09-10-2013, 07:18 | #1 (permalink) |
Junior Member Join Date: Oct 2011 Location: philippines
Member: 1670625 Status: Offline Thanks Meter: 1 | cherry mobile error emmc repair let me know if my emmc is damage already.. 1. DO NOT USE THE PHONE"S BATTERY 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box Interface Reset OK! eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 2.7-2.8V, 2.6-2.7V, 2.5-2.6V 2.4-2.5V, 2.3-2.4V, 2.2-2.3V, 2.1-2.2V, 2.0-2.1V 1.9-2.0V eMMC Boot Information BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT: DISABLED PWR_BOOT_CFG_PROT : DISABLED eMMC FirmW UPDATE : DISABLED ERROR: Connection Refused (CMD6) Check your Test Point Soldering! Total Elapsed Time 00:00:09 Write Success! i resoldered again and again but still the same problem... TIA |
09-10-2013, 13:01 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | -use small cable(rj45) -work with USB and POWER SUPPLY(RPS) or battery -double check your connection/pinout -use desktop PC not laptop/netbook (in my unit, can't work in laptop with atf lightning) |
The Following User Says Thank You to Sniper_04 For This Useful Post: |
