Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 06-08-2011, 14:11   #1 (permalink)
LEENO's Avatar
Member: 38084
Cant flash fbus
Now i received atf, is first time i use it.
I cant flash 5228 rm-625
im using ufc
I think is a cable problem, can i modify cable for working with atf?
BUS CHECK:
VBATT OFF...
VBATT ON
Setting VBATT Done!...
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 400C1921
ID DWORD 4 : 01051105
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00000296
3 ROM_ID 15
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 12C00018
ID DWORD 1 : 0DA30052
ID DWORD 2 : 9E8D91E8
ID DWORD 3 : 8239D54A
ID DWORD 4 : F365D8FD
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : B8 C3 AD EC FC 99 7F CD 80 81 D3 DE AF 87 0B 8C
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 8A
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
Boot File - Version 010.050.00
Boot File - Revision 0x0002 (2)
eBB5ProtocolType == New
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : 06
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0400 -> Flash
Device ID : 0000 -> Type not in database
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0040 -> KAT00F00RA
Revision ID : 0231
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data : XSR 1.5
Checksum : 14
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0231
Flash Descriptor
Device ID : 0040
Revision ID : 0000
Size : 10000000 (256 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g
Algorithm File - Version 010.050.00
Algorithm File - Revision 0x0002 (2)
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
7DC72D3FDC552426A4479BC820097D304CFB6C15
Scanning Simlock Applet Type...
OK
PA_SIMLOC30 Applet detected
Use "Scan Phone" Button to Check if this Phone
uses a 15-digit NCK or a 20-digit NCK...
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FlashInfo.RestartMode : 2
FLASHING:
ATF Software Version v7.40
ATF Lightning FBUS Flash Started...
Number of Image Files: 4
Processing Image File : L:\500GB\FLASH NOKIA\Products\RM-625\RM-625_40.1.003_prd.core.C00
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed : 650000Hz
Algorithm Sending Speed : 13000000Hz
Program Sending Speed : 13000000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 403
Entry Point: 0x289C52
Page Format : -1
MAX PAGE : 0x00040000
CMT Type : BB5
Page Format : -1
Changing MODE : FLASH
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 8A
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0231
Block Length : 09
Data : XSR 1.5
Checksum : 14
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0040
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CRITICAL ERROR ... ALGORITHM LOADER NOT FOUND
SendAlgoCodeFile_DCT5 : Error
Try TO UNPLUG RJ45 AND TRY AGAIN
Operations Failed....
Old 06-08-2011, 14:16   #2 (permalink)
LEENO's Avatar
Member: 38084
The same with 7.50
ATF Software Version v7.50
CMT Type : BB5
Page Format : -1
VBATT OFF...
VBATT ON
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 8A
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0231
Block Length : 09
Data : XSR 1.5
Checksum : 14
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0040
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Old 06-08-2011, 20:16   #3 (permalink)
Member: 171973
Sonork: 100.1601062
hi :
as i posted before i have same problem with 6700s also i change flashing speed
to normal but problem not solved.
br saeed azimi
Old 06-08-2011, 21:12   #4 (permalink)
LEENO's Avatar
Member: 38084
please how modify cable?
It is working with hwk and mxkey but not work with atf and mtbox
Old 06-08-2011, 21:18   #5 (permalink)
LEENO's Avatar
Member: 38084
it is sl3
if i buy credits, can i repair this phone?
MCU: V ICPR72_10w42.2 26-11-10 RM-625 (c) Nokia
IMEI: 3527150xxxxxxxxxxxx
Model : Nokia 5233
Product Serial Number: 0
Default SN Type : 0
PPM Version : V ICPR72_10w42.2 26-11-10 RM-625 (c) Nokia
RFIC Version : 17141716
DSP Version : ICPR72_10w33
AHNE Version : 11
APE SW Core Version : V 40.1.003
APE Variant Version : V 40.1.003
APE Test Version : eno_version
Retu Version : 16
Tahvo Version : 22
APE HW Version : 256
APE ADSP SW Version : 256
******** Reading SimLock ********
Unable to read SP Data..
