12-02-2012, 20:47 | #7 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
1. Use ATF 9.20 or Newer. 2. Update Important Files. 3. Select Infineon inf Phone Selection Tab 4. Select correct Phone Type C2-05 RM-725 5. Click Buscheck to check connection. 6. Perform XGOLD Decrypt PM 120 | |
12-02-2012, 21:25 | #8 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Quote:
What about with 1616 via Fbus? Solved i cant read for lbf Ok. 1616 Not support for LBF...(Low Gamma) Only Xgold 213 polaco Last edited by el-polaco; 12-02-2012 at 21:32. Reason: Edited for Lbf | |
12-08-2012, 00:47 | #10 (permalink) |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | full flash 1616 done by ATF Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Archivos de programa\Nokia\Phoenix\Products\RH-126\rh126_005.800 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 2162688 bytes Data Checksum: 822C Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1783808 bytes Data Checksum: 5F10 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 64 bytes Data Checksum: 0000 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Archivos de programa\Nokia\Phoenix\Products\RH-126\rh126_005.80ub PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00210000~0x003D5D7E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1858944 bytes Data Checksum: E268 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Archivos de programa\Nokia\Phoenix\Products\RH-126\rh1260_nai05.80ub CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00EB0000~0x00F003BE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 328640 bytes Data Checksum: 1C8F Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:02:19 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 05.80 08-06-10 RH-126 (c) Nokia IMEI: 012821000873237 Product Serial Number: GGY595978 Product Code : 059C1R3 Module Code : 0204344 Basic Production Code: 059C7B9 PPM SW Version : V 05.80 08-06-10 RH-126 (c) Nokia UB ADSP Version : p V 05.80\n08-06-10\nRH-126\n(c) NMP\nub MCU SW Version : V 05.80 08-06-10 RH-126 (c) Nokia HW Version : 4003 UEM Version : 1328 UPP Version : 8850 LCD Version : WIN:BOHAIv94 NT39121 ********** SIMLOCK INFO ********** CONFIG_DATA : 7223100000000000 PROFILE_BITS : 800000000003000B ASIC : 11 PROVIDER : AMX Argentina S.A;Argentina [GSM] Block [1] 1:Close Block [2] 1:Close Block [3] 1:Close ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Br Polaco |
