Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 08-28-2012, 17:13   #1 (permalink)
Member: 769590
Thanks Meter: 16
Can't flash Lumia 610 RM-835 - Data Rejected at SEQ 0x151
Not really sure what I'm doing wrong. I have installed the drivers as instructed on the forum..... and couldn't find anything in the way of an answer to this particular problem.
Would appreciate some help, it has been driving me mad over the course of the day
Here is a screenshot...
and the log
Windows Phone Flashing Started
AMSS File Found:
 RM835_12w16_prod_generic_amss.esco
WPOS File Found:
 RM835_12160_prod_319_01_boot.esco
USER AREA ERASE File Found:
 RM835_12w16_prod_generic_user_area_erase.esco
WARNING: OSBL File is not Loaded
WARNING: MODEM ADSP File is not Loaded
             Windows Phone Lumia Flasher
If the Phone is ALIVE
  1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
  1. Press and Hold the VOLUME UP button
  2. Connect it to the USB Port while still Pressing
  3. Continue to Press the VOLUME UP button for 8 more
     seconds
             Basic Phone Information
SW Version             : 1066.0000.8773.12160
IMEI Plain               : 359313042581128
HW Version            : 112.1569.1.0
Product Code         : 059P4D7
Basic Product Code: 059L3R3
Module Code          : 0205127
PSN Number           : 03F4194AB
NCSD Version         : 1.9
            Extended Phone Information
Public ID           : 712071A9573134910495053BEFEDD5FD
Wireless Lan ID: 3C:36:3D:73:61:6A:00:00
Bluetooth ID     : 3C:36:3D:71:CF:12:00:00:FF:FF:FF:FF
Rebooting to OSBL MODE
Sending AMSS Certificate
HASH: 0A3B18ABC63D2CF5A23BEBC1500E56E22163B717
Certificate Size: 449 Bytes
Status     : WRITE AMSS CERTIFICATE SUCCESS
Sending AMSS Data Blocks
(Please Wait for 25 Seconds...)
Status     : AMSS WRITE SUCCESS
Sending WPOS Certificate
Certificate Size: 1460 Bytes
ERROR: Data Rejected at SEQ 0x151
Status     : WRITE WPOS CERTIFICATE FAILED
Old 08-30-2012, 07:57   #2 (permalink)
Member: 769590
Thanks Meter: 16
Well updated the software to V9.02. The "download latest version" button on advance-box.com is a little misleading I suppose...?!
Seem to be getting several errors from the software now and again as other members have mentioned on the forum.
Double/tripple checked drivers, one time i did see a zuneSomeThingOrOther process in the task manager. Killed it. With my hope renewed.... It failed again.
Tried different versions of the flash files, different computers, even several RM-835's.
Is this the correct place for the official support?
Old 09-03-2012, 09:24   #3 (permalink)
Member: 769590
Thanks Meter: 16
Bump.....
Product supporters.....?
Did i miss something really obvious? Is that why I have no answer?
Old 09-03-2012, 09:31   #4 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,216
Originally Posted by degsmfan View Post
Bump.....
Uninstall ATF >>> Keep backup the BACKUP folder > delete ATF folder
Install ATF V9.00 >>> Update to V9.02 >>> Update Important Files
Try to flash
Download link
Offical Hotfile Mirror
Offical Mirrorcreator Mirror
Br - srinibas
Old 09-03-2012, 13:12   #5 (permalink)
Member: 769590
Thanks Meter: 16
Windows7:
Same Thing again...
AMSS File Found:
WPOS File Found:
     seconds
I did this....
"Uninstall ATF >>> Keep backup the BACKUP folder > delete ATF folder
Try to flash "
Then I did the same, though after deleting ATF folder I also removed it via control panel and installed again, updated 9.02, updated the important files....
Now i did get a different skin.... though exactly the same error.
What i do get every now and again are unresponsive script errors from firefox (i have also changed IE to default browser, to see if it helped)
various different files, one for example resource://gre/modules/XPCOMUtils.jsm:320 and :323
with the option to stop the script or to continue it...
again tried in normal and dead mode. No difference
Old 09-03-2012, 18:44   #6 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,045
@degsmfan
click [CHECK] button to see if your flash files are corrupted or not...
Old 09-04-2012, 07:20   #7 (permalink)
Member: 769590
Thanks Meter: 16
Originally Posted by Advance-Box View Post
@degsmfan
Thanks for your answer, I have done this with all 3 sets of flash files. (2 different versions)
I believe it also does this before flashing with the new version of ATF.
The flash files do not appear to be corrupt, according to ATF.
Old 09-04-2012, 08:55   #8 (permalink)
MPhoneClinic's Avatar
Member: 20639
Thanks Meter: 233
and the log
AMSS File Found:
WPOS File Found:
     seconds
NCSD Version         : 1.9
I got the same issue trying to flash Nokia 800 rm-819
stuck at :
ERROR: Data Rejected at SEQ 0x3
Status : WRITE OSBL CERTIFICATE FAILED
The phone was working fine, just wanted to Debrand it.
please help!!
thanks
Old 11-08-2012, 15:59   #9 (permalink)
Member: 769590
Thanks Meter: 16
Still have the same problem. Nice to know I'm not the only one though.
Old 02-07-2013, 08:43   #10 (permalink)
Member: 1283794
Thanks Meter: 3
same problem for me, no solution, I tried everything. ???
Old 02-07-2013, 10:47   #11 (permalink)
Member: 1283794
Thanks Meter: 3
nobody knows? any possibility
Old 10-17-2013, 13:48   #12 (permalink)
Member: 1232550
Thanks Meter: 6
HI
i have ver. v10.11 and have same trouble.
here log:
Certificate Size: 1364 Bytes
Any one know please?
Old 06-16-2014, 14:19   #13 (permalink)
samindapowerson's Avatar
Member: 1857049
Sonork: 100.1627774
Thanks Meter: 179
use phone product code firmware for flash
use phone product code firmware for flash.i had same error.i just use same product code firmware.problem solved.atf wow
Old 06-20-2014, 15:40   #14 (permalink)
Member: 389266
Thanks Meter: 10
hello
same error, I have tried several ways and nothing, the phone up to my logo and did not go there
thanks
Old 07-30-2014, 20:03   #15 (permalink)
Member: 143848
Thanks Meter: 87
help
same issue ..
any help
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 04:41
The Best Dual Data cable FBUS-M2BUS for your NOKIA 5110 6110 nk.cable Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-14-1999 15:33
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-16-1999 12:20
Page generated in 0.46887 seconds with 8 queries