IMEI: 352715047525099
Model : Nokia 5233
Default SN Type : 0
AHNE Version : 11
Retu Version : 16
Tahvo Version : 22
SECURITY_TEST : PASSED
PHONE_MODE : LOCAL MODE
BOOTING BB5 Phone...
TIME STARTS HERE
CMT Hardware : 400C192101051105
CMT PUBLIC ID : 12C000180DA300529E8D91E88239D54AF365D8FD
CMT ROOTHASH : B8C3ADECFC997FCD8081D3DEAF870B8C
CMT ROM_ID : 4B9B75103E691FF8
Send Loader...
This Phone is a "New HASH" Phone
You need to use The ATF Network and
Authorize this Phone to enable Super
Dongle Repair, Stand-Alone SX4 and
Decrypt SL3 PM 120 HASHES
Visit The ATF Store for more Information
VBATT OFF...
VBATT ON
Old 06-09-2011, 11:30   #6 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
@LEENO
SIMLock cannot be repaired without backup or buy an RPL file.
About Bus check ERROR, check settings:
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 06-09-2011, 12:03   #7 (permalink)
LEENO's Avatar
Member: 38084
Originally Posted by ..::Angel::.. View Post
@LEENO
Bro my setting are like your image but i have bus check error.
Rpl purchased will repair corrupted pm too?
Please suggest me cheapest rpl service
Is this good? Nokia RPL BB5 Work HOT! - IMEI-Server.com - NCK Codes for Unlock, Logs, Credits, Activations, Nokia RPL BB5
Old 06-09-2011, 12:56   #8 (permalink)
LEENO's Avatar
Member: 38084
Flashing other phone (5230 rm-588) with same cable work good
Number of Image Files: 3
MCU: V ICPR72_10w42.2 26-11-10 RM-588 (c) Nokia
IMEI: 3548450xxxxxxx
Model : Nokia 5230
Product Serial Number: 085A194AA
Product Code : 0589690
Module Code : 0204359
Basic Production Code: 0582715
Default SN Type : 0
PPM Version : V ICPR72_10w42.2 26-11-10 RM-588 (c) Nokia
HW Version : 0512
Content Pack Version : v 001_001 29-12-10 vanilla RM588
AHNE Version : 11
APE SW Core Version : V 40.0.003
APE Variant Version : V 40.0.003V 40.0.003 V 40.0.003
Retu Version : 16
Tahvo Version : 22
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : 0/3 , 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status : Not Locked
SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
SIMLOCK_TEST : PASSED
SECURITY_CODE : ENCRYPTED
PHONE_MODE : TEST MODE
PM 120 Found...
PM 308 Found...
SimLock Certificate Saved to : C:\AdvanceBox Turbo Flasher\Nokia\Backup\354845xxxxx\SL3_certificate_V ICPR72_10w42.2 26-11-10 RM-588 (c) Nokia_354845xxxxxxx_Not Locked_13.51.54.pm
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
ID DWORD 4 : 01051103
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
ID DWORD 0 : 0880000D
ID DWORD 1 : D7A20052
ID DWORD 2 : 67FA4E06
ID DWORD 3 : E9F0D04F
ID DWORD 4 : 994525C7
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71
7 ROM_ID 15
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 7B
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0231
Block Length : 09
Data : XSR 1.6
Checksum : 13
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0040
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR17_alg.f g
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
VARIANT : Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\354845046445557\3548450464455 57_13.52.03.rpl
Processing Image File : L:\500GB\FLASH NOKIA\Products\RM-588\RM-588_40.6.003_prd.core.C00
CMT Type : BB5
Number of Blocks : 202
Entry Point: 0x289CCA
Page Format : -1
VBATT OFF...
VBATT ON
BootFlashMode_DCT5
TIME STARTS HERE
1 SYSTEM_ASIC_ID 01
2 ROM_ID 15
3 ROM_ID 15
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum 7B
MessageID : 06
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0231
Block Length : 09
Data : XSR 1.6
Checksum : 13
SendAlgoCode_DCT5..
