Downgrading n96 Hello freinds n96 with software problem bring to me,i flashed it with last version i mean 30.101.now problem solved and phone work probably.my problem,this version has not the language that i want,but previous version has this language pack.when i try to downgrade it,phone will not power on.i tried several time with atf but same problem. I think i shoud erease the phone and then flash it with the lower version.of curse i store all pm and RPL.i dont know its gone work or not. but i make this topic to ask you is there any other solution in this case? thanks in advance... |
Yup. It should work. Just go ahead! if you need some manuals - check FAQ thread in sticky BR |
i ereas it then flash,phone shows 123456789 imei,but after write RPL,when i press scan nothing happen,only shows 'reading mcu version" now i cant erase and on the other hand i cant write pm on it either! Code: AdvanceBox SendBootCodeEx |
How to ERASE flash RAPIDOYAWE phones: 1. Backup full RPL and PM 2. Erase phone using ATF erase option 3. Flash with ENO firmware 4. Flash with desire (lower) version - full flash with all files 5. Write RPL backup to fix phone IMEI 6. Write PM120 backup to fix phone SIMLocks 7. Repair SD with ATF 8. StandAlone SX4 auth and PM 1,309 BR |
after flash with higher version problem solved,i mean phone came back to last position. for changing language i only flash it with 30.033 ppm(only ppm) that it had my language pack. thanks for your help:) |
