Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-17-2012, 08:04   #1 (permalink)
Member: 367928
Thanks Meter: 178
ATF hang while fleshing 6303c, (strange) - [SOLVED SOLUTION INSIDE]
mobile power on after nokia it turn white, but keypaid make beep,
chrging ok,
Old 07-17-2012, 08:17   #2 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
chrging ok,
bro u have update the impotent file ???
bro
Old 07-17-2012, 08:25   #3 (permalink)
Member: 367928
Thanks Meter: 178
bro
yes, all updated.................
Old 07-17-2012, 08:45   #4 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
restart ur computer and then try f not solve then
move the backup data and
delete the atf from c:/ and also from control panal.
install again the Atf...
BRO
Old 07-17-2012, 08:57   #5 (permalink)
Member: 367928
Thanks Meter: 178
BRO
it heppeen only with this 6303c,
all other fleshing are fine, working
Old 07-17-2012, 09:19   #6 (permalink)
mothsd's Avatar
Member: 1350924
Sonork: 100.1613496
Thanks Meter: 13
Hi
bro
No relevance with this
Old 07-17-2012, 09:24   #7 (permalink)
mothsd's Avatar
Member: 1350924
Sonork: 100.1613496
Thanks Meter: 13
Hi
chrging ok,
Just change the flash files and try tested by me with same version(10.12)
Old 07-17-2012, 09:26   #8 (permalink)
Member: 367928
Thanks Meter: 178
alreaady try.....................................
Old 07-17-2012, 09:29   #9 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
chrging ok,
Hi,
Try to change skin to FineVactor.skn or iMatel.skn.
It should be okay.
Old 07-17-2012, 10:06   #10 (permalink)
Member: 367928
Thanks Meter: 178
Originally Posted by ..::Angel::.. View Post
Hi,
It should be okay.
still same sir, always hang ( not responding) at this stage,
some time access violation at adress............................................ ....
Old 07-17-2012, 10:10   #11 (permalink)
Member: 643472
Sonork: 100.96901
Hi,
Post here full logs.. I saw RPL backup was successful, and its not possible
for RAP3G phone such as 6303c RM-443.
Old 07-17-2012, 10:58   #12 (permalink)
Member: 367928
Thanks Meter: 178
Number of Image Files: 3
Processing Image File :
rm443__10.12.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed : 3250000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 98000Hz
Number of Blocks : 1597
Entry Point: 0x5050
Page Format : -1
MAX PAGE : 0x00004000
rm443__10.12.ppm_a
CMT Type : BB5
Number of Blocks : 399
Entry Point: 0x00B6
Page Format : -1
rm443__10.12.image_a_is_matt_black
CMT Type : BB5
Number of Blocks : 640
Entry Point: 0x00C8
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00000001
ID DWORD 3 : 020C1921
ID DWORD 4 : 02054100
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00001040
3 EM_ASIC_ID 02
ID DWORD 0 : 00001030
4 PUBLIC_ID 12
ID DWORD 0 : 12F00219
ID DWORD 1 : D4070049
ID DWORD 2 : 61312D78
ID DWORD 3 : 06DFE93B
ID DWORD 4 : 593D211A
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 67E82268
CRC 1 : F29CEA60
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Revision ID : 0000
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Type not in database
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Manufacturer Code : 00EC ->
Device ID : 0030 -> Type not in database
Revision ID : 0321
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data :
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Flash Descriptor
Device ID : 0030
Revision ID : 0000
Size : 08000000 (128 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_XSR17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
START READING RPL DATA
IMEI: 352682043133619
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\352682043133619\3526820431336 19_23248.rpl
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
108AF4DB7EC8B1B36E9D6A60F7EB2996DC7B2B5D
ImagePath: J:\Phoenix\Products\RM-443\
ImageFilename: rm443__10.12.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
Total blocks to write : 1597
>> CMT Rootkey Hash CERT : NOLO
>> CMT Rootkey Hash CERT : KEYS
>> CMT Rootkey Hash CERT : PRIMAPP
at this point atf hang
Old 07-17-2012, 11:07   #13 (permalink)
Member: 643472
Sonork: 100.96901
As expected, your phone is Nokia 6303i RM-638, NOT RM-443.
Flash with correct files, it will be okay.
Old 07-17-2012, 12:38   #14 (permalink)
Member: 367928
Thanks Meter: 178
rm638__10.80.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Program Sending Speed : 19500000Hz
