10-08-2015, 08:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Heart of Asia
Member: 1706168 Status: Offline Sonork: 100.1619095 Thanks Meter: 66 | Can't flash Nokia 105 there is Nokia 105 new brand , can't flash with ATF GOLD , tried with two different ATF version in two PC , still same, flash file is 100% ok because before this i flashed a lot of 105 with this file here is the log and screenshot Code: VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00C2 Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Processing Image File: E:\Nokia\105.RM-908\RM-908\rm908_03.400 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... |
01-26-2016, 12:53 | #3 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In the dark side ;) Age: 44
Member: 21508 Status: Offline Thanks Meter: 186 | I have got exactly same problem, i think there some new HW version which are not supported.. @Support could you do something ?? Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer ID: 0x00C2 Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Multi-Bank / 1.8v Processing Image File: F:\____ GSM ____\Nokiz\bb5\RM908_English_Deutsch_French_Italia no_Dutch_03.40\rm908_003.400 Data Block Found... Number of Sections: 03 IMAGE Certificate Block Sent Successfully... Processing Section 01 of 03 IMAGE Erase Block: 0x00800000~0x00A0FFFE Start Erasing... Erasing Please Wait... |
