11-27-2010, 14:08 | #16 (permalink) |
Freak Poster Join Date: May 2010 Location: HOLLYWOOD
Member: 1312925 Status: Offline Thanks Meter: 49 | Flashing .................................................. ...................90% Unlock (SL1/SL2) Server ok,but Sw Fail ............................50% Unlock (SL3) .................................................. ...............0% Sx4,SD Repair Server ok,but Sw Fail ................................50% Manual Erase BB5 (SL1/SL2) ...........................................1% UI Settings/Format .................................................. ......50% +++++++++++++++ DCT3/DCT4/Infinion ++++++++++++++++++ Buscheck/Flash .................................................. ...........10% DCT4 PLus Unlock (RSA) .................................................. 0% UI settings,Reset Sec. code ...........................................20% RPL Write .................................................. ...................10% this is my experience |
The Following 3 Users Say Thank You to cloud.vandam For This Useful Post: |
12-01-2010, 03:53 | #20 (permalink) |
No Life Poster Join Date: Apr 2009 Age: 41
Member: 1015389 Status: Offline Sonork: 19830303 Thanks Meter: 526 | i got error to all previous updates are all working good.. but i do it in this ways: *after selecting dct4 tab reset your box *insert cable to phone and in flash bus port then bus check *if you see error etc.. remove it from flash bus wait for 3 seconds and insert it again and bus check again *sometimes i got 3 tries before it connect properly *if now fully detected now you can do flashing etc.. thats why i use atf is for fast flashing it saves my time alot.. please atf team fix this issue.. |
The Following User Says Thank You to marvin03 For This Useful Post: |
12-05-2010, 13:08 | #21 (permalink) |
Product Manager Join Date: Jan 2009 Location: Philippines Pure Pinoy Age: 37
Member: 943187 Status: Offline Thanks Meter: 584 | STILL error!! 1. Select BB5 instead of DCT4 2. Do not connect any phone to the Box 3. Click "Buscheck" and wait for ERROR message to finish (15 seconds) 4. Select DCT4 Phone now and connect your 1202 phone. 5. Click Buscheck and your 1202 DCT4 UPP will be detected now... what is the problem on my atf? cant check all dct4 |
12-05-2010, 17:21 | #22 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 47
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | ATF best only for bb5 phones not for dct4. Still getting errors in bus check and other problems. Atf team should improve in that section. I m still useing HWK for dct4 phones most reliable. |
12-06-2010, 12:38 | #27 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: india
Member: 942210 Status: Offline Sonork: 1511 Thanks Meter: 91 | Quote:
Boot Check, Please wait... VBATT OFF... VBATT ON Setting VBATT Done!... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 22 lsbUPP_ID : 92 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Boot OK! SearchForBootstrap_DCT4 : Error (Failed) BUSCheck FAILED | |
12-06-2010, 15:51 | #28 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
BR | |
12-09-2010, 08:19 | #29 (permalink) |
Member: 942210 Status: Offline Sonork: 1511 Thanks Meter: 91 | problem still Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 22 lsbUPP_ID : 92 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u3_2nd.fia DataLen : 000009D8 Boot OK! SearchForBootstrap_DCT4 : Error (Failed) BUSCheck FAILED plz help atf team |
Nokia 5110 v5.29 via M+F-Bus Data Cable | gsmdeemon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-30-2001 21:17 |
check out my FREE large gsm soft site | LaLGsm | GSM Mobile Links | 0 | 01-16-2001 04:36 |
F-Bus, M-Bus, M2Bus, Dau-9P ? | Max Hash | Nokia Hardware & Hardware Repair | 1 | 05-10-2000 03:41 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
