12-15-2014, 17:54 | #1 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2265913 Status: Offline Thanks Meter: 1 | Dolphin Clip + ATF + Lumia 925 Has anyone attempted to read/flash a Lumia 925 using the dolphin clip? I cannot get the phone to be detected. all I contantly get is Resetting and Exploring JTAG chain...No Devices found in Chain! I have also checked the pinouts and they are all aligned. Has anyone else had the same issue? Thanks |
12-15-2014, 18:08 | #2 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: AvatorBox MCU
Member: 1427447 Status: Offline Sonork: 100.1596998 Thanks Meter: 4,218 | Quote:
Remove usb cable phone ... and connect agian . and press reset jtag and follow the software instructions. better post screenshot ... to give better answer for you | |
12-15-2014, 18:16 | #3 (permalink) |
Member: 2265913 Status: Offline Thanks Meter: 1 | Thanks for the reply I have attempted what you suggested and have followed the screen instructions but I still get the same error. Again all pins are lined up. Can I ask what cables should be plugged into the Dolphin Clip. I have to RJ45 that goes from Dolphin to ATF. I have the USB to the phone also (Phone does not have a direct USB port rather a ribbon cable to connect the batter on) Are there any additional ones. I am fairly new to this so not too sure if any of the other settings on Dolphin need to be altered. Thanks in advance. |
12-15-2014, 20:34 | #9 (permalink) |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | No need any settings in dolphinclip if you not changed anything or change .. For connecting Lumia phones no need any settings in dolphin |
The Following User Says Thank You to Smart-gsm For This Useful Post: |
