01-15-2014, 10:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Ghaziabad, India
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | currently not supported for windows phone currently not supported for windows phone what does it means??? lumia 620 is hang on nokia logo what should I do??? |
01-15-2014, 10:53 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, that's right. Bus Check and Backup RPL is not supported for Windows Phones. You can simply full flash phone for logo hang problem at first.. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
01-15-2014, 11:16 | #4 (permalink) |
Member: 977479 Status: Offline Sonork: 100.1638508 Thanks Meter: 795 | Lumia 620 hang on nokia done via atf Code: Windows Phone 8 Flashing Started Loading Flash Files Please Wait... ====================================================== Windows Phone 8 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... ====================================================== IMEI: 356347051752496 Version: 1.1.1.3 Product Code: 059R5S6 Module Code: 0205404 Boot Flash Mode Successful... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 00E74000 Block ID 0x05 : Nokia.MSM8227.P5122.1.2 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010C011700 UEFI App: FLASH APP Flash App Protocol Version: 1.12 Flash App Implementation Version: 1.23 Query ROOT KEY HASH... ROOT_KEY_HASH: 67131691EEDD1F38568C7FFAE284FB2621680FEAC833314467E31DAA963D1467 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:03:34 |
