12-23-2012, 11:58 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 748456 Status: Offline Thanks Meter: 32 | Can't remove the password from MicroSD Here is the log Code: Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x00 Application ID : Product Name : N/A Product Revision : 1.0 Serial Number : 71CFAAF3 Manufacture Date: September 2010 Card CID: 0020204E2F4120201071CFAAF300A983 Card CSD: 006F00325F5A83BFF6DBDFFF8A804021 Card SCR: FFFFFFFFFFFFFFFF Card OCR: FF0080FF80 Maximum Speed: 25000000 Hertz Checking Lock Status... Micro SD Card is Password Protected!!! Creating Resume File: C:\AdvanceBox Turbo Flasher\sd_card\resume\0020204E2F4120201071CFAAF300A983.resume Total Number of Passwords to Try: 12356630 Starting Brute Force... Password Found: a Micro SD Card Password Removed!!! Total Brute Force Time: 00:00:00 Number of Passwords Attempted: 512 Password Saved To: C:\AdvanceBox Turbo Flasher\sd_card\resume\0020204E2F4120201071CFAAF300A983.pass Process Done... |
The Following User Says Thank You to Alva For This Useful Post: |
12-23-2012, 17:46 | #4 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
There are some "China" brand cards which does not follow to SD Specifications... These unlicensed manufacturers usually have Manufacturer ID : 0x00 same as your card... In this case, it is hard to support it unless I can get the same "China" brand card like yours... ATF Software tells you the password is "a" because the card replied Success when ATF Software tried to unlock the card with password "a". Best way to deal will this card is just FACTORY FORMAT it and LOOSE ALL DATA INSIDE... | |
