04-29-2014, 10:15 | #1 (permalink) |
Freak Poster Join Date: May 2010 Location: philippines Age: 34
Member: 1300904 Status: Offline Thanks Meter: 31 | Cherry mobile Flare 2X help.. Good pm to all pls help me to my Cherry Mobile Flare 2X show this error after click restore boot always show Waiting for Device Connection 20 second(s)...Timeout During Operation! how to fix this Phone Type : Cherry Mobile Flare 2X CPU Type : Qualcomm MSM8225Q Storage TYpe : eMMC 4GB Boot Package : Full Factory Restore Android Version: 4.1.2 (Jelly Bean) Kernel Version : 3.4.0 Build Number : TBW593922_8760_V006094 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs 8. Full Factory Restore takes 40 minutes to Finish ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x008E00E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...Timeout During Operation! Restore Boot... Waiting for Device Connection 20 second(s)...Timeout During Operation! Restore Boot... Waiting for Device Connection 20 second(s)...Timeout During Operation! pls help ATF team |
04-30-2014, 01:33 | #5 (permalink) | |
Member: 1300904 Status: Offline Thanks Meter: 31 | Quote:
yup detected as a Qualcomm then i try connect the battery and w/o batery but alwats show error Waiting for Device Connection 20 second(s)...Timeout During Operation! i try pinout again but same | |
04-30-2014, 02:13 | #7 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | If detected as qualcomm, then it means your JTAG connection is NOT OK. Either your pinoutis wrong or your RJ-45 head is not working. Use RJ-45 head from OLD FBUS Cable only. DO NOT USE PC LAN CABLE! It you follow pinouts 100% correctly as shown in ATFJ.exe, then it should be detected! B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
