02-28-2014, 06:07 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: phillippines
Member: 295944 Status: Offline Thanks Meter: 194 | Cherry Mobile FLAME 2.0 Hang in Android Logo Success Flash Restore Boot By ATF Jtag PHONE MODEL TOOLS - ATF NITRO or ATF BOX (JTAG ACTIVATED) - Modified RJ45 Fbus Cable ( Don't use LAN cable use Old Nokia Fbus Cable ) - CA-101 usb cable (for phone power supply) FILES NEEDED: Download here: CHERRY_MOBILE_FLAME_20_FACTORY.afp PROCEDURE: - disassemble phone first - soldered the pinout with MODIFIED RJ45 Fbus cable to Phone board PINOUT: - after soldered pinout connect Phone to Box using modified rj45 Fbus cable - then connect phone also to PC using CA-101 usb cable that server as your power supply - run ATF JTAG software - Click SELECT PHONE and browse the file CHERRY_MOBILE_FLAME_20_FACTORY.afp - click RESET JTAG to check the phone connections to Box - now click RESTORE BOOT for flashing or restoring the phone ( patience is Needed Flashing will take 40 minutes to finish ) FINISH FLASHING - after Flashing do format the phone by pressing and holding VOLUME UP and POWER BUTTON until phone screen become RED SCREEN DISPLAY. - select WIPE DATA / FACTORY RESET then press power button - then YES - - DELETE ALL USER DATA then press power button - select REBOOT SYSTEM NOW then press power button After Format wipe data Phone is now OK. IMEI is still intact no need rebuild IMEI in my case and in my procedure Phone info after flashing FINISH PRODUCT Br, Xeven2nd |
The Following 6 Users Say Thank You to 7even2nd For This Useful Post: |
02-28-2014, 06:11 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @7even2nd Great Tutorial / Demonstration! Very clean work and very clear pix! However, that is my phone's IMEI Look at TP Picture Screenshot... you will see IMEI on back sticker of my phone... |
The Following User Says Thank You to Advance-Box For This Useful Post: |
02-28-2014, 07:21 | #3 (permalink) |
Member: 295944 Status: Offline Thanks Meter: 194 | @Advance-Box Thank you very much sir. WOW you brought the Phone in the Philippines Coz have NTC approved sticker . . . |
The Following User Says Thank You to 7even2nd For This Useful Post: |
07-28-2014, 05:20 | #4 (permalink) |
Junior Member Join Date: Mar 2011 Location: Cebu City Ph
Member: 1539737 Status: Offline Sonork: [email protected] Thanks Meter: 0 | thanks boss ...... malaki ang na ibahagi mo! sa lahat,,,,,___++++ |
