Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Mar 2010 Location: Rasht
Member: 1254480 Status: Offline Thanks: 76
| Downgrading n96 Hello freinds n96 with software problem bring to me,i flashed it with last version i mean 30.101.now problem solved and phone work probably.my problem,this version has not the language that i want,but previous version has this language pack.when i try to downgrade it,phone will not power on.i tried several time with atf but same problem. I think i shoud erease the phone and then flash it with the lower version.of curse i store all pm and RPL.i dont know its gone work or not. but i make this topic to ask you is there any other solution in this case? thanks in advance... |
| | #2 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Dec 2006 Location: Karachi, Pakistan Age: 22
Member: 643472 Status: Offline Sonork: 100.96901 Thanks: 6
| Quote:
Yup. It should work. Just go ahead! if you need some manuals - check FAQ thread in sticky BR | |
| The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
| | #3 (permalink) | |
| Quote:
i ereas it then flash,phone shows 123456789 imei,but after write RPL,when i press scan nothing happen,only shows 'reading mcu version" now i cant erase and on the other hand i cant write pm on it either! Code: AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned
Number of Sub Blocks 12 (0x0C)
1 SYSTEM_ASIC_ID 01
Block Length : 5 (05)
BB ASIC Index : 1 (01) APE
ID DWORD 0 : 008815D3
2 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
3 PUBLIC_ID 12
Block Length : 21 (15)
ID DWORD 0 : FBC60927
ID DWORD 1 : 153C4A0D
ID DWORD 2 : 0A19F4EB
ID DWORD 3 : 873A32D6
ID DWORD 4 : B90E5E88
4 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 0B BC 42 03 E2 D3 B8 25 04 C7 5C B6 5E 90 6A 35
5 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 137A9A3B
CRC 1 : 33259D2C
6 SYSTEM_ASIC_ID 01
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 400C1921
ID DWORD 4 : 01031103
7 ROM_ID 15
ID DWORD 0 : 00000296
8 ROM_ID 15
ID DWORD 0 : 00000B22
9 PUBLIC_ID 12
ID DWORD 0 : 15400117
ID DWORD 1 : C7DA0158
ID DWORD 2 : 26591A0C
ID DWORD 3 : EC6BAD3E
ID DWORD 4 : 7CACB307
10 ASIC_MODE_ID 13
Mode Id : 00
11 ROOT_KEY_HASH 14
Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE
12 ROM_ID 15
CRC 0 : 4B9B7510
CRC 1 : 3E691FF8
Checksum FA
NOR Chip Detected... Nitro Flashing Disabled
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAPIDOv11_2nd.fg
Boot File - Version 01.037.01
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : 03
SubBlocks : 03
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0020 ->
Device ID : 8804 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 6B21
2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
Block Length : 13
Device Index : 00
Device Contents : 00000000000000000000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
Checksum : 68
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0020 DevID :8804 ExtID :0000 RevID :6B21
Flash Descriptor
Device ID : 8804
Revision ID : 0000
Size : 00800000 (8 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAPIDOv11_algo.fg
Algorithm File - Version 01.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
AD7799ABC45695918C0B8E955FAD5FF12650E6AE
Searching for APE Boot File..
SearchForBootstrap_DCT5...
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\nomadik8815_2nd.fg
Boot File - Version
Boot File - Revision 0x (51744)
eBB5ProtocolType == New
SuggestedType : 04 DDR & 2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
SendAPECodeRequest_DCT5..
SendAPECodeRequest_DCT5 FLS1_NO_ERROR..
MessageID : 03
SubBlocks : 03
Block Length : 0B
BB ASIC Index : APE 01
Device Type : NAND 01
Device Index : 00
Device ID : 00B1 -> Type not in database
Revision ID : 0000
2 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 12
Data : N8815 ALG STNFMS
Block Length : 0B
Device Index : 00
Revision ID : 0000
Checksum : 95
Searching for APE Algorithm File..
Flash Descriptor
Device ID : 00B1
Revision ID : 0000
VPP Info : 0015
Erase10s : 0F
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPPInfo : VPP_INFO_3V_MASK VPP_INFO_12V_MASK VPP_INFO_ERASE_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\nomadik8815_alg.fg
Algorithm File - Version 01.059.00
APE Algorithm Sent
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 01 )
BB Asic Index : 01
APE PAPUBKEYS HASH:
( CMT and APE PAPUBKEYS HASH are Identical )
Scanning Simlock Applet Type...
OK
SL1/SL2 Applet detected
FlashInfo.RestartMode : 2 | |
| | #4 (permalink) |
| How to ERASE flash RAPIDOYAWE phones: 1. Backup full RPL and PM 2. Erase phone using ATF erase option 3. Flash with ENO firmware 4. Flash with desire (lower) version - full flash with all files 5. Write RPL backup to fix phone IMEI 6. Write PM120 backup to fix phone SIMLocks 7. Repair SD with ATF 8. StandAlone SX4 auth and PM 1,309 BR |
| | #5 (permalink) | |
| Quote:
after flash with higher version problem solved,i mean phone came back to last position. for changing language i only flash it with 30.033 ppm(only ppm) that it had my language pack. thanks for your help | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Downgrading 6150?? | taichip | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 10-22-2001 20:27 |
| Downgrading the fone! | Cyb3r_j | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 07-24-2001 06:18 |
| How to downgrade software with fullemmi | Me@n | Old Legacy Motorola (EMMI) | 5 | 07-09-2001 19:22 |
| real downgrade c4 13 03 v2288 for exchange | al_bu2000 | Old Legacy Motorola (EMMI) | 0 | 06-05-2001 12:08 |
| ..you'll need to downgrade your software / Contact service | Magic2ik | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 08-23-2000 18:36 |
