01-06-2014, 06:53 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: next to obama's ancestor grave
Member: 585028 Status: Offline Thanks Meter: 25 | Detecting ONFI #1 ID...ONFI Signature Not Found! Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting ONFI #1 ID...ONFI Signature Not Found! Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting ONFI #1 ID...ONFI Signature Not Found! |
01-17-2015, 22:45 | #6 (permalink) |
Freak Poster Join Date: Jun 2010 Location: MEXICO
Member: 1318721 Status: Offline Thanks Meter: 166 | select restore boot and select file unlock lumia 900 before repari boot tks team Default language ID 0x080A JTAG Interface Connected, S/N 0xD099A411 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 3, compiled 23/09/2013 07:35:00 p.m. ================================================== ======== Phone Type : Lumia 900 RM-808, RM-823 Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Automatic Counter Reset (If Needed) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY Flex Cable 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to Phone 5. Use RESET JTAG button to check the JTAG Connection 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting ONFI #1 ID...MICRON MT29F1G08ABBDAH4, 128 MiB Sending Flash Loader...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 79066100 ACTIVE Level 1 PUK: 80419908 ACTIVE Level 2 PIN: 95572303 Level 2 PUK: 93083523 Level 3 PIN: 77206579 Level 3 PUK: 42272500 Level 4 PIN: 76708155 Level 4 PUK: 01809854 Level 5 PIN: 30139248 Level 5 PUK: 20077510 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears This is PERMANENT UNLOCK... Flashing will NOT RE-LOCK PHONE ================================================== ========================== Loading AFP (Please Wait)...OK AFP revision 3, compiled 23/09/2013 07:35:00 p.m. ================================================== ======== Phone Type : Lumia 900 RM-808, RM-823 Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Automatic Counter Reset (If Needed) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY Flex Cable 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to Phone 5. Use RESET JTAG button to check the JTAG Connection 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- |
