Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 08-10-2012, 17:34   #1 (permalink)
Crazy Poster
Member: 1248940
Thanks Meter: 7
c6-01 rm-612 "phone start up failed" "contact the retailer"
is there solution for this model?
Old 08-10-2012, 20:04   #2 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
post here the logs with logs we can't help u...
Bro
Old 08-10-2012, 22:18   #3 (permalink)
Crazy Poster
Member: 1248940
Thanks Meter: 7
phone was water damaged. only flash in dead mode.
 Number of Image Files: 5
Processing Image File :
 RM-612_40.0.021_prd.core.C00
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed    : 650000Hz
Algorithm Sending Speed    : 13000000Hz
Program Sending Speed      : 13000000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  489
Entry Point:  0x2AC269
Page Format : -1
MAX PAGE : 0x00040000
 RM-612_40.0.021.218.01.rofs3.fpsx
CMT Type : BB5
Number of Blocks :  5
Entry Point:  0x00FF
Page Format : -1
MAX PAGE : 0x00003000
 RM-612_40.0.021_prd.rofs2.V01
CMT Type : BB5
Number of Blocks :  131
Entry Point:  0x00FF
Page Format : -1
 RM-612_40.0.021_uda_1_001.uda.fpsx
CMT Type : BB5
Number of Blocks :  237
Entry Point:  0x00FF
Page Format : -1
 RM612_APE_ONLY_ENO_10w49_v0.018.fpsx
CMT Type : BB5
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 6500000Hz
Number of Blocks :  15
Entry Point:  0x0138
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010006
     ID DWORD    3 : 400C1921
     ID DWORD    4 : 01051103
  2  EM_ASIC_ID 02
     Block Length  : 5  (05)
     ID DWORD    0 : 00000296
  3  EM_ASIC_ID 02
     ID DWORD    0 : 00000B22
  4  PUBLIC_ID 12
     ID DWORD    0 : 15700106
     ID DWORD    1 : 7C2B0252
     ID DWORD    2 : EE664DF3
     ID DWORD    3 : C2518260
     ID DWORD    4 : 8D0B8192
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 4B9B7510
     CRC         1 : 3E691FF8
CMT Secondary Loader: C:\Program Files\Advance Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPIDOv11_2nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> Type not in database
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 0400 -> Flash
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> Type not in database
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0050 -> Type not in database
   Revision ID       : 0031
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              :
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Flash Descriptor
   Device ID         : 0050
   Revision ID       : 0000
   Size              : 20000000 (512 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
CMT Algorithm Loader: C:\Program Files\Advance Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPIDOv11_XSR15_alg.fg
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
SendCodeStart_NewProtocol
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 54 04 01 00 00 00 A5
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
   PAPUB_KEYS_HASH_RESP_BB5 2A
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
 505A5C85580A6322C103BFE4E67B73EF478E791C
 START READING RPL DATA
IMEI: 354839048057718
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... EMPTY
RPL Backup was Successful...
 Plain RPL saved to:
 C:\Program Files\Advance Turbo Flasher\AdvanceBox Turbo Flasher\Nokia\Backup\354839048057718\354839048057718_220514.rpl
ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-612\
ImageFilename: RM-612_40.0.021_prd.core.C00
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00010000
            Spare             : FFFFFFFF
            Num Partitions    : 00000004
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 00080000
            Partition    2
              ID              : 00000004  DEMANDONOS
              Start Address   : 01A20000
            Partition    3
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 0D3C0000
            Partition    4
              Start Address   : 1F140000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200080000019A0000000000040000000201A200000B98000000000008000000010D3C000011BC00000000000A000000011F140000003C0000EF
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0x57  (87)
ERASE Blocks :  0x02  (2)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x23 (35)
            Device Index     : 0x00
               0             : 00040000-00082FFF
               1             : 00083400-003FFFFF
               2             : 00800000-00D5FFFF
               3             : 00D60000-0D39FFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x02000000
            Format Info      : 000000000000000A0000000000000002000000640000000B00000002000000010000000000000000
ERASE_REQUEST_BB5  : 5004120B0003000004000000082FFF120B00030000083400003FFFFF120B0003000080000000D5FFFF120B00030000D600000D39FFFF5B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A0000000000000002000000640000000B0000000200000001000000000000000033
Successfully Erased...
Total blocks to write : 489
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : SOS*UPDAPP
>>  CMT Rootkey Hash CERT : SOS*DSP0
>>  CMT Rootkey Hash CERT : SOS*ISASW
>>  CMT Rootkey Hash CERT : SOS+CORE
>>  CMT Rootkey Hash CERT : SOS+ROFS1
ImageFilename: RM-612_40.0.021.218.01.rofs3.fpsx
StartErase_DCT5...
BlockLength  :  0x0E  (14)
ERASE Blocks :  0x01  (1)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 0C4A0000-0D39FFFF
ERASE_REQUEST_BB5  : 5001120B0003000C4A00000D39FFFF44
Total blocks to write : 5
>>  CMT Rootkey Hash CERT : SOS+ROFS3
ImageFilename: RM-612_40.0.021_prd.rofs2.V01
StartErase_DCT5...
            Device Index     : 0x00
               0             : 094A0000-0C49FFFF
ERASE_REQUEST_BB5  : 5001120B000300094A00000C49FFFF38
Total blocks to write : 131
>>  CMT Rootkey Hash CERT : SOS+ROFS2
ImageFilename: RM-612_40.0.021_uda_1_001.uda.fpsx
StartErase_DCT5...
            Device Index     : 0x00
               0             : 0D3C0000-1EF7FFFF
ERASE_REQUEST_BB5  : 5001120B0003000D3C00001EF7FFFF82
Total blocks to write : 237
ImageFilename: RM612_APE_ONLY_ENO_10w49_v0.018.fpsx
StartErase_DCT5...
BlockLength  :  0x10  (16)
     0   ERASE_AREA_BB5 0x13
            Block Length     : 0x0D (13)
ERASE_REQUEST_BB5  : 5001130D00534F532A454E4F0000000000DD
Total blocks to write : 15
>>  CMT Rootkey Hash CERT : SOS*ENO
ContinueFlash_DCT5 Complete
Continue Flash Complete :  : No Error - 0 (0x00)
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  05
          Device Type       :  0F
          Num Bad Blocks    :  0000000A
          Additional Bad    :  0000FFFF
          Correctable ECC   :  0000FFFF
FlashInfo.RestartMode : 1
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:04:40
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Old 08-10-2012, 22:37   #4 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
@exploding_cow
Download the latest verion and flash it again...
http://forum.gsmhosting.com/vbb/8607686-post8.html
bro
DOES THE CELLNET DIGA HACK STILL WORK??? SP UNLOCKER 2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-04-1999 13:55
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? MyKe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-26-1999 14:31
Ringtones from the charts and new Links GM GSM Mobile Links 0 09-26-1999 13:54
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.20464 seconds with 9 queries
