02-15-2015, 04:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Direct Emmc Detection Problem Can U Guide Me With This Whats Wrong With ATF as I Found Many R Saying Problem Detection On Big Box Need To Give Manual 2.8 V supply to point as Pin 2 not passing voltage is it true??when i check voltage is ok... I m using ATF 5in1 Adapter By GPG |
02-15-2015, 10:14 | #2 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Shiraz Iran Age: 37
Member: 1171122 Status: Offline Sonork: 100.1623220 Thanks Meter: 151 | Quote:
You must modify this adaptor If you use 4 in ! V2 you can do it correctly I find S5280 pinout and I think it's like as S5280 I shared it for you this ATF log of S5280 emmc: Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 15010053355530304D0AE291BE06 CSD : D02701320F5903FFF6DBFFE18E404029 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 2560 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 3909091328 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : S5U00M Product Rev : 0.10 Product SN : E291BE06 Manufactured : January 1998 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRANS_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 15010053355530304D0AE291BE06_A7A335A1.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ | |
02-15-2015, 13:40 | #3 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
You issue is in this FAKE 5 in 1 GPG adapter. So, or modific this FAKE adapter or you try with Big Box from Pin 2 but with resistor for to have right voltage. Lock from RJ45 cable: BR allumts | |
The Following 2 Users Say Thank You to allumts For This Useful Post: |
02-16-2015, 14:31 | #6 (permalink) | |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
I also pass 3.5 supply Where 3.3 require in pinot 1.8 also given can u guide me 1.8 also given by external supply??... | |
02-16-2015, 18:25 | #7 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi but you not have seen the wires for eMMc direct?, where there's 3.3V loock good there are 2 Wires and are VCC and VCCq....and all others. What use power supply if are using modified FAKE 5 in 1 GPG.... |
02-17-2015, 09:33 | #9 (permalink) |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x5E5E5E5E |
02-17-2015, 16:46 | #10 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi, but you not see that you Wrong connection? Quote:
If not are many tired sometimes can press Thanks button BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
02-18-2015, 00:22 | #11 (permalink) |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Brother PM me Ur yahoo id it will be better for me.....just 1 doubt if i use open RJ45 cable VCC & VCCQ = VCC & sold both 3.3 & 1.8 to same point.?? My GPG Cable not working only boot repair work emmc not..i ordered Smartgsm cable In my hand Within 2 Days. I Made Rj45 Cable A/c To UR pinout shown. |
02-18-2015, 08:45 | #13 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hey, just loock Photo in post #4 CAREFULLY and all done. If not want do all this, buy New 4 in 1 adapter, but not continue doing how you want, diagram for modific is in post #4 Clear. |
03-03-2015, 23:13 | #15 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Not read that is write to BIG CHARACTERS "RJ45 ATF CHROME"? You cannot use in Nitro/light, why open small box and lost warranty with risk that damage it, this Diagram above is ONLY for BIG ATF CHROME aka GOLD now... yes of course that resistor are of 100 ohms ...what think post false info?...no post these type of question read carefully before post. |