Flash Descriptor
Device ID : 0040
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 00080000
Partition 2
ID : 00000004 DEMANDONOS
Start Address : 02720000
Partition 3
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 09E60000
Partition 4
Start Address : 0F640000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200080000026A0000000000040000000202720000077400 00000000080000000109E60000056200000000000A00000001 0F640000003C0000F5
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0x5F (95)
ERASE Blocks : 0x02 (2)
0 ERASE_AREA_BB5 0x12
Block Length : 0x2B (43)
Device Index : 0x00
0 : 00040000-00082FFF
1 : 00083400-003FFFFF
2 : 00400000-007FFFFF
3 : 00800000-00D5FFFF
4 : 00D60000-09E5FFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 000000000000000A0000000000000002000000640000000B00 000002000000010000000000000000
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Erase_SendFormatPartition_BB5_NOR
Successfully erased..
Time Taken to Erase : 00.00.01
Flashing Speed: 5.00 Mhz (AUTO)
Processing : RM-588_40.6.003_prd.core.C00
Total blocks to write : 202
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : SOS*UPDAPP
>> CMT Rootkey Hash CERT : SOS*ENO
>> CMT Rootkey Hash CERT : SOS*DSP0
>> CMT Rootkey Hash CERT : SOS*ISASW
>> CMT Rootkey Hash CERT : SOS+CORE
>> CMT Rootkey Hash CERT : SOS+ROFS1
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
Time Taken to Flash : 00.00.24
Processing Image File : L:\500GB\FLASH NOKIA\Products\RM-588\RM-588_40.6.003_prd.rofs2.V01
CMT Type : BB5
Number of Blocks : 429
Entry Point: 0x00FF
Page Format : -1
No partition info....
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 02E20000-09D5FFFF
Time Taken to Erase : 00.00.00
Processing : RM-588_40.6.003_prd.rofs2.V01
Total blocks to write : 429
>> CMT Rootkey Hash CERT : SOS+ROFS2
Time Taken to Flash : 00.01.05
Processing Image File : L:\500GB\FLASH NOKIA\Products\RM-588\RM588_40.6.003_001_002_U001.uda.fpsx
CMT Type : BB5
Number of Blocks : 48
Entry Point: 0x00F9
Page Format : -1
StartErase_DCT5...
Device Index : 0x00
0 : 09E60000-0F47FFFF
Processing : RM588_40.6.003_001_002_U001.uda.fpsx
Total blocks to write : 48
Time Taken to Flash : 00.00.08
Total Flash Write Time (Flashing Only) : 00.01.38
Total Flashing Time (Booting + Erase + Flashing) : 00.01.41
Status_BB5 STATUS_REQUEST_BB5..
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000002
Additional Bad : 00000002
Correctable ECC : 00000000
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
IMEI: 354845xxxxx
Model : Nokia 5230
Default SN Type : 0
HW Version : 0512
Content Pack Version : v 001_002 01-02-11 vanilla RM588
AHNE Version : 11
APE SW Core Version : V 40.6.003
APE Variant Version : V 40.6.003.doc.OPDAV 40.0.003
Retu Version : 16
Tahvo Version : 22
Old 06-09-2011, 17:47   #9 (permalink)
Member: 643472
Sonork: 100.96901
@LEENO
So it was phone problem
Old 06-09-2011, 19:14   #10 (permalink)
LEENO's Avatar
Member: 38084
Bro other tool can flash it.
It was working, i flashed it with bad product code and now it have damaged sp data.
It is rm-625 and i bad flashed with rm-588
Atf cant flash it but it successful erase phone.
Old 06-14-2011, 08:11   #11 (permalink)
LEENO's Avatar
Member: 38084
i buyed rpl, now phone is working but atf still can't flash this phone. Mtbox can't flash it too but other tool succesfull flashed it.
Anyone succesfull flashed rm-625?
Old 06-14-2011, 11:02   #12 (permalink)
Member: 643472
Sonork: 100.96901
Hello.
If you are getting error like above, then is cable problem. RAPIDO flashing has no problem anyway.
Old 06-14-2011, 13:35   #13 (permalink)
LEENO's Avatar
Member: 38084
Bro my cable work for flashing rm-588 with atf
It work for rm-625 flash erase with atf
But cant write firmware to rm-625
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
fbus-mbus ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-05-1999 13:46
Page generated in 0.49773 seconds with 11 queries
