09-04-2013, 07:50 | #34 (permalink) | ||
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 36
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,778 | Quote: Initializing Device...Init Write Error at line 3, Access to Memory Not Completed! Quote:
09-04-2013, 15:30 | #37 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: Shadow Clone
Member: 1357650 Status: Offline Sonork: 100.1611843 Thanks Meter: 123 | Quote:
bR | |
09-04-2013, 16:39 | #40 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | 1. If eMMC is not Damaged, then direct connection to eMMC via TP should work. If it does not work for you, then you must make it work by check type of cable used, soldering etc. 2. If eMMC is Damaged, nothing you can do but replace eMMC. As promised I will give free samples once my eMMCs arrive. I will also pre-program it with a working JB image so that all you need to do is change the IMEI after you replace the eMMC on the PCB. 3. If you use my full Dump for eMMC from here: http://www.4shared.com/rar/jKrvD-8T/...JBv006045.html You will not have any problems with partitions or "reduced size" in internal storage. You can even write this dump on a blank eMMC and it will work 100% after. (Of course please do change the IMEI 1 and IMEI 2 because sooner or later the IMEI inside my dump will be blocklisted by NTC hehehe). B.R. |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
09-04-2013, 20:53 | #41 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brunei Age: 34
Member: 704097 Status: Offline Sonork: 100.1607742 Thanks Meter: 820 | I'll try to replace eMMC samsung 16gb (KYLUM galaxy s3) Flashing stop and after replug power supply and cable, flashing continued...but stop again! I think KYLUM eMMC does not compatible in flare Br, Sent from my iPhone 4 using Tapatalk 2 |
The Following User Says Thank You to Sniper_04 For This Useful Post: |
09-04-2013, 23:12 | #42 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @Sniper_04 It should be compatible, if the eMMC is fully working. Your eMMC replacement has "No Product Name" and wrong "Boot Partition". So it is not 100% working. B.R. |
