04-18-2013, 08:55 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Cant Flash Lumia 710 on XP sp3 alreday installed drivers According to This Code: 1. C:\AdvanceBox Turbo Flasher\DriverNokia_Connectivity_Cable_Driver_7.1. 101.0.msi 2. C:\AdvanceBox Turbo Flasher\Driver\Lumia Phone Drivers\WinUSB Drivers.msi 3. If still ask for drivers, give this path: C:\AdvanceBox Turbo Flasher\Driver\Zune Drivers Here is the scren shot of error uninstalled and installed all driver 2-3 times, and Zune also. please solve my problem. BR |
04-18-2013, 09:06 | #2 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Maybe help u. http://forum.gsmhosting.com/vbb/9297451-post27.html |
The Following User Says Thank You to mbiborna For This Useful Post: |
04-18-2013, 09:19 | #3 (permalink) |
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Thanks Mate Flashed Successfully Code: Windows Phone Flashing Started OSBL File Found: RM803_12w18_prod_generic_nokia_osbl.esco AMSS File Found: RM803_12w18_prod_generic_amss.esco ADSP File Found: RM803_12w18_prod_generic_adsp.esco WPOS File Found: RM803_12180_prod_221_01_boot.esco USER AREA ERASE File Found: RM803_12w18_prod_generic_user_area_erase.esco ====================================================== Windows Phone Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ====================================================== Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes Status : WRITE OSBL CERTIFICATE SUCCESS Sending OSBL Data Blocks [BLOCK 1 0x00000000~0x000EA227] Data Size: 0x000EA228 Bytes SHA-256 : 8958B125792783B8738B72F8E583DFEA ---------- : B56CD367044EB16EDEA9BACAE740F77E Status : OSBL WRITE SUCCESS Sending AMSS Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 449 Bytes Status : WRITE AMSS CERTIFICATE SUCCESS Sending AMSS Data Blocks (Please Wait for 25 Seconds...) Status : AMSS WRITE SUCCESS Sending ADSP Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 449 Bytes Status : WRITE ADSP CERTIFICATE SUCCESS Sending ADSP Data Blocks (Please Wait for 25 Seconds...) Status : ADSP WRITE SUCCESS Sending WPOS Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 1652 Bytes Status : WRITE WPOS CERTIFICATE SUCCESS Sending WPOS Data Blocks [BLOCK 1 0x00000000~0x00FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 40F04B3D89AAD618B9BEB74DB66311E4 ---------- : 948498715ABC538520A70E27656F70DA Status : WPOS WRITE SUCCESS [BLOCK 2 0x01000000~0x016573FF] Data Size: 0x00657400 Bytes SHA-256 : E82D455752C99475A49FB363563F9570 ---------- : B1E99DF5E75492EF1FB719D2D3223F80 Status : WPOS WRITE SUCCESS [BLOCK 3 0x01697400~0x01FFFFFF] Data Size: 0x00968C00 Bytes SHA-256 : 59097A0018DE221A449DA0AC093070D6 ---------- : 39BACF8FE1E5DB93209734BB87A8E299 Status : WPOS WRITE SUCCESS [BLOCK 4 0x02000000~0x02FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : A167FAA647145B67A7C3F99B1B443A78 ---------- : 9AE0D08BE4C24D7B2BFCD5179AD29E48 Status : WPOS WRITE SUCCESS [BLOCK 5 0x03000000~0x03FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 492AF8AB26F9C2AEC042293D1E5C3526 ---------- : BBEE0809B384BC885BC4868D07112824 Status : WPOS WRITE SUCCESS [BLOCK 6 0x04000000~0x04FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 347916A286963D99D9479B4560D1A1C5 ---------- : 0BDA4E654E93370001371BE50D21A77E Status : WPOS WRITE SUCCESS [BLOCK 7 0x05000000~0x05FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 54ECE68DBEF3EDD868D60650CB8C1982 ---------- : 1D4991328FAA2F546724C0718D8E7B2C Status : WPOS WRITE SUCCESS [BLOCK 8 0x06000000~0x06FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : A1BF5ECE6B35E5D940C21D444E9EFA34 ---------- : 5583E8A859C7770746EB4D79D32B99E7 Status : WPOS WRITE SUCCESS [BLOCK 9 0x07000000~0x07FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 4884D50FAB3095E2427BD9EC847EF3E2 ---------- : 424EC50A98958299C8964FFC3E2AE2D2 Status : WPOS WRITE SUCCESS [BLOCK 10 0x08000000~0x08FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 883389D1805933C037BD4C7CD7E2E9D6 ---------- : A01A6076DE280452C32ED26F62A66CC4 Status : WPOS WRITE SUCCESS [BLOCK 11 0x09000000~0x09FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : DBF2A7120560C8320C72734EA1F05470 ---------- : ED1C15AA9E5F90ADBCA1F430765E3A4C Status : WPOS WRITE SUCCESS [BLOCK 12 0x0A000000~0x0AFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 461D4FF97D9AB5A3D03A58EE16EB441A ---------- : 78DBBAA8E88960FBF433924251D45428 Status : WPOS WRITE SUCCESS [BLOCK 13 0x0B000000~0x0BFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 23A3E7B54C2B52269C51AAED44B3AC6A ---------- : F513DBC1EEBB8EB8C178DEA16CF386CE Status : WPOS WRITE SUCCESS [BLOCK 14 0x0C000000~0x0CFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : B4D8711D02269EF96552BDF4AB8A9189 ---------- : 1446147984E079991143D60DEDDCB968 Status : WPOS WRITE SUCCESS [BLOCK 15 0x0D000000~0x0DFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : B0E0BFF54841D00A8000F2E318137228 ---------- : A08FC68D02DB124CF0059262FD2E3478 Status : WPOS WRITE SUCCESS [BLOCK 16 0x0E000000~0x0EFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 7D03ACA368E9E317644340878EA0491C ---------- : DD21E04B1B9AF9FEF6FDD89FA7B4D6A0 Status : WPOS WRITE SUCCESS [BLOCK 17 0x0F000000~0x0FFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 859978814DB5827BC46B7392C5470C66 ---------- : 91A399932A590F5CD15BD9B12D2F63BC Status : WPOS WRITE SUCCESS [BLOCK 18 0x10000000~0x10FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : EDD82B56D53DE42028CFB899255F1F1F ---------- : 30B4D08F5B00840F7EF9CF8E24F7185E Status : WPOS WRITE SUCCESS [BLOCK 19 0x11000000~0x11FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : FE0E23B8A8161C4D3B0F3D2A5389DDFD ---------- : 5BE6D521CEA40C1B46E6270C6F8EB5D1 Status : WPOS WRITE SUCCESS [BLOCK 20 0x12000000~0x12FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : DC533D9A164CD88C62E7275CD4066EFF ---------- : 8C2C9FF94C1CB68B8952A1021C021F89 Status : WPOS WRITE SUCCESS [BLOCK 21 0x13000000~0x13FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : B007FA22943A97A035F3ADD8961EF19D ---------- : 7E889412862FAF3FDEF780538F18F9BB Status : WPOS WRITE SUCCESS [BLOCK 22 0x14000000~0x14FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : D0D05173CCF5D36427E454DF6BE38548 ---------- : 7CC7BA4E8FE2FDF68F45E87F464A5331 Status : WPOS WRITE SUCCESS [BLOCK 23 0x15000000~0x15FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : BA769F114796DB0554A2C9F0797B052A ---------- : CC1FC3A430EF1BA0333704BFA64DDC5F Status : WPOS WRITE SUCCESS [BLOCK 24 0x16000000~0x16FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 24A58C9677D182CEE8BD0D02F1A87085 ---------- : A26142443BB84D56B117BA448E76D6F1 Status : WPOS WRITE SUCCESS [BLOCK 25 0x17000000~0x17FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 5367C6FB8E30D2DF71A39FDB64DA1B2C ---------- : 0FC274374A1DCFA23AD004298443C689 Status : WPOS WRITE SUCCESS [BLOCK 26 0x18000000~0x18984BFF] Data Size: 0x00984C00 Bytes SHA-256 : CD64799755120F2CEB7F260D6354F566 ---------- : 44193F2F41A3C8DEA2E1236441B0F006 Status : WPOS WRITE SUCCESS Sending USER AREA ERASE Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 396 Bytes Status : WRITE ERASE CERTIFICATE SUCCESS Erasing USER AREA Status : ERASE SUCCESS Flashing Done! Total Flashing Time (Erase + Flashing) : 00:04:03 its done but its still on 7.5 windows, is there any updatesd for windows 7.8 for lumioa 710 rm-803. BR Last edited by himanshu taldar; 04-18-2013 at 09:27. |
04-18-2013, 12:01 | #5 (permalink) | |
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Quote:
Used this version 1600.3031.8779.12180 not found any newer vesrion can u pls tell the exect file? btw currently i installed 7.8 custom version in lumia and its working 7.8 custom. any official flash file for lumia 710 rm-803? br | |
04-20-2013, 11:41 | #12 (permalink) | |
Bro i tried with nokia Data package manager, but coudnot found latest 7.8 firmware for my phone, tried all product code. This Is the last version Found on Nokia Data package manager 1600.3031.8779.12180 and i want this 1600.3036.8858.12xxx Br | |
04-20-2013, 13:19 | #13 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, Perhaps... Nokia removed that beta version of 7.8 from their server. I download from Navifirm before. You can try to search on Google for alternate links (if available). BR |
04-22-2013, 11:52 | #15 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Try to download from this link found on Google. BR | |
