Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 12-30-2014, 21:50   #1 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 36
Question samsung sm-g7102 repair phone by sdc but after removing memory card phone dead again
my samsung sm-g7102 dead
i repair boot with sdc file .
phone recover.
than i flashed.
phonerestart on startup and i remove memory card than swith on phone phone again dead.
and again insert memory card and swich on phone alive again.
please help i m very confused.
i m try many firmware one file and 4 file with pit partition
and many sdc file but result are same condition.
Old 12-31-2014, 07:32   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
When you flash the BL file + PIT, you need to remove the SD card first before you flash it.
Old 12-31-2014, 07:58   #3 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 36
Question fail
when i flash without sd card with same bl+pit odin show fail.
whenn i flash with sd card flash comlet but restart on startup. when tske sd card out phone go to dead mode.
Old 12-31-2014, 08:40   #4 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 156
most likely there is problem with Flash IC.
The Following User Says Thank You to invaderaze For This Useful Post:
Old 12-31-2014, 08:45   #5 (permalink)
Member: 1343981
Thanks Meter: 30
Thumbs up Send Ur Problem
Send Ur Problem
With Step By Step ( With Photos )
I Have A Solution For Ur Issue
Singaram
[email protected]
Old 12-31-2014, 15:10   #6 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 36
Question fail
phone recover.
than i flashed.
start on startup and show read cloar error e:failed to mount i remove memory card than swith on phone phone again dead.
Old 01-02-2015, 17:18   #7 (permalink)
lifegood8's Avatar
Member: 757297
Thanks Meter: 36
Question Question samsung sm-g7102 repair phone by sdc but after removing memory card phone de
any budy solve this plz reply.
Old 01-03-2015, 13:36   #8 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 952
probably eMMC related issue .. had the same before and couldn't fix it.
Old 01-05-2015, 09:30   #9 (permalink)
Member: 1751722
Thanks Meter: 19
http://forum.gsmhosting.com/vbb/f609...50/index2.html
read my post 22
Page generated in 0.19815 seconds with 8 queries
