12-05-2013, 16:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: 46000
Member: 197566 Status: Offline Thanks Meter: 89 | Can`t unlock lumia 510 - (SOLVED) JTAG Interface Connected, S/N 0xBA6C96C0 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 26.11.2013 10:47:00 ================================================== ======== Phone Type : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...Timeout During Operation! I all do for instruction. 10 times checked wires |
12-06-2013, 05:23 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | First of all, did you follow this? Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...Timeout During Operation! SO it means USB Cable MUST BE DISCONNECTED First... Then Connect After. If you followed it, then maybe you are using wrong TP PInout? Show me picture of your TP Soldering. If TP is OK and correct, then problems should be solved using this V2 File. http://174.120.45.27/tmp/610_610C_51..._UNLOCK_V2.rar Use this instead. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
12-06-2013, 13:53 | #3 (permalink) |
Member: 197566 Status: Offline Thanks Meter: 89 | http://174.120.45.27/tmp/610_610C_51..._UNLOCK_V2.rar this file help me. Phone unlock done. Thanks. |