Number of Blocks : 138
Entry Point: 0x0259
Page Format : -1
MAX PAGE : 0x00040000
rm638__10.80.ppm_mr2
CMT Type : BB5
Number of Blocks : 27
Entry Point: 0x011D
Page Format : -1
rm638__10.80.image_mr2_059B7T7_005
CMT Type : BB5
Number of Blocks : 75
Entry Point: 0x0154
Page Format : -1
2. Insert USB.
BootFlashMode_DCT5
READING BOOTROM
1 SYSTEM_ASIC_ID 01
2 EM_ASIC_ID 02
3 EM_ASIC_ID 02
4 PUBLIC_ID 12
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
7 ROM_ID 15
CRC 0 : 67E82268
CRC 1 : F29CEA60
MessageID : C1
SubBlocks : 06
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0000
Block Length : 0B
Device Index : 01
Revision ID : 0000
Block Length : 0B
Device Index : 00
Revision ID : 0321
Block Length : 09
Data :
Flash Descriptor
Device ID : 0030
Revision ID : 0000
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
FUR control Ok
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\352682043133619\3526820431336 19_50233.rpl
Pabub KEY Request
BB Asic Index : 00
CMT PAPUBKEYS HASH:
ImagePath: C:\Users\Z\Downloads\Products\RM-638\
ImageFilename: rm638__10.80.mcusw
Certificate 1
ASIC Index : CMT 0
Certificate 2
ASIC Index : CMT 0
Certificate 3
ASIC Index : CMT 0
Certificate 4
ASIC Index : CMT 0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
ProcessPartitionInfo_DCT5...
Partition Info
Partition Blocks : 1
1 PARTITION_INFO_BB5
BB ASIC Index : 0x00 CMT
Device Type : 0x03 MuxOneNAND
Device Index : 0x00
Partition Version : 00010000
Spare : FFFFFFFF
Num Partitions : 00000004
Partition 1
Attribute : 00000002 RO
Start Address : 000A0000
Partition 2
ID : 00000008 FILESYSTEM
Attribute : 00000001 RW
Start Address : 02CC0000
Partition 3
Start Address : 077C0000
Partition 4
Start Address : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 0002000A000002720000000000080000000102CC000004B000 000000000A00000001077C0000003800000000000B00000001 07B4000000180000C9
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength : 0xE1 (225)
ERASE Blocks : 0x04 (4)
0 ERASE_AREA_BB5 0x12
Block Length : 0x4B (75)
Device Index : 0x00
0 : 00020000-000203FF
1 : 00060000-0009FFFF
2 : 000A0000-0025FFFF
3 : 003E0000-005DFFFF
4 : 005E0000-010DFFFF
5 : 01EC0000-01EDFFFF
6 : 027C0000-02CBFFFF
7 : 077C0000-07B3FFFF
8 : 010E0000-01EBFFFF
1 FORMAT_PARTITION_BB5 0x19
Block Length : 0x2F (47)
Device Index : 0x00
Format Info ID : 0x02000000
Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
2 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
3 FORMAT_PARTITION_BB5 0x19
Device Index : 0x00
Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
ERASE_REQUEST_BB5 : 5009120B00030000020000000203FF120B0003000006000000 09FFFF120B000300000A00000025FFFF120B000300003E0000 005DFFFF120B000300005E0000010DFFFF120B00030001EC00 0001EDFFFF120B000300027C000002CBFFFF120B000300077C 000007B3FFFF120B000300010E000001EBFFFF3D
FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
Successfully Erased...
Total blocks to write : 138
>> CMT Rootkey Hash CERT : ADA
>> CMT Rootkey Hash CERT : PASUBTOC
>> CMT Rootkey Hash CERT : PAPUBKEYS
>> CMT Rootkey Hash CERT : RAP3NAND
>> CMT Rootkey Hash CERT : UPDAPP
>> CMT Rootkey Hash CERT : DSP0
>> CMT Rootkey Hash CERT : MCUSW
>> CMT Rootkey Hash CERT : MCUSW1
>> CMT Rootkey Hash CERT : GENIO_INIT
>> CMT Rootkey Hash CERT : ISA+DYNSW
ImageFilename: rm638__10.80.ppm_mr2
StartErase_DCT5...
BlockLength : 0x0E (14)
ERASE Blocks : 0x01 (1)
Block Length : 0x0B (11)
Device Index : 0x00
0 : 01EE0000-027BFFFF
ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74
Total blocks to write : 27
ImageFilename: rm638__10.80.image_mr2_059B7T7_005
StartErase_DCT5...
BlockLength : 0x3F (63)
ERASE Blocks : 0x02 (2)
Device Index : 0x00
0 : 02CC0000-077BFFFF
Device Index : 0x00
ERASE_REQUEST_BB5 : 5001120B00030002CC0000077BFFFF90
Total blocks to write : 75
ContinueFlash_DCT5 Complete
Continue Flash Complete : : No Error - 0 (0x00)
STATUS_REQUEST_BB5...
1 Sub Block ID : 15 STATUS_NAND_OK_BB5
Block Length : 0F
BB ASIC Index : 00
Device Type : 03
Device Type : 00
Num Bad Blocks : 00000001
Additional Bad : 00000001
Correctable ECC : 00000000
FlashInfo.RestartMode : 2
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:01:04
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Old 07-17-2012, 12:43   #15 (permalink)
Member: 643472
Sonork: 100.96901
@zargar322
Is phone okay now?
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
Pic Solution jan Nokia Hardware & Hardware Repair 8 10-11-2010 10:56
5110 version 5.24 solution lampin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-14-1999 07:00
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Page generated in 0.34823 seconds with 11 queries
