05-11-2015, 09:51 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Under the Sky
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | cant write system with emmc??? i tik system but always skiping system why???whats is wrong? Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 11010030303847344200100C18293F9F CSD : D00E00320F5903FFFFFFFFE79640001F eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 4096 KB USER AREA SIZE : 7952400384 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 256 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 008G4B Product Rev : 0.0 Product SN : 100C1829 Manufactured : January 2012 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 11010030303847344200100C18293F9F.ext_csd Backup Directory: C:\ATF\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ MBR is Corrupted... Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:02 Write Success! Flash Image: PIT Start Writing 0x00000009 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: SGPT Start Writing 0x00000021 Blocks at 0x00ECFFDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: aboot.mbn Start Writing 0x00001000 Blocks at 0x00022280 Partition Selected: USER AREA Total Elapsed Time 00:00:03 Write Success! Flash Image: sbl1.mbn Start Writing 0x00000400 Blocks at 0x00021E00 Partition Selected: USER AREA Total Elapsed Time 00:00:05 Write Success! Flash Image: rpm.mbn Start Writing 0x00000400 Blocks at 0x00023280 Partition Selected: USER AREA Total Elapsed Time 00:00:07 Write Success! Flash Image: tz.mbn Start Writing 0x00000400 Blocks at 0x00023680 Partition Selected: USER AREA Total Elapsed Time 00:00:05 Write Success! Flash Image: sdi.mbn Start Writing 0x00000040 Blocks at 0x00022200 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: non-hlos.bin Start Writing 0x00007000 Blocks at 0x00002000 Partition Selected: USER AREA Total Elapsed Time 00:00:23 Write Success! Flash Image: boot.img Start Writing 0x00005000 Blocks at 0x00033280 Partition Selected: USER AREA Total Elapsed Time 00:00:21 Write Success! Flash Image: recovery.img Start Writing 0x00005000 Blocks at 0x00038280 Partition Selected: USER AREA Total Elapsed Time 00:00:23 Write Success! Warning: EXT3/4 Image Detected Skipping system.img.ext4... Total Images Written: 8 Process Done! |
05-11-2015, 09:52 | #2 (permalink) |
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | Warning: EXT3/4 Image Detected Skipping system.img.ext4... why atf skipping system?? i cant flash this phone with odin or z3x it gives error on aboot and phone deadboot again |
