Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-25-2014, 17:03   #1 (permalink)
Registered User
Member: 759011
Sonork: 164643 (server.sonork.com
Thanks Meter: 152
Exclamation c5 phone startup failed
Unable to read SP Data..
SECURITY_TEST : PASSED
CMLA_KEY : PASSED
SUPER_DONGLE_TEST : PASSED
SL1/SL2 Phone detected
PHONE_MODE : TEST
DCC ID : NOT USED
Changing Phone Mode...
(Wait for 10 seconds)
Successfully set to : Normal
Old 04-25-2014, 17:06   #2 (permalink)
Registered User
Member: 759011
Thanks Meter: 152
MCU Version: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia
IMEI Plain : 359345038020257
IMEI Spare : A359345038020250
IMEI SV : 33593450380202515F
Phone Model: Nokia C5-00
Category : Classic Phone
Phone Type : RM-645
SX4 Custom Keys Stand Alone Edition
>>> : SX4 Auth Successfull
Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\PM Files\SX4\RM-645.pm
Start Uploading PM...
Field : 1 Sub : 0 Byte(s): 116 - Ok
Field : 1 Sub : 2 Byte(s): 12 - Ok
Field : 1 Sub : 4 Byte(s): 112 - Ok
Field : 1 Sub : 6 Byte(s): 12 - Ok
Field : 1 Sub : 7 Byte(s): 216 - Ok
Field : 1 Sub : 8 Byte(s): 112 - Ok
Field : 1 Sub : 13 Byte(s): 12 - Ok
Field : 1 Sub : 16 Byte(s): 208 - Ok
Field : 1 Sub : 18 Byte(s): 208 - Ok
Field : 1 Sub : 20 Byte(s): 208 - Ok
Field : 1 Sub : 22 Byte(s): 16 - Ok
Field : 1 Sub : 23 Byte(s): 4 - Ok
Field : 1 Sub : 24 Byte(s): 84 - Ok
Field : 1 Sub : 26 Byte(s): 112 - Ok
Field : 1 Sub : 28 Byte(s): 12 - Ok
Field : 1 Sub : 29 Byte(s): 12 - Ok
Field : 1 Sub : 31 Byte(s): 208 - Ok
Field : 1 Sub : 33 Byte(s): 36 - Ok
Field : 1 Sub : 34 Byte(s): 376 - Ok
Field : 1 Sub : 35 Byte(s): 16 - Ok
Field : 1 Sub : 39 Byte(s): 36 - Ok
Field : 1 Sub : 40 Byte(s): 16 - Ok
Field : 1 Sub : 41 Byte(s): 184 - Ok
Field : 1 Sub : 42 Byte(s): 4 - Ok
Field : 1 Sub : 43 Byte(s): 36 - Ok
Field : 1 Sub : 44 Byte(s): 184 - Ok
Field : 1 Sub : 45 Byte(s): 184 - Ok
Field : 309 Sub : 0 Byte(s): 4 - Ok
Field : 309 Sub : 1 Byte(s): 4 - Ok
Field : 309 Sub : 2 Byte(s): 12 - Ok
Field : 309 Sub : 3 Byte(s): 36 - Ok
Field : 309 Sub : 4 Byte(s): 12 - Ok
Field : 309 Sub : 7 Byte(s): 12 - Ok
Field : 309 Sub : 17 Byte(s): 12 - Ok
PM Upload Done!...
Old 04-25-2014, 17:07   #3 (permalink)
Registered User
Member: 759011
Thanks Meter: 152
CMT PAPUBKEYS HASH:
D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057
PHONE FIRMWARE VERSION:
Reading NPC IMEI...
359345038020257
Connecting to The ATF Network
Network Connection Accepted
Requesting Authorization Code
Authorization Code Received
Verifying Authorization Code
Authorization Code is OK
Saving RSA Modulus
Saving Authorization Code
File Saving Complete!!!
Old 04-25-2014, 17:09   #4 (permalink)
Registered User
Member: 759011
Thanks Meter: 152
Phone Type : RM-645
Super Dongle RPL Stand Alone Edition
Generating Super Dongle RPL...
Sending Superdongle RPL...
OK: Super Dongle RPL Accepted
Successfully done.
CMLA_KEY : PASSED
PHONE_MODE : TEST
DCC ID : NOT USED
HOW TO SALOVE THIS PROBLEM
Old 04-25-2014, 18:57   #5 (permalink)
Automatico's Avatar
Member: 2140790
Sonork: 100.1679059
Thanks Meter: 212
How to solve this error?
With a bkp (Simlock) maked b4 flash process, write simlock and all will be ok
Is a SL3 Phone. Not Sl1/2 Write 120-308 pm saved) thats all
ciao
auto
Old 04-26-2014, 20:25   #6 (permalink)
Registered User
Member: 759011
Thanks Meter: 152
Write 120-308 r u 100% successful ?
and need 120-308 pm
Old 04-27-2014, 02:07   #7 (permalink)
Automatico's Avatar
Member: 2140790
Sonork: 100.1679059
Thanks Meter: 212
and need 120-308 pm
You need original PM (saved) or full rpl
No other solution
ciao
auto
Old 04-27-2014, 12:14   #8 (permalink)
Member: 1354113
Thanks Meter: 669
c5 start up faild
i think it is file system problem, try to format file system. post reply
Page generated in 0.21415 seconds with 8 queries
