Can't flash Lumia 610 RM-835 - Data Rejected at SEQ 0x151 Not really sure what I'm doing wrong. I have installed the drivers as instructed on the forum..... and couldn't find anything in the way of an answer to this particular problem. Would appreciate some help, it has been driving me mad over the course of the day :) Here is a screenshot... http://i48.tinypic.com/8wh4z4.jpg and the log Code: Windows Phone Flashing Started |
Well updated the software to V9.02. The "download latest version" button on advance-box.com is a little misleading I suppose...?! Seem to be getting several errors from the software now and again as other members have mentioned on the forum. Double/tripple checked drivers, one time i did see a zuneSomeThingOrOther process in the task manager. Killed it. With my hope renewed.... It failed again. Tried different versions of the flash files, different computers, even several RM-835's. Is this the correct place for the official support? |
Bump..... Product supporters.....? Did i miss something really obvious? Is that why I have no answer? |
Install ATF V9.00 >>> Update to V9.02 >>> Update Important Files Try to flash Download link Offical Hotfile Mirror Offical Mirrorcreator Mirror Br - srinibas |
Windows7: Same Thing again... Code: Windows Phone Flashing Started "Uninstall ATF >>> Keep backup the BACKUP folder > delete ATF folder Install ATF V9.00 >>> Update to V9.02 >>> Update Important Files Try to flash " Then I did the same, though after deleting ATF folder I also removed it via control panel and installed again, updated 9.02, updated the important files.... Now i did get a different skin.... though exactly the same error. What i do get every now and again are unresponsive script errors from firefox (i have also changed IE to default browser, to see if it helped) various different files, one for example resource://gre/modules/XPCOMUtils.jsm:320 and :323 with the option to stop the script or to continue it... again tried in normal and dead mode. No difference |
@degsmfan click [CHECK] button to see if your flash files are corrupted or not... |
I believe it also does this before flashing with the new version of ATF. The flash files do not appear to be corrupt, according to ATF. |
stuck at : ERROR: Data Rejected at SEQ 0x3 Status : WRITE OSBL CERTIFICATE FAILED The phone was working fine, just wanted to Debrand it. please help!! thanks |
Still have the same problem. Nice to know I'm not the only one though. |
same problem for me, no solution, I tried everything. ??? |
nobody knows? any possibility |
HI i have ver. v10.11 and have same trouble. here log: Sending AMSS Certificate HASH: 0A3B18ABC63D2CF5A23BEBC1500E56E22163B717 Certificate Size: 449 Bytes Status : WRITE AMSS CERTIFICATE SUCCESS Sending AMSS Data Blocks (Please Wait for 25 Seconds...) Status : AMSS WRITE SUCCESS Sending WPOS Certificate HASH: 0A3B18ABC63D2CF5A23BEBC1500E56E22163B717 Certificate Size: 1364 Bytes ERROR: Data Rejected at SEQ 0x151 Status : WRITE WPOS CERTIFICATE FAILED Any one know please? |
use phone product code firmware for flash use phone product code firmware for flash.i had same error.i just use same product code firmware.problem solved.atf wow:D:D |
hello same error, I have tried several ways and nothing, the phone up to my logo and did not go there thanks |
help same issue .. any help |
