08-27-2012, 07:43 | #1 (permalink) |
Crazy Poster Join Date: Jan 2011 Location: Edmonton/AB. CANADA Age: 37
Member: 1493721 Status: Offline Thanks Meter: 8 | C5-06 problem now again i flashed with RM-816 it only virates that's it any help please |
08-27-2012, 08:37 | #2 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
B4 flashing what was the mobile condition ? Have you backup the RPL & PM B4 flashing ?? Flashing LOG ??? Br - srinibas | |
08-27-2012, 09:24 | #3 (permalink) | |
Member: 1493721 Status: Offline Thanks Meter: 8 | mobile condition was working perfectly just wanted to change language to Chinese just mistakenly flashed nokia C5-06 with C5-05 now the condition is only Vibrates i just saved RPL can i erase and flash it back if i have RPL backup ? and can i erase it with USB cable or i need FBus ? Quote:
08-27-2012, 10:05 | #4 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | You cant erase without PM backup Now 1sr read the Full flash dump 2nd try to recover the PM from Level 2 after authorize . Post result Br - srinibas |
08-27-2012, 10:26 | #5 (permalink) | |
Member: 1493721 Status: Offline Thanks Meter: 8 | Quote:
now i don't know how to recover pm from it can you please do me another fav and tell me how to do it ? Code: BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001060 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 2C700104 ID DWORD 1 : A70A5940 ID DWORD 2 : E7F3EB8D ID DWORD 3 : 2B87702C ID DWORD 4 : 666AD08C 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : DA 55 0B 5B AA B5 17 40 90 88 A3 E4 F3 EB 53 AC 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPUv11_2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0040 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0241 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0040 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 10000000 (256 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPUv11_XSR17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: FCA5CA3CB2B6BE0DD4FAD6075AFCBB8D7972103C Dumping Flash Chip 256 MB FlashInfo.RestartMode : Test Mode Total Time: 00:05:39 | |
08-27-2012, 14:46 | #8 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @NAS33R Here written all about SL3 SIMLock recovery: http://forum.gsmhosting.com/vbb/f609...79/index2.html BR |
08-28-2012, 09:23 | #9 (permalink) |
Member: 1493721 Status: Offline Thanks Meter: 8 | Is this the file i need ? i've just recovered it from phone urgent reply Code: Dumping PMM Partition FlashInfo.RestartMode : Test Mode ======================================================= ATF SL3 Simlock Recovery Module v1.0 ======================================================= STATUS: Mounting Flash Dump... STATUS: PMM Storage Found at 0x0007E000 STATUS: Defragmenting XSR3 Blocks REPORT: XSR3 Fragmentation Level is LOW REPORT: Defragmentation will take a few SECONDS! STATUS: XSR3 Defragmention Done STATUS: Saving Simlock Data to File... C:\AdvanceBox Turbo Flasher\Nokia\Backup\358295041179148\358295041179148_RECOVERED_EB7E0C89.pm REPORT: Total Elapsed Time 00:00:36 |
08-29-2012, 12:31 | #12 (permalink) | |
Member: 1493721 Status: Offline Thanks Meter: 8 | here is the log i wrote the RPL Quote:
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
