07-04-2014, 04:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: .........
Member: 665025 Status: Offline Thanks Meter: 44 | cherry mobile hyper atf pls help,.. - (CM Hyper V1 and V2 AFP Now Available) repair via atf, complete done,. now device is alive but no recovery mode, no bootloader nor fastboot,. only abnormal display,. how to flash stock recovery,. pls help,.. |
07-04-2014, 05:52 | #2 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @markrempillo It should have recovery and it should allow you to Wipe Data and Cache. Hyper AFP file was tested on a FULLY Blank eMMC. So it should work on any Hyper phone. What do you mean by Abnormal Display? B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
07-04-2014, 05:55 | #3 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @markrempillo Also, if phone can go into ADB and is rooted, you can flash stock recovery via ADB. |
07-04-2014, 07:29 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | I Tested my Hyper AFP File Again... and it is PERFECTLY WORKING. WIRE UP JTAG CONNECTION BOOT REPAIR DONE, EVEN WORKS ON 30 MHZ SPEED! FIRST BOOT - WITHOUT WIPE DATA/CACHE INTERNAL STORAGE IS OF CORRECT CAPACITY USB STORAGE IS ALL ACCOUNTED FOR... |
07-04-2014, 11:38 | #6 (permalink) |
Member: 665025 Status: Offline Thanks Meter: 44 | abnormal display, it ons with white screen and suddenly lots of colors then slowly turning off,.. my customer flash it with wrong firmware then try to flash recovery, after that became dead,. then i downloaded d afp for hyper, no imei factory, connect successfully with jtag and write successfully, then thats the result,. sorry late reply,. slow internet here,. edit: same logs as above,.. |
07-05-2014, 05:05 | #9 (permalink) |
Member: 665025 Status: Offline Thanks Meter: 44 | thats it,. NO v2.0 at the back,. thnks for your reply,. ill just wait for your file,. thnks team,. waiting here,............... |
The Following User Says Thank You to markrempillo For This Useful Post: |
07-08-2014, 08:57 | #11 (permalink) |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | CM HYPER V1 readed dump by ATF using MSM8225_READ_FULL.afp Hyper V1 - Download - 4shared hope it can help br. FFC |
07-08-2014, 12:07 | #13 (permalink) |
Member: 159757 Status: Offline Thanks Meter: 461 | eMMC_flash1_part1_0x00000000.BOOT1.bin =2,048kb eMMC_flash1_part2_0x00000000.BOOT2.bin =2,048kb eMMC_flash1_part0_0x00000000.USER.bin =3,784,704kb br. FFC |
07-08-2014, 17:48 | #15 (permalink) | |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Hi, Try this AFP for Hyper v1 made from rico_deep's dump CHERRY_MOBILE_HYPER_V1_FACTORY_NO_IMEI.afp CHERRY_MOBILE_HYPER_V1_IMEI_ONLY.afp | |
