10-10-2013, 13:56 | #1 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1987130 Status: Offline Thanks Meter: 6 | LUMIA520 JTAG repair after the firmware update failed - [[SSOOLLVVEEDD]] This Flash File is NOT COMPATIBLE with this Phone. This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! ERROR: Flashing Failed! 请求帮助 Ask for help |
10-11-2013, 07:02 | #2 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
10-11-2013, 10:17 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @lingkeji Are you sure you selected correct RM-XXX for your 520 BIG BOOT file? Also try to see voltage on the battery using a Multitester. If phone is already DEAD for long time, then almost all the time the battery is also DRAINED and have zero charge. Last edited by Advance-Box; 10-11-2013 at 10:22. |
10-11-2013, 13:58 | #6 (permalink) |
Member: 1987130 Status: Offline Thanks Meter: 6 | Windows Phone 8 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Version: 1.1.1.3 Product Code: 059S320 Module Code: 0205436 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6035.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010C011700 UEFI App: FLASH APP Flash App Protocol Version: 1.12 Flash App Implementation Version: 1.23 Query ROOT KEY HASH... ROOT_KEY_HASH: A74593CEE9F88EDA6D4950CA46A3A634381F9458DB7BE8BE04 56B9521A6DFE01 Sending Image Signatures... ERROR: Flash Signature Block REJECTED! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! |
10-11-2013, 18:57 | #9 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | |
10-12-2013, 01:56 | #11 (permalink) | |
Member: 1987130 Status: Offline Thanks Meter: 6 | Quote: | |
01-06-2015, 10:57 | #13 (permalink) |
Registered User Join Date: Mar 2011 Location: dubai
Member: 1545797 Status: Offline Sonork: 1596859 Thanks Meter: 91 | plz help my lumia hang on logo i try many time with atf per show error If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 357257055813021 Version: 1.1.1.3 Product Code: 059S4H0 Module Code: 0205435 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8227.P6036.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100130000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02010F011C00 UEFI App: FLASH APP Flash App Protocol Version: 1.15 Flash App Implementation Version: 1.28 Query ROOT KEY HASH... ROOT_KEY_HASH: F771E62AF89994064F77CD3BC16829503BDF9A3D506D3FACEC AEF3F808C868FD Sending Image Signatures... ERROR: Flash Signature Block REJECTED! This Flash File is NOT COMPATIBLE with this Phone. ERROR: Flashing Failed! |
