or bb5 (sl1/sl2/sl3 be independent? it helps a lot especially in the form of knowledge! Although I will be part of your support team! |
10-08-2011, 12:57 | #14 (permalink) |
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | windows7 and have the computer, when you open the NPC with the notepad he has converted the same time without the need for extra programs! but what difference do the flash with original product code and make flash with a different product code? what exactly does that mean? never understood right! |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
