09-16-2012, 13:36 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: gsmworld Age: 43
Member: 85537 Status: Offline Thanks Meter: 66 | can't unlock lumia 710 ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 710 Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5D Product SN : 002AA430 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... ERROR: Dump Aborted, Too Much Read Failures! Total Elapsed Time 00:00:27 |
09-16-2012, 13:46 | #2 (permalink) |
Member: 85537 Status: Offline Thanks Meter: 66 | Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 710 Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5D Product SN : 002AA430 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... Patch Byte Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 enter pin code 00000000 but incorrect ,flashed then try again but the same |
09-16-2012, 15:16 | #3 (permalink) |
No Life Poster Join Date: Dec 2009 Location: DUBAI Age: 33
Member: 1189306 Status: Offline Sonork: 100.1589231 Thanks Meter: 273 | @mishiko_gsm bro flash ur set with AMSS file downlaod from navifirm+ here is the navifrm+ link.. http://forum.gsmhosting.com/vbb/8619211-post8.html then try again to unlock bro |
09-17-2012, 09:10 | #5 (permalink) |
Member: 85537 Status: Offline Thanks Meter: 66 | i flashed amss file several times and unlocked several times too,but when try to input 00000000 incorrect password Interface Reset OK! Reading Platform Information... Selecting Active Handle... Select Handle OK! Sending Ping... Ping Reply OK! Lumia 710 Detected Storage Device Information Manufacturer ID: 90 Application ID : 014A Product Name : HYNIX Product Rev : 5D Product SN : 002AA430 Protection Information Write Protect A: OFF Write Protect B: OFF Dumping AMSS FAT16 Region Please wait for 2-4 Mintues... Patch Byte Found... Total Patch Bits Found: 1 Patching AMSS... Patch OK! SP Unlock Done! PIN: 00000000 PUK: 0000000000 Total Elapsed Time 00:02:23 |
